Question about ASUS P4S8X Motherboard
Asus P4S8X-X - Pentium 4 - 2.4 GHz
My Asus P4S8X-X mobo has acted strangely. The Computer worked fine but now I have to wait one hour or more, waiting for some screen image. After the system wakes up, it works for a while normally but turns off again. No beep, no screen, no error. I do not have other mobo or processor to replace.I've already released all boards, the memories, video, battery etc. but nothing could solve the problem and already update the bios also, but again unsucessfully.Any idea, please help.
  • ASUS Master
  • 12,061 Answers
I would try another Power Supply Unit.. are you sure it's the PC and not the monitor thats faulty? You could check this by connecting another monitor,and see if it does the same...
Posted on Jul 30, 2007
SOURCE:
Its stuck in first start-up with "just a moment"...for several hours now.
Take out the battery, wait 20 seconds and plug it in again. restart the laptop and it should start up normally.
Is it a new laptop that you start up for the first time?
Dec 30, 2015 | ASUS X551MA-DS21Q 15.6" Notebook - Intel...
Have asus p4s8x mob,when adding 3rd stick of memory (1gb) total of 3gb.computer hangs on startup 1long 3 short beeps. if i remove one old stick and leave new with old (2gigs total)it works fine,also works...
The Asus Asus Motherboards P4S8X-MX uses PC-3200 type memory and usually ships from Asus with 0MB of RAM. The Asus Motherboards P4S8X-MX supports up to 2GB of RAM. Maximizing your system memory will allow your Asus Motherboards to operate as fast as possible and offer the most productive environment.
RAM modules must be installed in special locations on the motherboard called Sockets. These memory sockets are what hold the RAM module in place and can range from 1 to 16 or more. Banks consist of a group of 1 or more sockets. A system can have 1 or more of these banks of sockets. If a system has more than 1 socket in a bank, a Kit must be purchased for that bank. A kit is simply more than one, usually 2 or 4, like RAM modules. All sockets in a bank must be filled, and for such systems we sell memory in a kit. Typically you will see 2x512MB or 2x256MB signifying you are purchasing 2 units of 512MB RAM modules or 2 units of 256MB RAM modules, respectively.
The Asus Asus Motherboards P4S8X-MX has 1 bank(s) which have 2 socket(s) in each bank for a total of 2 memory socket(s). This means the Asus Motherboards P4S8X-MX can support up to 2 individual RAM modules.
We recommend you purchase the largest capacity RAM module each time you purchase memory. The reason for this is if you decide to upgrade again later and all your memory sockets are filled, you will not need to discard the already installed lower capacity memory.
Below is a visual representation of the memory bank(s) and socket(s) configuration for the Asus Asus Motherboards P4S8X-MX.
Standard Memory Bank & Socket Configurationsocket_2.gif hope this helps John
Jul 01, 2011 | ASUS P4S8X Motherboard
Hi.. I have a server system having Intel Pentium 4 processor. The following details are written on the Processor. Intel (m) (c) '03 PENTIUM (R) 4 2.8 GHz, IM1800, jl79k MALAY, Q417A92 t417b040 ...
hi,
you can on this motherboard models for your intel Pentium 4 processor,
1. ASUS P4P800 Deluxe
2.MSI Neo2-FIS2R
3.ASUS P4C800 Deluxe
4.Intel D865PERL
5. ABIT IS7
Feb 16, 2011 | ASUS Support Intel Pentium M Processor and...
What is the fastest processor that can be used with this motherboard?
 3.06 GHz Pentium 4  with Northwood core. Newer ones will not be recognized by the BIOS.
Apr 25, 2010 | ASUS P4S8X Motherboard
What mobo can replace ASUS P5PE-VM
the socket of you processor is lga775, the graphics port is agp and it support DDR I , so you need to buy a motherboard that has the exact specifications.
my advice is to continue with asus. you could buy an Asus P5P800/ P5S800 that is compatible with your previous motherboard. there are also some good models from asrock and they may be cheaper than asus.
the problem with this type of motherboard is that they are expensive because that are not in use.
Dec 20, 2009 | ASUS P5PE-VM Motherboard
Best/Fastest CPU for DFI PE21-EL mobo
Your motherboard supports 2 different fsb's.
look these up @ cpu-world
you can use:
Intel Pentium 4 processor (478-pin)
- 533MHz system data bus - supports up to 2.8 GHz
- 400MHz system data bus - supports up to 2.4 GHz
Intel Celeron processor
- 400MHz system data bus - supports up to 2.0 GHz CPU speed
and here are the suppoted cpus:
Intel Celeron RK80531RC029128 BX80531P170G128 1.7 GHz 17 x 400 MHz, Willamette Any A RK80531RC033128 BX80531P180G128 1.8 GHz 18 x 400 MHz, Willamette Any A RK80531RC037128 BX80531P190G128 1.9 GHz 19 x 400 MHz, Willamette Any A RK80532RC041128 BX80532RC2000B 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported RK80532RC045128 BX80532RC2100B 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported Intel Pentium 4 RK80532PC021512 1.5 GHz 15 x 400 MHz, Northwood Any A RK80532PC025512 BX80532PC1600D 1.6 GHz 16 x 400 MHz, Northwood Any A RK80532PC029512 1.7 GHz 17 x 400 MHz, Northwood Any A RK80532PC033512 BX80532PC1800D 1.8 GHz 18 x 400 MHz, Northwood Any A RK80532PC037512 1.9 GHz 19 x 400 MHz, Northwood Any A RK80532PC041512 BX80532PC2000D 2.0 GHz 20 x 400 MHz, Northwood A 1.525V not supported 2.1 GHz 21 x 400 MHz, Northwood A 1.525V not supported RK80532PC049512 BX80532PC2200D 2.2 GHz 22 x 400 MHz, Northwood A 1.525V not supported RK80532PE051512 BX80532PE2266D 2.26 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PE056512 BX80532PE2400D 2.4 GHz 18 x 533 MHz, Northwood A 1.525V not supported RK80532PC056512 BX80532PC2400D 2.4 GHz 24 x 400 MHz, Northwood A 1.525V not supported RK80532PC060512 BX80532PC2500D 2.5 GHz 25 x 400 MHz, Northwood A 1.525V not supported RK80532PE061512 BX80532PE2533D 2.53 GHz 19 x 533 MHz, Northwood A 1.525V not supported RK80532PC064512 BX80532PC2600D 2.6 GHz 26 x 400 MHz, Northwood A 1.525V not supported RK80532PE067512 BX80532PE2667D 2.66 GHz 20 x 533 MHz, Northwood A 1.525V not supported RK80532PE072512 BX80532PE2800D 2.8 GHz 21 x 533 MHz, Northwood A 1.525V not supported
Dec 26, 2008 | DFI PE21-EL Motherboard
Dont suit my mobo
remove the graphics card, turn the computer on, wait for any error beeps if any, then re-install the card , then try it again, this should work, hope this helps you,glen.
Dec 21, 2008 | ASUS A9550GE/TD Radeon 9550 Graphic Card
CPU fan
When you say power is going to the mobo, are
other fans and lights turning on? You also may have forgotten to plug in
the large ATX power cord from the PSU, or the smaller 4-pin rectangular 12V
power cord. Is the correct local voltage setting for your PSU selected (110
or 220)?
Feb 19, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
About my pc's configuration
amd i live get amd x 6400 with 4 gb ram to start nice asus mobo and a 8800gtx video nice power suply with it and mide size case with alot fans ok u can pplay any game get parts on newegg.com all for under 500
Jan 23, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
ASUS P4S8X Motherboard Logo
156 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
