Question about HP Pavilion dv9000z Notebook
About hp dvd writer hp 420i
The Region setting chances of my above dvd writer has reached 5 times and is no longer now changing Region. Is there any way tht the dvd can be set as region free or it maay give me some more chances of re setting it.
Please help !
I have received other solutions from you on my Durabrand portable dvd player and it ws really nice nd solved my problem. Thnks a lot for the same.
VP Gupta
vedu6@hotmail.com
  • vedu6 Nov 21, 2008
    Please help !
    VP Gupta
    vedu6@hotmail.com
My fiancee has locked her laptop DVD system to region 3 and wants to change this back to Region 2 Please
"PROCESS IN WIN XP"
To Change the DVD SYSTEM Region open MY COMPUTER-- RIGHT CLICK TO THE DVD DRIVE ICON -- CLICK ON PROPERTIES--CLICK ON HARDWARE--HERE AGAIN SELECT THE DRIVE WHICH YOU YOU WANT TO CHANGE THE REGION AND CLICK PROPERTIES--- NOW CLICK ON DVD REGION --In this page you'll find many country name so now select yours country and click ok.
CAUTION: YOU CAN CHANGE THE REGION A LIMITED NUMBER OF TIMES. AFTER CHANGES REMAINING REACHES TO ZERO, YOU CANNOT CHANGE THE REGION EVEN IF YOU REINSTALL WINDOWS OR MOVE YOUR DVD TO DIFFERENT COMPUTER. MAXIMUM CHANGES CHANCE ARE 5 TIMES.
Jul 12, 2011 | Computers & Internet
My dvd is blocked by zoning. It doesn't play dvd any longer. It alowes to change zoning/ region only 5 times and then it lockes. What do I do?
You need to reflash the firmware in the DVD, this will reset the counter. There could also be cracked versions of the DVD firmware which will reset the counter every time you power off or even make it region free. This will invalidate your warrenty.
To find out more, search for the make of the drive followed by firmware flash region free
Feb 24, 2010 | HP Pavilion dv6000z Notebook
How can LG DVD Writer on my HCL PC be made Region Free. I am unable to play region 5 coded DVD's on PC. No options are left to change the code. BTW, why DVD players are coded with region codes??
there is a program called region free http://www.dvdidle.com/dvd-region-free.htm you can pay for it or just find a crack version via a torrent online. that will enable you to play any region dvds
Jun 28, 2009 | LG GMA-4020B Super-Multi...
Problem with LG DVD Writer GSA-4120B
The REGION code can only be changed 3 times and then it is not changeable. Do you know if it has been change 3 times yet?
Apr 13, 2009 | Computers & Internet
Dvd region
if you reinstall windows it will reset firmware...better option download and install any dvd (software "any dvd")this will allow any region to be viewed..so dont have to set region any more.
ps I wouldnt of set region code to any particular region cos of the fact you only get so many tries before it locks and sometimes its permanant if I was gonna do anything it would be to flash it with region free firmware.
Jan 06, 2009 | HP Pavilion dv6000z Notebook
Changing the DVD Region code
since the changes remaining is set to 0, sorry to say that you cna no longer change this to a different regional setting, unless you reinstall the OS,
chances are you have selected the region previously, or somebody else.
The world is split up into 8 DVD regions:
Region 1: U.S., Canada, U.S. Territories
Region 2: Japan, Europe, South Africa, and Middle East (including Egypt)
Region 3: Southeast Asia and East Asia (including Hong Kong)
Region 4: Australia, New Zealand, Pacific Islands, Central America, Mexico, South America, and the Caribbean
Region 5: Eastern Europe (Former Soviet Union), Indian subcontinent, Africa, North Korea, and Mongolia
Region 6: China
Region 7: Reserved
Region 8: Special international venues (airplanes, cruise ships, etc.)
Old DVD-ROM drives came with a firmware level RPC-1. Software protection was used to control which region is played.
