Question about HP DeskJet 3930 InkJet Printer
The print option is defaulted to Custom Printing.
Is there a way to change the default option? I would like for it to always be set at fast, economical which uses less ink. Then if I wanted a better quality, I could change it.
  • 67 Answers
On the properties on the printing wizard when you click print you can change the options you wanted.
Posted on Apr 28, 2009
Set xerox 7845 to black as default print color
You can always look for answers to your Xerox questions at www.xerox.com/support .
Default the Print Driver to Print in Black and White Only for a Microsoft Windows 7 OS:
The steps below can be used to restrict color printing through the print driver.
NOTE: This solution requires administrative permissions and may require the assistance of a System Administrator.
Open the Printers, Printers and Faxes, or Devices and Printers window. See the Related Items below for additional information.
Right-click on the printer, and then select [Properties] or [Printer Properties].
Click on the [Administration] tab.
Expand the [Configurations] section.
Enable the option for [Black and White ONLY].
Click [OK]. The driver will now have Black and White printing as the default and locked so that the option cannot be changed.
Default the Print Driver to Black and White for a Microsoft Windows OS:
Open the Printers window on the computer.
Right-click on the required printer, and then select [Properties] or [Printer Properties] depending on which operating system is being used.
Click on [Advanced], and select [Printing Defaults].
Click on the [Image Options] tab.
Under Color Correction, select [Xerox Black and White Conversion].
Select any other required driver default settings.
Click on [Apply].
Click [OK] to save the settings.
Close the window.
Default the Print Driver to Black and White for MAC OS:
Launch an application, preferably not your browser, that you can print from, e.g. Microsoft Word
  1. Select File -> Print
    1. Select Xerox Features where it says Copies \& Pages
    2. Select Color Options from the drop down labeled Paper/Output
    3. Select Black and White (Black and white printing on the Xerox 7845 costs less.)
    4. On the Presets drop down, select Save As and enter a name, e.g. "Black and White" if you print to multiple printers, check the All Printers
    5. Click OK to save this preset
Now you can test printing by clicking Ok to the print dialog.
Sep 30, 2013 | Office Equipment & Supplies
Force Canon iR2270 to always pull from a specific drawer.
There are no need to crazy brother, Print document from any tray is does not control by the window driver in default mode, u have to select the tray from machine in which u want that printout are coming by default,,............
First Of all Pull out ur tray from which u want to print outs are comming by defult, than there is a small gear under circle where u set the page size, in the corner of the tay, u have to turn in toward the ltr mode, after that machine automatically pick up the page from this tray by defult
Dec 14, 2012 | Canon ImageRunner 2270 | IR2270 |
When I copy to photo paper it reduces automatically, why
Print on special and custom-sized media
To print on special or custom-sized media (Windows)
1. Load the appropriate media. For more information, see Load media.
2. With a document open, click Print on the File menu, and then click Setup,
Properties, or Preferences.
3. Click the Paper/Features tab.
4. Select the media size from the Size is drop-down list.
To set a custom media size:
a. Click the Custom button.
b. Type a name for the new custom size.
c. In the Width and Height boxes, type the dimensions, and then click Save.
d. Click OK twice to close the properties or preferences dialog box. Open the
dialog box again.
e. Select the new custom size.
5. To select the media type:
a. Click More in the Type is drop-down list.
b. Click the desired media type, and then click OK.
6. Select the media source from the Source is drop-down list.
7. Change any other settings, and then click OK.
8. Print your document.
To print on special or custom-sized media (Mac OS)
2. On the File menu, click Page Setup.
Chapter 2
28 Use the device
3. Verify that the correct printer is selected.
4. Select the media size.
5. To set a custom media size:
a. Click Manage Custom Sizes in the Paper Size pull-down menu.
b. Click New and type a name for the size in the Paper Size Name box.
c. In the Width and Height boxes, type the dimensions and set the margins, if
desired.
d. Click Done or OK, and then click Save.
6. On the File menu, click Page Setup, and then select the new custom size.
7. Click OK.
8. On the File menu, click Print.
9. Open the Paper Handling panel.
10. Under Destination Paper Size, click the Scale to fit paper size button, and then
select the customized paper size.
11. Change any other desired settings, and then click OK or Print.
Print borderless
Borderless printing lets you print to the edges of certain media types and a range of
standard media sizes.
NOTE: Open the file in a software application and assign the image size. Make
sure the size corresponds to the media size on which you are printing the image.
You can also gain access to this feature from the Printing Shortcuts tab. Open
the printer driver, select the Printing Shortcuts tab, and select the printing
shortcut for this print job drop-down list.
NOTE: Borderless printing is not supported on plain media.
To print a borderless document (Windows)
2. Open the file that you want to print.
3. From the application, open the print driver:
a. Click File, and then click Print.
b. Click Properties or Setup.
4. Click the Paper/Quality tab.
5. Select the media size from the Size is drop-down list.
6. Select the Borderless Printing check box.
7. Select the media source from the Source is drop-down list.
8. Select the media type from the Type is drop-down list.
Print borderless 29
9. If you are printing photos, select Best from the Print Quality drop-down list.
Alternatively, select Maximum dpi, which provides up to 4800 x 1200 optimized
dpi* for optimum print quality.
*Up to 4800 x 1200 optimized dpi for color printing and 1200 input dpi. This setting
might temporarily use a large amount of hard disk space (400 MB or more) and will
print more slowly.
10. Change any other print settings, and then click OK.
11. Print the document.
12. If you printed on photo media with a tear-off tab, remove the tab to make the
document completely borderless.
