Question about Crossfire VR600D Car Audio Amplifier
Crossfire VR600d Need to know the value of resistors R61 R62 and R67 would appreciate it if you have any idea thanks forge
0 characters
1 Points
I got an amp from my buddy who was going to throw it out cause he broke the 0.2 to 6 volt dial. He discarded the old broken part out of fustration. Anyone know the part number for said missing piece? ...
so we know a few things...
1. you guys are inside the amp removing board soldered components.
could be a good thing since what you can do to sleuth a solution is this...
a. know that the 'knob' is actually a variable-resistor that ranges resistance from a start value to a max value.
b. you can ascertain the range by opening a similar amp and testing the resistance range as you rotate the knob.
c. pick the mid value resistance and buy a cheap resistor of that value, then just solder the resistor in place of the two knob-control bread board connectors.
May 07, 2011 | Crunch Maxxsonics P1500.1 Car Amp
Sony Xplod-XM-554ZR-- - - Resistor on circuit board HELP!!!
R466 is chip resistor 220 Ohms 1/8 watt connecting between Emitter pins of Q408 and Q409.
Its part number is ...
R466 "1-216-182-00" RES-CHIP 220 5% 1/8W
Available in Part Store.
Let me know if you need further info.
Apr 02, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
JL 500/1 Problem
You need the old transistor. Knowing it's brown is not enough; you need to know its resistance value. It sounds like the resistor you replaced with has too low a resistance value, causing the "cuts" in sound. Find the old resistor and then use this site to find out what you need:
Jan 13, 2009 | Jl Audio 500/1 Car Audio Amplifier
Crossfire VR600D Car Audio Amplifier Logo
76 people viewed this question
Top Crossfire Car Amplifiers Experts
xxxxxx xxx
Electro Med Services...
Are you a Crossfire Car Amplifier Expert? Answer questions, earn points and help others
