Question about Tomtom ONE GPS Receiver
GPS Won't Turn On
Our TomTom has been working fine for the past four months. However, last week I arrived at a destination and when I was ready to return home, the GPS would not turn on. When I have it plugged into the car, the green light at the top next to the on/off button is illuminated, but there is nothing on the screen. I've tried the reset button, but that did not work. I'm hoping there's an easier solution than sending it in for repairs which could take weeks. Any ideas? Could it be the battery? Thanks!
  • 45 more comments
  • hollybud Nov 03, 2007
    My problem is exactly the same as this one. How do we replace the chips, do we have to send the tomtom away for repair, and is it very expensive? Sandy
  • shania Nov 09, 2007
    I have the same problem. Don't know what to do and how much it will cost to repair.
  • Anonymous Nov 25, 2007
    green light illuminated but screen blank, Checked the card is in place
    my tom
  • Anonymous Dec 04, 2007
    gps was working fine and all of a sudden wooud not turn on.
  • welliesmum Dec 09, 2007
    Had the same 'green light on' problem after leaving unit in sub zero car overnight. Two weeks later, plugged back in, just before throwing unit away & it works!!!!
  • humdinger Dec 11, 2007
    press turn on button nothing comes up had a journey withit turned off with charging at the same time green light was on so the battery was being charged help mike
  • Anonymous Dec 24, 2007
    This is my 6th. gps tomtom one 3rd. edition. One would only boot up with a blank white screen, one other will not boot at all. Four others are wrapped under the Xmas. tree and i know i will be taking them back. No more tomtom's for me. I tried everything possible on these units to no avail.
  • Anonymous Dec 30, 2007
    the tomtom onexl won"t turn on
  • Anonymous Jan 29, 2008
    Our TomTom One will not show display. Green light illuminates when pugged in to car. but their is no display. We have tried charging it with our
    computer but to no avail. Interestingly I bought one for my wife too and wouldn't you know. She has the same problem with hers. Any Suggestions?
  • Meddie Feb 22, 2008
    TomTom ONE 3rd edition. Only boots up to the screen showing hands on a steering wheel, then immediately turns off. Have fully charged the battery, tried resetting from the button on the base, but no luck. It happened after I had tried connecting to the PC and updating, but kept getting error messages that a file was missing. It's only three months old and has been used three times.
  • pdoccers Mar 20, 2008
    I switched off my Tom Tom But when I went to turn it back on again it would not come on. It is fully charged by a mains charger & will on the charger the green light is on. When disconnected from the charger the green light is off & the reset facility has not made any difference.
  • sikkelphoto Mar 31, 2008
    I also plugged it into a different plug, but the same problem-both lights on, but cannot turn it on.
  • Anonymous Apr 21, 2008
    green light comes on but screen does not
  • Anonymous May 19, 2008
    tom tom will not turn on and green light on charger, I left tom tom to charge for add'l 1/2 hr in car and it will still not turn on also rest and thatt did not work either.
  • Anonymous May 23, 2008
    same problem
  • poppygirl May 23, 2008
    my tomtom one won't turn on. The green charge light is on but that's it?
    Can you help
  • Anonymous Jun 07, 2008
    tom tom will not turn on. green light is on but screen is blank.
    I have held off on switch down for several seconds.. nothing
  • smiffyrebel Jun 10, 2008
    turned TomTom off 2 days ago but when I tried to use it this morning the TomTom go 520 won't turn on have had the unit in the home dock charging for over 2 hours as suggested also tried resetting twice but still the unit will not turn on NOTE this unit is only a couple of weeks old and from the amount of people having the same problem it seems very unreliable.
  • Brian Edmundson Jun 15, 2008
    The power up problem is caused by the car charger going faulty and applying too higher voltage to the unit. This is usually caused by the white sense wire becoming broken due to frequent use of the charger. The fix to the charger is simple but the TomTom is 'DEAD'. Green light on - so the battery is OK but the unit will not turn on.
    I have stripped the unit down since it is out of warrenty, and found a blown component - D8 but without a circuit diagram I can go no further.
    Can anyone out there help?? I am an electronics engineer so am OK with all the techy stuff.
  • Anonymous Jun 21, 2008
    GPS will not turn on
  • joyceowolabi Jun 23, 2008
    my tomtom one does not switch back on. I've tired charging it all night,removing the sd card nothing seems to work. Don't know why? Pls help
  • pyroman251 Jul 31, 2008
    Same problem here, had it running for about 20 minutes for set up. Went to use it this morning, does not power up. Green light comes on, that's it. Nothing else. What a waste of $$$ now I have to go through the whole return process.