Change settings from an application for current jobs (Windows)
To change the settings
1. Open the document that you want to print.
2. On the File menu, click Print, and then click Setup, Properties, or Preferences.
(Specific options may vary depending on the application that you are using.)
3. Change the settings that you want, and then click OK, Print, or a similar command.
Change default settings for all future jobs (Windows)
1. Click Start, point to Settings, and then click Printers or Printers and Faxes.
- Or -
Click Start, click Control Panel, and then double-click Printers.
2. Right-click the printer icon, and then click Properties, Document Defaults, or
Printing Preferences.
3. Change the settings that you want, and then click OK.
9. If you are printing photos, select Best from the Quality drop-down list.
dpi*.
print more slowly.
10. Select the media source. If you are printing on thick or photo media, select the
manual feed option.
11. Change any other print settings, and then click Print.
Nov 04, 2011 | HP J4680 Office Jet All-In-One Printer
How do I get a fax transmission report to print from a Fuji Xerox C1190FS?
Printing Transmission Reports
To select a default option for printing fax transmission reports:
1. On the printer console, press the System button.
2. Select Admin Menu, and then press the OK button.
3. Select System Settings, and then press the OK button.
4. Select Fax Transmit, and then press the OK button.
5. Select one of the following options, and then press the OK button:
- Print Always: A transmission report is always printed.
- Print at Error: A transmission report is only printed when an error occurs with the fax
transmission.
- Not Print: A transmission report is never printed.
Note: The factory default is Print at Error.
Mar 05, 2011 | Office Equipment & Supplies
How do I program the printer to only print in blck/white
Any default (or normally used) settings, can be made by changing the Printing Preferences for that specific printer.
1) Find the printer...ex: [Start]--> [Settings]--> [Printers and Faxes]...then [right-click] on the printer name/icon.
2) The pop-up menu that appears should list an option to select called, "Printing Preferences".
3) Under the [Paper/Quality] TAB, you can select "Black and White" (instead of the normally default, "Color").
4) Make sure to click OK, and that printer should (by default/ normal) print in B/W now.
--- you can change this to "Color" in Print Setup...but it is temporary for that printing job, and should revert to it's default state, afterwards.---
-Printing Preferences- is where any changes you make will become the Normally used setup.
.Hope this helps
Mar 10, 2010 | HP DeskJet 932c InkJet Printer
Printer always says its offline even though its on and connected
If you are Windows XP Operating System, perform the steps below:
1. Click Start --> Printers and Fax.
2. Right click the printer icon and check the following:
a. Check whether the All-in-One is set as default printer.
b. Ensure that the there is a check mark on the "Use printer online". If you have the Use printer offline, make it online by selecting the option.
c. Ensure that there is no check mark on the Pause printing.
Check for the default printer and USe printer Online in the printers and faxes folder.
Click Start -->> Control panel -->> Hardware and sound-->> Printers-->>Change default printer. ---> Please Right Click on the printer icon which has tick mark and Select the options Use printer Online and Set as Default and also Select the option Resume printing.
Sep 30, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Colour prints coming out like draft copies - i.e. faded
Hello sir; It seem like you need to clean ink cell and print head, open top part let the cartridge move to the middle and the UNPLUG power cord you can easily to reach the ink cell to clean it.
Aug 20, 2009 | Canon PIXMA MP210 InkJet Printer
The printer works but skips labels sometimes and causes some labels to be printing on two different labels instead of one. How can I fix this?
make sure the printer is calibrated. It should feed 1 label only. If it does not default it to force a calibration. hold pause and feed while off then turn on, count to 6 and release the buttons. You also need to set label height and width in the printer driver. Both zebra designer and zebra universial. goto printers and faxes and right click on your printer driver chose properties, this opens up on the general tab.
Configuration changes for current job and Default Configuration changes
There are two places in the driver configuration to change print configuration. In Windows 98, ME, 2000 and XP, go to the "General" tab and click the "Printing Preferences..." button. This menu of configuration parameters are the settings that are in effect for the current print job. Any changes made here will only affect the current, or next, print job. These settings are initialized for each print job from the configuration defaults.
Go to the "Advanced" tab and click the "Printing Defaults..." button. The displayed configuration menu describes the default settings for the driver. These settings are used to set the initial "Printing Preferences..." for new print jobs. It is a convenient place to set parameters that seldom change in you environment. Commonly set default parameters include Printer firmware, Media Settings, Device Options, and Page Size.
On Windows NT, these menus are available when you right click on the printer name in the Printers folder. The pop-up menu contains selections for "Printer Settings" and "Default Settings" which take you to these screens in the driver.
Aug 20, 2009 | Zebra Z4M Printer
HP Laserjet 5000dn
if you using office go to page setup and select the tray(s) that you want to use for the first page and other pages ( both must be the same ) unless you only want the first page as letter head and the rest on plain paper or something along those lines ?
Also if you go into the properties of the printer and go to advanced and then click on the printing defaults button and see if the options in there are the same or different to whats in printing preferences.
If they are set to tray 1 then it will default to tray 1
Apr 13, 2009 | HP LaserJet 5000dn Printer
Can I set default printing to black and white for color laser printer?
Yes. Any printer's default options can be set as desired. Open the printer's properties (Start/Control Panel/Printers/right click the printer and left click Properties), and change the setting as you wish, then click OK. Those settings should be used each time you use the print command, unless you change the settings for that particular print job.
Hope this helps, and please rate my advice, good OR bad.
Feb 05, 2008 | Office Equipment & Supplies
HP DeskJet 3930 InkJet Printer Logo
62 people viewed this question
Ben Johnson
