40 gig Western Digital HD - Bios recognizes the drive - but doesn't show up in windows 2000 - drive isn't making any weird sounds - tried to swap the arm/heads with another same model drive that one started crashing so I put things back to original - windows 2000 still not reading the drive - what next?
  • 16 Answers
Check if you can see the drive in Disk Management - right click my computer, press manage, select disk management. create partition then format it.
Posted on Nov 21, 2008
How to swap hardware driver of wd hd
You don't have to swap drivers in windows it just a generic driver for all hard drives unless your using AHCI but that's generic too if your already using it. Just shut the machine down, don't get any static sparks from you fingers on anything, touch the metal PC tower firmly first, swap the drive, restart the computer and install windows. If the drive is in already and it's for a second drive and your PC isn't recognizing it it meamns your PC is to old and you need the Western Digital Acronis free version and you'll have to keep it installed on your computer for the life of the drive, it has a Tool or Utility called extended capacity manager that will recognize your drive properly. I can't see a SATA 2 drive being used in anything old enough to need software to recognize 500gigs. You wouldn't be able to use SATA.
Feb 20, 2014 | Western Digital WD Caviar Green WD5000AADS...
Bios not recognizing new hardrive
Hi:
Some older laptops don't always recognize the full size hard drives bigger than 134 Gb, but they usually show up in your bios. There isn't an easy way to install it wrong, so if the drive wasn't new to you, it might have a problem...New Hard drives come with installation CD's, but that won't do you any good until the drive is recognized
Nov 24, 2009 | Office Equipment & Supplies
400 Gig Western Digital My Passport not recognized
Delete that video in other pc's with deepfreeze to keep away from system failure. You need to scan your passport, vista is more tricky than xp anything about viruses will cause them to freeze or to reboot on their own to prevent system failure.
Sep 30, 2009 | Western Digital Passport WDXML800UE...
HD/MOTHERBOARD ISSUE
You can try using FDISK to partition the drive into multiple smaller drive images.
Sep 13, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
My WD Mybook TByte HD is not being recognized
There could be many reasons, but I had the same issues.
It turns out I had mistakingly swapped the 12v DC PSU with another one, the drive would light up, it would click but that was it. Nothing. Gave me the runaround for ages. Seems they need more current than the little PSU I was trying could deliver, so I swapped it for a 2 amp supply and it works fine.
Mar 13, 2009 | Western Digital 250GB MyBook External USB...
Western digital 500 gig hd eide disc error????
Take it back to the store - this is a common problem with WD drives and WD are doing nothing to address this issue with their larger drives. Buy another make and you should be trouble free.
Feb 17, 2008 | Western Digital Caviar SE16 (WD5000KS)...
Western Digital External Hard Drive SN WCAMR4295471
If you are using a pre-Windows xp system you may need to install specific drivers for your HD. If you run xp or Vista Try disconnecting completely the power cable from your computer for five minutes and then plug it back to the power and restart it. I know it sounds weird, but sometimes usb mass storage devices suffer troubles caused by electrostatic charges.
Jan 03, 2008 | Computers & Internet
Internal hd ata
If I am right on this one the 4600 can only take a 250gig hd But I was wondering if you could partion the HD to 236.7 gigs twice so the computer only recognizes the 236.7 gig hd you will see two drives in my computer once you do just format both partitions unless you have another hd and then you will see three drives just do the ones you installed or you may loose your operating system, I don't even know if that will work, but I think it is worth a try seems you already have the 500gig drive, can't hurt to try, I sure hope this help some what.,
Dec 22, 2007 | Dell Dimension 4600 PC Desktop
New Hd HELP
I guess there is nothing with BIOS since it identify your Western Digital Caviar Hard Drive. Try changing the jumper setting of this Hard Drive by reading the Instruction that comes along when you purchase. Otherwise you can visit the Western Digital website and click on Support-Knowledge BASE...http://www.wdc.com
Apr 08, 2007 | Western Digital Caviar SE WD2500JS...
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
