Question about Radio Shack Cinego D-1000 Multimedia Projector
My cinego when it gets past hot, it turns off
  • Anonymous Nov 30, 2008
    ten minutes into watching a movie, the unit powers off.
    Problem Solver:
  • 11 Answers
There may be a problem with one of the three cooling fans no longer functioning. There are two fans on the right side (if you are looking in the same direction as the projector is projecting) and one on the left. If even one doesn't function, the unit will too quickly overheat. It must be sent in for repair, in that case.
Posted on Jul 20, 2009
My cinego d1000 overheats 5 minutes after i turn it on
Replace the heatsink and fan with a better one and make sure the proper amount of thermal paste is used (about 1 decent drop)
Thanks, Frank Z.
3868607368
http://www.attechcomputers.co.cc
Experienced techs waiting to help you with your needs.
Jun 24, 2009 | Radio Shack Cinego D-1000 Multimedia...
Cinego D-1000 no power
Make sure all the connections on the bulb are secure. Cinego wont turn on if they arent.
Aug 07, 2008 | Radio Shack Cinego D-1000 Multimedia...
Cinego turns itself off after 10 mins
Hi There
Check if your lamp has any faults like discolouration or marks on it.
Otherwise it could be Mainboard that will need repair or replacement.
Apr 16, 2008 | Radio Shack Cinego D-1000 Multimedia...
SRC button on cinego projector will not read source
Three (3) things you can try:
1. Lower down the Screen resolution of your laptop as well as the Color quality and the Screen refresh rate before doing the Fn + F5. If it works, adjust thereafter;
2. Do a soft (Factory) reset of your Cinego in the in the Management Menu (credit to Cooljazz); and/or
3. it is just "slow" in sensing the presence of a VGA source as it cycles in its selection, internal DVD, VGA, Composite Video IN. Since it does not have a manual source selection, your only option is to really wait or ...Verify that "Auto Source Select" is enabled in the Management Menu (buttons-Proj/Setup then >/9) and "tap" the "SRC" button on the projector itself to manually initiate the input/source selection.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 14, 2008 | Radio Shack Cinego D-1000 Multimedia...
CINEGO
Mine does the same thing and I just replaced the bulb after waiting almost 6 months and I purchased one directly from Radio Slack. It will turn on for about 10 seconds and then goes into shut down.....At three hundred dollars I can't see putting another bulb in, when this one has less than 50 hours on it.
What do you think
Oct 29, 2007 | Radio Shack Cinego D-1000 Multimedia...
The cinego turns off
Someone told me to change the bulb and it would fix it. I guess that is what ill have to do also.
Oct 11, 2007 | Radio Shack Cinego D-1000 Multimedia...
Cinego Projector to a laptop
Describe the connections available to you on the projector.
Jul 17, 2007 | Radio Shack Cinego D-1000 Multimedia...
I have problem wiht Cinego D-1000
While it is frozen on that "Searching" screen, hold the SRC button down on the actual projector for an extended time. Then after letting it up, hit it briefly one or two times until it finds a source. Make sure that under Projector Setup/Management/ "Auto Source Select" is checked. This brought my Cinego back from the dead.
Jan 08, 2007 | Radio Shack Cinego D-1000 Multimedia...
49 people viewed this question
Top Radio Shack Office Equipment & Supplies Experts
jasbo
jasbo
xxxxxx xxx
Pie-man
Level 1 Expert
Are you a Radio Shack Office Equipment and Supply Expert? Answer questions, earn points and help others
