Question about Janome Memory Craft 5700
Janome e1 error
I was hemming my sons pants when my janome 6600 made a really awful nosie the lcd screen said turn off power which I was in the process of doing.  I have unplugged it rethreaded the machine and it still will not sew.
  • Janome Master
  • 1,388 Answers
The erreor message relates to the motor sensing that it is working unusually hard.........the extra strain will have a physical cause, generally in the hook and bobbin region.......something blocking or slowing things down, so.......
Remove needleplate and bobbin case.
You will probably find an accumulation of lint in and around this area, also possibly in the feeddog channels.
Use a small brush and vacuum with crevice tool to remove the lint and wipe the hookrace with a tissue moistened with methylated (denatured) spirit to remove any dirt deposits.
Also check that the bobbin case is not damaged on the top surface by needle strikes or on the underside rim by the hook gouging as it spins.
If damage is present but mild, you can use very fine emery paper to smooth surface, if more severe, replace the bobbin case. Don't forget to change needles regularly too.
Best of ......
www.bargainbox.com.au
Posted on Nov 21, 2008
My Janome Harmony 8048 continues to loose its memory which causes an E1 error. What can be done?
Internet research shows this may be a problem that needs to be addressed by a technician. Take it for service.
Questions Answers for janome e1 error
Jun 01, 2016 | Janome Sewing Machines
How do I fix the E1 error code?
Abnormal rotation in main motor Motor runs at more than maximum speed
Look HERE for Service Manual
May 22, 2012 | Brother CS6000i Computerized Sewing...
Janome 6600 displays E3 Error. How do I correct
Hi
Direct from the Janome workbook E3 error relates to:
"Stepping motor for tension release (MC6500P & MC6600P only)"
Ensure there is no lint or thread trapped between the discs of the top tension unit.........try "flossing" where thread goes down thru tension unit with a scrap of clean fabric.
It may also be the mechanism that releases tension when the presser foot is raised....it is a sensor and may be out of alignment...not really an easy home fix.
Let me know how you get on, just remind me of the issue as I respond to many.
Bargain Box
Sep 15, 2009 | Janome Sewing Machines
Janome E1 error
If a warrantee job, it will be no charge.
Motor in Australia is $149-00.....plus installation charge.
You could phone or email Janome HQ or another dealer in your country and ask for an explaination of the E1 error to satisfy yourself of what is the likely cause, and a quote to fix it.
Aug 21, 2009 | Janome Memory Craft 5700
Janome 6600p: E1 error
Hi
Bargain Box
Oct 08, 2008 | Janome Sewing Machines
Janome 6600
I've always been able to get a free PDF downloadable manual from Janome. They are happy to send you a manual for your specific machine via email, and they've always been very helpful to me. Here's a link to them:
http://www.janome.com/index.cfm/ContactUs/Machine_Support
Hope this helps!
Jul 12, 2008 | Janome Memory Craft 5700
Cant hem unable to workout what length to start with to end up with the correct length required looking at the manual it says to take the hem and fold it over etc. but its very confusing
Sorry, I don't understand just what you mean by "length to start". Length of what - stitch? hem turn-up?
Let us assume you are taking up a hem of a pair of pants. Try them on and put a pin where you want the hem to finish i.e. this will be the bottom of the pants. Take pants off, turn them inside out (careful that your pin does not fall out!) and fold the excess pants on that pin mark. The excess fabric should be on the outside, not tucked inside the leg tunnel. Measure how much it is from the existing hem to where you folded it over, let us say for the purposes of this exercise it is 4 inches. Your hem is to be 1 inch and you need 1/2 inch to turn under for a neat finish, total 1 1/2 inches, so you need to cut off 2 1/2 inches from the bottom of each pants leg. Fold 1/2inch at new leg bottom (wrong side of fabric to wrong side), press, fold 1 inch hem same way and press. Place pins every 2inches or so at a right angle to the hem edge. Pins should come out 1/4inch from edge of hem where the 1/2inch neatening fold was made (this is where I wish I could draw a picture!). Fold the hem back inside the leg tunnel. The pins should make the fabric fold under only enough so that 1/4inch of the hem sticks out beyond the pants leg. You will sew on this bit using the blind hem stitch (04 on my 7550). You might need to adjust the stitch width - not length - so that the straight part of the stitch goes along the hem bit and the zig-zag JUST bites into the pants leg fabric.
I do hope this lengthy explanation is of some use to you!
Jul 01, 2008 | PfaFF Creative 7570
Error 5 on my machine
Can I get a copy of the instruction manual for your Janome Harmony 2049? I got my mom's machine when she passed away in Dec but no manual. Thank you!
Jun 28, 2007 | Janome 2049LX Mechanical Sewing Machine
Sewing Machines Logo
581 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
