Question about Canon PowerShot S45 Digital Camera
S45 sliding cover fault
Hi, The sliding cover on my S45 has become loose, and the camera sometimes powers down when the camera is on and in use. Seems like the cover switch has become very sensitive to the slightest movement of the cover when in use, and easily turns off. Otherwise, the camera works fine. Can I fix this fault, or is it a Service Center repair. If it is fixable easily, what do I need to do? Thanks. JEFF
  • ag114 Dec 20, 2007
    Lens cover is in the open position, lens is extended,
     power to the camera is off.   Cannot get any digital
     info displays to show.  Screen is dark.
Question: re a jammed open cover, the advice above says, "You can easily take off the front cover to investigate this" . How? - Just ease it off, or undo the screws in the silver plate that holds the carry cord? Thank you.
Posted on Feb 19, 2008
    Problem Solver:
  • 17 Answers
When you start to close the lens cover, a pin pushes against a spring to trigger the lens retraction sequence. You can easily take off the front cover to investigate this, and possibly adjust the angle of the spring to make it less sensitive. Just be careful not to yank out the ribbon that connects it all together.
Posted on Dec 09, 2007
How to open the battery box?
From examining the plethora of images available on Google, it seems there is a sliding cover on the base of the camera. Use your thumb to push this gently towards the edge, and the batteries should be revealed (also, probably, the SD card for when you need to replace that.)
Sep 10, 2016 | Pentax Optio S45 Digital Camera
MY CAMERA WAS OK BUT NOW IS NOT COMING ON
Is neither the taking pictures or viewing pictures mode working?
If it's only taking pictures that's a problem, make sure you slide the cover all the way across until it clicks. I have the same camera and have noticed it won't come on if you don't push it all the way.
Feb 24, 2010 | Canon PowerShot S45 Digital Camera
My camera lens will not extend when the cover is pulled back. The battery is fully charged and but when I pull the lens cover back the lens should zoom out automatically but it does not. I can't...
Hi
You are probably suffering from the most common fault with the MJU 300/400 range of cameras. If you can still see pictures from your memory card when you use the quick view button, then this is a good indication that the software of the camera is operating perfectly. However the camera switches to photo capture mode when the lens cover is moved back. It is a common fault with these cameras that the black plastic armature operated by the sliding action becomes loosened from the case resulting initially in the cover becoming sloppy and causing the lens to keep closing erratically. More importantly the plastic armature which is positioned to operate a tiny Surface Mounted switch can cause the fragile plastic 'nib' to break off. It is this switch that in effect turns the camera on. If this is what has happened, it is the most common fault, there is very little that can be done as a DIY repair unless you have access to speciallised SMD soldering equipment, experience in this type of repair and most importantly a source of supply for the SMD switch. I have as yet been unable to identify the type or supplier myself. The alternative is to take the camera to an authorised repair shop. This is the expensive route but you might be able to keep the costs down by making it obvious that you know what the fault is etc.
Dec 21, 2009 | Olympus MJU 400 Digital Camera
Lens cover doesn't open when switching on
If you've recently dropped the camera you may have damaged the lens tube (housing) or jarred the zoom mechanism off of its track. Either one of those problems will require professional repair. If it hasn't suffered from a drop, your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may be to weak/worn to properly power the camera, or the camera may require professional repair.
Oct 16, 2009 | Olympus MJU 400 Digital Camera
Cannot find a driver for Canon PowerShot S45 for Windows Vista
When connecting a digital camera to your computer with the usb connector, then turning it on the memory card in the camera becomes a removable drive under My Computer and will also bring up a dialogue window that will ask if you want to import pictures, etc. There is no need for a driver. Steve Medley
Dec 11, 2008 | Canon PowerShot S45 Digital Camera
No Power up
Dear ianaird:
There is no fuse or anything to jump-start a dead camera unfortunately. If you have tried a different battery and you are sure it was good, then check your battery and memory card door to make sure they are completely closed.
If still no power, try removing the battery and gently wiping with an eraser and then a clean dry cloth all battery contact areas that you can reach. Reinstall the battery and try again.
If you still get no power you will likely need to send the unit in for service. Contact Canon's Tech support at 1-800-828-4040.
Hope that helps.
Sincerely,
HeavyDLB
Apr 12, 2008 | Canon PowerShot S45 Digital Camera
My Sony Cybershot DSC-S45
the button is offset inside the camera, there is a little piece of plastic that seems to loose its elasticity and will not depress the actual on/off switch inside.
Dec 09, 2007 | Canon PowerShot A460 Digital Camera
Maybe this fuse is blown:
http://www.hit-karlsruhe.de/aol2mime/images/S45_S50_PowerFuse.jpg
Short it or replace it.
See also http://www.hit-karlsruhe.de/aol2mime/canon_powershot.htm
eNDi
Oct 17, 2007 | Canon PowerShot S45 Digital Camera
Lens cover is stuck
I did the same repair...however, I found that those little wheels are completely optional. All they do is keep the lens cover from prying away from the camera, but if you're careful, the lens cover will work without them.
Sep 07, 2006 | Canon PowerShot S45 Digital Camera
Canon PowerShot S45 Digital Camera Logo
224 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