New DVD-ROM drives come with a firmware level RPC-2 with hardware protection. RPC 2 drives have a 5 change limit on regions, once the counter gets to 0 your drive is permanently locked to the last region it was set to. Even if you reformat or move the drive to another system it will still be locked to the last region. There are ways to get around it, some models have resetting tools made by 3rd parties to reset the change limit back to 5 and some also have firmware patches to remove the region lock.
How to bypass DVD region code protection ?
As we've said, a lot of newer drives are RPC-2 drives these days. Some of these drives don't allow raw access to the drive until the drive firmware has done a regioncheck. But some RPC-2 drives DO allow raw access, so in some cases it is quite possible to use a special software to bypass the protection:
The first solution is free VideoLAN player: click here to download VideoLAN. It might take a long time to initialize DVD. So just pop the disc in your drive and try it out, while you get a coffee.
The second solution is free Remote Selector tool: click here to download Remote Selector. Launch remselec22.exe file. Click Control tab. Choose Enabled, and check all options Region Free, Disable Macrovision, Disable User Prohibition as shown below:
or you can install one of this program:
The region can only be changed five times, before its set permanently.
In WinDVD: if a DVD from a region different than the default one is tried to be played, the dialog box for changing the DVD region code should appear. If that dialog box do not appear, check the region code set in the software:
Click Start, All Programs, Intervideo Win DVD, and Intervideo Win DVD.
Right-click the Win DVD window and select Setup or Properties.
Click the Region tab and check the region code selected.
If there is a 0 in the Changes Until Permanent field, the DVD region code will not be able to be changed again.
If a number from 1 to 4 appears in the Changes Until Permanent field, add a mark in the checkbox of the desired region and click OK. The new region will be set up.
In PowerDVD: the first time you insert a DVD title, to be played on PowerDVD, a small dialogue box will appear. It will set the region code to match that of the DVD title you wish to play. After this the program will be set. However, if you have a region free DVD-ROM drive, you have the option of playing DVD titles from different regions. PowerDVD will allow you to change the region code setting up to five times, and then it will be locked on the region you have listed on your fifth and last change. At that point you will only be allowed to watch DVD titles from that region. To change the region code, from the original setting, just insert the DVD title in your DVD-ROM drive and run PowerDVD. When the software recognizes that the disc is from a different region than what was previously set, a dialogue box will appear. For this example, the Current Region is Region 1. After changing from one region to another, I will have four changes left. The program detected the disc I inserted was from Region 2, so it selected this option. Once I click OK the Current Region will be changed to Region 2 and the DVD title will play.
hope this helps dont forget to mark my solution pls
Aug 07, 2008 | Microsoft Windows XP Professional With...
My Philips DVD SDVD8441 player will not play Region 2 dvd's. I have used up the 3 chances I had to change the region. Is there any way I can unlock it?
Most DVD players have the region settings stored in a type of RAM. The firmware allows only a certain number of region changes before you can no longer make any changes. Unless you can hack the main board to somehow alter the firmware, there is no way to get more region changes. This is by design and relates to international copyright laws.
Mar 28, 2008 | Televison & Video
Trying to change region to 2 but it has locked me out is there a code i need
you can only change ur region codes a few times then ur drive becomes locked to the last reset.then youll need to reflash ur drive with firmware.theres a program u can get(free)called any dvd which gets around region codes.
I personally would reflash firmware.this sets drive to "0" which is all regions.
simple precedure.locate firmware,download it,write it to a cd,insert cd which then reflashes auto.remove cd.
Mar 26, 2008 | HP Pavilion dv4000 Notebook
DVD Writer does not respond when DVD movies are inserted..
YOU WILL PROBABLY CHANE THE REGION SETTING TO GET THIS DRIVE TO PLAY THE DVDS FROM Canada
Jan 16, 2008 | LG (GSA-4167B) DVD RW Dual Layer Burner
HP Pavilion dv9000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
