Question about Toshiba TZ50V51 50" Rear Projection Television
Multiple images my projection tv shows three images at the same time
  • tigery58 Nov 24, 2008
    I have the red image not in convergence with the others and the red line seems to bend too.  Could you please tell me which IC chip I need to change?or how can I locate the problems?
  • 125 Answers
Your TV is having convergence problems, there are 2 integrated circuits on the convergence section to be replaced, possibly there are some resistors blown also.
After the integrated circuit are replaced your technicican will have to clean the mirror and lens and realign the picture I am in Los Angeles
Saludes a todos los de centro America y sur America ; oops tambien los de North America. - Tv.repair at yahoo.com
Jose
Posted on Nov 21, 2008
Picture scrambled / multiple pictures
CONVERGENCE PROBLEM. FIND A HONEST TV TECH. MAYBE A $300 REPAIR
Nov 11, 2013 | Sony KP-61S70 61" Rear Projection...
Hi i have a kp-57HW40 sony projection tv. Right now it is failing, and when I turn it on I hear multiple clicks. The screen will not even light up, just stays black as it if were powered off. On the...
Thats the error for having a issue with the +5V which can be caused by either the A board or the B Board with the B board being the most likliest cause.
Jul 09, 2011 | Sony KP-57HW40 57" Rear Projection...
The tv shows only red and blue it projects three
You need to replace Both STK ICs . They are Big Black ICs and will have PN# on them
example STK392-110
Mats has ICs 1-800-628-1118
Also check the Pico Fuse in Front and back Of ICs they look like resistors ,But will be Green or Yellow 5amp, 6amp, 7amp.
Feb 22, 2011 | Sony KP-51HW40 51" Rear Projection...
The tv image is showing in three colors....Almost ghost like but in three colors. I checked my connections and tried my blue ray player and the image is still messed up....I did press the magic focus...
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
You can get a repair kit with parts and instructions from www.TvRepairKits.com
Sep 23, 2010 | Hitachi 53FDX20B 53" Rear Projection...
Converging problem
This is a rear projection TV that uses three color "guns" in a cathode ray tube . They are no longer converging at the screen. The convergence problem is usually a sign of something else gone wrong with the high voltage.
Do NOT attempt to open this set yourself. This type of TV can have LETHAL voltages inside for WEEKS after it is unplugged. The repair and convergence calibration will require a qualified service technician.
Jan 09, 2010 | RCA HD52W59 HDTV Projection Television
I have Sony KP-46WT500 Projection TV. For some time it appears convergence went bad. I see multiple images, especially at edges and corners. As many as 3 images Red, Blue and Green. I am an Electronics...
It would be great to assist you in Sony convergence issue.
As you said, for some time TV shows bad convergence in picture that shows its matter of lose/ dry solder joints in D board, specially on convergence out ICs pins that need to be re-solder.
There are 2 big black ICs mounted on aluminum heat sink on D Board of TV, below image shows D Board location in TV.
Resolder pins of these 2 ICs and also check any other dry/ cold solder joints in circuit board. I do not think of IC replacement as problem occurs some time.
Let me know if you have additional question.
Thanks.
Dec 20, 2009 | Sony KP-46WT500 46" Rear Projection...
Rca 52" projection image problem
Try this with TV off Press and Hold at same time ch- and vol - until TV comes on It should either let you into service mode or start convergence Automatically
Sep 25, 2009 | RCA P52929 52" Rear Projection Television
Three separate images about 4-5 inch apart on my TV
Symptoms shows TV has problem of faliure of convergence out ICs. (2 ICs in TV) and need to be replaced.Let me know do you want to repair it at your own? ...
... if yes, it is necessary to have experience of TV repair and basic electronics knowledge.
Nov 23, 2008 | Sony KP-51WS500 51" Rear Projection...
Panasonic rear projection tv convergence problem
Check the regulator and convergences ICs....accordianman
Feb 26, 2008 | Televison & Video
TV pops and shuts off
Its two maybe three issues that your having trouble with. First thing is the convergence. That problem could be a cold solder connection on the convergence IC's or the Ic's have a thermal problem, as after they heat up they go bad. The second is the popping. This could be an issue with the rear channel Audio output Ic intermittanly shorting and shutting down the set, or it could be a bad ground around the picture tubes, or a leaky hi voltage block, or a second anode lead going to the picture tubes could be split. The other common problem with this set is the STR#### regulator IC in the power supply. Now unless your a tech you shouldnt attempt any of these repairs as there is very high voltage in this set and could cause great harm to you. seek the help of an authorized repair shop for Toshiba. Try this # if you cant find one in your area 800-457-7777 Good Luck
Jun 09, 2006 | Toshiba 55H70 55" Rear Projection...
Toshiba TZ50V51 50" Rear Projection Television Logo
101 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
