Question about GE WBSR3140DW Top Load Washer
Washer machine not draining water
Washer will wash/agitate, but when it reaches the rinse/spin cycle it just hums and will not spin and drain out the water.
  • 7 more comments
  • mariehmh Nov 26, 2008
    My washing machine is doing the same thing and the tub seems really loose also...looser than what it is supposed to be.
  • charles s Dec 03, 2008
    me to whaqt did you do.help?
  • fuzzeebear Dec 19, 2008
    washer will fill with water ,timer will go threw cycles but do nothing , then it drains and not even spin
  • rdfowlerjr Dec 21, 2008
    washing machine does not drain or soin out water
  • ritakhan2002 Dec 21, 2008
    I have a GE toploader and the water is not ejecting.
  • Anonymous Jan 10, 2009
    washer fills but wont go into rinse cycle it turns off
  • Anonymous Jan 19, 2009
    the water will not drain but it will fill
  • drwej Feb 05, 2009
    I have the GE 315 model and I have the same exact problem. This problem just occured on Sunday while washing a medium load of infant clothing. The machine will fill and wash all load levels. When it gets to the rinse cycle, it doesn't drain the water. It clicks and hums like is is trying to but it just won't do it.
    I took my shop vac and emptied the water. Once this was done, the rinse and spin cycle worked immediately with no problem. Remember, this is only after draining the water.
    Before washing clothes again, I decided to run the machine without any clothes. I had no luck. The machine is stuck again at the rinse cycle and will not drain or spin. I called GE and they are coming out on Monday with their expensive fees. I would like to resolve this before Monday.
    Additionally, I have infant clothes that require a machine to get the poop out.
  • Tracie L
    Tracie L Feb 24, 2009
    GE Profile Washer, it will wash the clothes and rinse them but will not spin them. It started gradually and got worse would have a burning sent now it will not spin at all
    Problem Solver:
The GE serviceman repaired my machine approximately 40 minutes. I paid $189 for the issue to be resolved in 5 minutes. This is no exaggeration.
The serviceman arrived at 2:50pm and finished at 2:55pm. It took another 5 minutes for me to write the check and he was gone.
My recommendation is...
- Purchase the GE service plan prior to calling GE to repair the service. A 1-Year service plan is $40 and 2-Year is $75. It costs $99 just for the serviceman to come to your house.
- Fix the issue yourself. Of course, this only applies if you are handy. I am handy and I tried to fix the problem myself. I just couldn't figure out the location of the access panel.
Solution...
The access panel is on the front. This can be removed in less than 20 seconds. The notches on the access panel is in line with the edging of the washing machine door. To remove, slide in a flat object like a flat-head screwdriver. Wiggle up and down on each side until door comes loose. Lift up door and set aside.
The water pump is on the lower right in the front of the washing machine. If your wash machine has any water in it, you want to use a shop vac to empty it out. The serviceman used a clamp to stop the water from running down. A little water still came out but he used my shop vac to get it up. It was less than a cup full and I had a 1/2 tub of water. Afterwards, he stuck his fingers in the water pump and pulled out the item that was blocking the pump.
Guess what was blocking the pump? The item was my two-month old daughter's sock. He recommends using a washing bag.
Remember this solution is for GE 315 model that is a top load washer. This will most likely work with similar models. I knew my water pump was still working because it hummed during the rinse and spin cycles.
Good luck and I hope this saves you $189 or any other fees.
Posted on Feb 09, 2009
  • 3 Answers
The problem is easy to fix, take the front cover of your washing machine off, bottom right is the pump. make sure you have all the water u can get out of it out. take the drain hose loose from the pump. ( the drain hose that connects to the tub, not the out going drain hose.) it might be stopped up in the fins of the pump. that is what happened to mine.....hole in a pillow let the stuffing loose in the washer and clogged up my pump at the fin. thanx roger
Posted on Feb 10, 2009
  • rdfowlerjr Feb 10, 2009
    sry i could not help u out before the serviceman got there.
It is the water pump
Posted on Feb 06, 2009
Washing machine not draining water
Posted on Nov 25, 2008
Why won't maytag MVWC6ESW go into rinse cycle?
The cold water valve screen in the washer water valve is clogged. You have grit in your water and it will continue to happen until you get a filter system installed on to it.
Mar 18, 2016 | Maytag MVWC6ESWW Washer
My Kenmore washer (series 90) stopped working in between the rinse and spin cycles. It will not drain (half full as we speak), agitate or spin. It will fill with water but once it reaches the proper water...
Something stuck in Pump. Pump on your model is driven by washer motor, so if Pump can't turn, motor can't work and will hum until it overheats and shuts down.
Sep 28, 2017 | Washing Machines
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Top load washer won't go through cycle
modle problem here its the main board common fault with this model good luck
Mar 26, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
It wont complete cycle and empty the water just hums for a while and then turns its self off
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Kicking out water during wash cycle - spin instead of agitation
Try these
  1. Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  2. The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  3. Check the drain control lever
  4. Test the drain control coils
  5. Check the cam bar
pls rate my suggestion..
Jul 19, 2009 | Maytag LSE7806A Top Load Stacked...
Washer will hum and will not drain water out!
You will have to either look under the machine or take the back off.
You will see the big motor which does the washing.
You will also see a small motor which drains the machine.
Disconnect the power supply and remove the pipes from the small motor.
It could be blocked up from congealed washing powder.
Or something may have blocked the pipe from the drum to the drain motor.
If it all looks ok and still doesn`t work, then the motor has siezed.
Very easy to replace
good luck
Jan 25, 2009 | GE WBSR3140DW Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
GE WBSR3140DW Top Load Washer Logo
718 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
