Question about Koss KS3102 System
Koss KS3102 - Audio Problems
I have a Koss KS3102 and recentley the tuner and av inputs stoped working...I can turn them on but no sound comes out. What i don't understand is how i can play cd's and watch dvd's. Can anyone help me? THanks
  • mmarshall15 Dec 17, 2008
    How do I reset the KS3102 system - All of a sudden I loss the sound. I get a some sound with my DVD but not TV sound
This has happened to me twice...
While In the DVD Input mode - on the Remote Control press Number Key 7, Number Key 6, Number Key 4, Number Key 1 and Number 8 in order.
You will see a flash on your screen, then this will have reset your system. Good Luck!!!
Posted on Dec 30, 2008
I think I have had the same problem. It seems like the system resets itself randomly. I think if you first turn it on in AV-1 or AV-2 mode, then hit the menu button on the remote, then scroll to ihe 'input'option, hit that then pick 'digital'. Do this for both AV-1&2. UI hope this fixes your problem!
Posted on Jan 28, 2007
  • davaine May 15, 2011
    no it did not
SOURCE:
Everything works fine ,no audio on most channels
How do i get surround on tv channels it works on dvd setting but not tv koss model ks3102
Apr 18, 2014 | Koss KS3102 System
Sound no picture
Hi,i suggests there is a loose or broken connection on your video connections between the Koss KS3102 System dvd player and tv. Having sound suggests the optical pickup is fine. If you did not have sound then the Koss KS3102 System dvd player could have been broken. If checking the connections doesn't work, try a cleaning disk.
Take care.
Mar 25, 2011 | Koss KS3102 System
I have a Koss digital 5.1 surround sounds system and it worked perfectly when i first got it, now when i plug my PS3 system into the AV-1 ports in the back, i get video feed but no audio, what can i do to...
How is the surround sound connected through the TV?For now,you can try just setting the sound settings in the TV to stereo or SAP and see if that gives your PS3 sound because it may not support surround sound system.If not,just comment on this post and I will get an auto email that says you replied and we'll try something else. Good luck! Greg
Aug 15, 2010 | Koss KS3102 System
Cant get sound from tv on speakers.
lost remote and cant get sound from ks3102
Dec 16, 2009 | Koss KS3102 System
Won't play sound out of the AV. 1 and 2
You probably have the av inputs set to digital instead of analog. The easiest way to fix this is to turn the theater system on, turn it to one of the the inputs, then hit menu on the remote. You will cycle through some options with the right arrow until you get to "input", which will offer av 1 and av 2, you can select either one with the ok button. then you will get some more options, analog - optical - coaxial, the first one that shows up is the one you've got currently selected. unless you're using one of the other audio input formats, the system should most likely be set to analog. You will probably need to do this with both inputs.
You have to do this every time the system loses power in my experience.
Dec 29, 2008 | Koss KS3102 System
KS3102 Digital Optical Input Problem
What I did was turn on the system, don't put in any dvd in, or select an output 1 or 2. Press Menu on the remote, the display on the system display, not on tv should show Speaker, and other options. Select Input, select the one you want to use as the Optical Sound by press enter, then it will ask you on the system display input or optical sound input. Select optical input and press enter it will then say saved. You can then hit exit til goes back to where the display is back on main screen, or just wait til it exit by itself.
Jan 30, 2008 | Koss KS3102 System
Reciever Blown out?
when you select the av input on the remote,hit the menu button,it should give you a few options,select the av input you have your connections in and select analog if its analog.coax if coax.etc.i select analog because thats what i use and sound comes through after that.hope this helps,its not too detailed because this is from memory because my player just stopped working.don't know why mine stopped working.
Oct 19, 2007 | Koss KS3102 System
Koss ks3102 hts turns on but no sound
the system audio output is faulty call a tech and let them look at your set for repair.good luck
Apr 24, 2007 | Koss KS3102 System
KS3102 - Audio Input help!!
Hey I have the same home theater and experience the same audio problem from time to time. What you have to do is use the menu button on the remote and select all the speakers again. For some reason this home theater just turns off the speakers randomly from time to time. Now I'm experiencing problems with video not displaying on different inputs. I'm getting a new home theater, I think this one has had it.
Oct 04, 2006 | Koss KS3102 System
Ratoms
Had the same exact problem today. Called and e-mailed Koss today and was told player was made by Koss Electronics, not Koss headphones and that Koss Electronics went out of business. Finally just started hitting random 4 digit combinations and would you believe 0000 works? lol
Sep 18, 2006 | Koss KS3102 System
Koss KS3102 System Logo
424 people viewed this question
Top Koss Audio Players & Recorders Experts
Steve Allison
Steve Allison
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