  • Anonymous Aug 25, 2008
    tomtom comes on with hr glass thats it
  • migw54 Aug 27, 2008
    Green light comes on when plugged into car but will not start up on pressing 'on' button. Totally dead if not plugged into car. Help!
  • Anonymous Oct 11, 2008
    Green light will come on, on the cigarette lighter adapter but gps won't come on.  Will not work with fresh batteries either.
  • bill7154 Nov 01, 2008
    I have a Tomtom ONE XL that just stopped working. It boots up and loads my "start window" but goes no further and will not shut down without pushing the reset button.
    I uploaded the updates and applications from the website. As soon as I locate the install CDs, I'm going to try that.
    Any other suggestions? Headed on a trip on 12 days and really want to have this thing working. GRRRRR
  • rhfrick123 Nov 02, 2008
    I have the same problem can amyone help?
  • ve3znq Nov 12, 2008
    Nextar I4-BC GPS won't power up
  • dmorganti Dec 04, 2008
    My tom tom one will not turn on either, the green light comes on when its plugged in but the screen wont come on when you press the button
  • HEMACH Dec 05, 2008
    • WON,T TURN ON
  • Anonymous Dec 16, 2008
    Tom Tom charges but will not turn on. I also tried the reset button on the buttom with no result.
    Tom Tom charges but will not turn on. Reset button does not do anything. The unit has been left unplugged for some time.
  • dewet123 Dec 25, 2008
    Hi i just updated my tom tom and after the updates it doesnt want to switch back on. Its like it stolled.
  • Anonymous Jan 07, 2009
    i have a tom tom one xl i put a sd memory card into it and now nothing is working it wont turn on please help me
  • tavolgenau Jan 30, 2009
    I have a tom tom one XL which will no longer turn on. It would work then strangely shut down. No it won't do anything. I've tried charging it for long hours at a time in my car, the green light was lit, but there was no improvements.
  • Anonymous Jan 31, 2009
    I have a green light on but m tom tom wont switch on
  • k karimi Mar 01, 2009
    Every on should call Tomtom customer care and strongly lodge their complaints. This is a very expensive device bought by our hard earned money.
    The number is 08451610009.
    Man it just simply shut off. the green light comes on to show it is charging but I assume it isn't as usually if the battery is charging it gets a bit warm. Mine remains cool. I think the green light has no purpose than to tell that the cable is live.
    I think it is an inherrent problem with this device and the company should own up the responsibility.
  • Anonymous Mar 18, 2009
    EDMO117,
    I have a burnt component on my Tom Tom one New Ed. its labeled D5 but could not figure the value out to replace.
  • tomwestly Mar 23, 2009
    same
  • Anonymous Apr 22, 2009
    tom tom will not work at all tried to reset and still nothing
  • Anonymous Apr 26, 2009
    Me too AGGGHH! Need my Tomtom to work desperately! Can't turn it on. Charged it and green light comes on as with other but cannot get it working. I agree we need a petition - let all get together and complain!
  • Anonymous Apr 27, 2009
    green light comes on but power button and reset button does nothing. The computer doesn't even see it as a USB device anymore.
  • Anonymous May 04, 2009
    My Tom Tom One GPS receiver will not turn on or off, has a continuous vertical test pattern.
  • Anonymous May 07, 2009
    Charged for two hours, but will not turn on, even when still connected to power supply. Reset button makes no difference. This happened after I connected it online to try to fix an earlier problem where the screen froze on startup.
  • Anonymous May 10, 2009
    Looks Tomtom is not a good product,I purchased TomTom One 3 years back for $350 i had so many probs this is not a good GPS to buy.
  • andy kissan May 11, 2010
    hi can you connect it to your computer by the usb cable if you can press the power button and hold it hard until you see somthing and tell me wghat you see
Amazing what reading through the support page at TOMTOM reveals... I have the XL so no SD card to remove, but the support page explains that a hard reset by holding the power button takes 15 SECONDS. That's actually a really long time if you watch a clock. I pressed it and waited it out, and it worked. Powered right up. Not sure if I lost all my favorites and stuff but I have them backed up using TomTom Home anyway....
Posted on Aug 22, 2010
  • 5 Answers
I have managed to fix my TomTom one.
The problem was two fold. First the diode D8 was blown and also the power supply chip was blown.
It is a tricky job, using surface mounted components so should not be attempted by a novice but I managed it.
I have a full set of photos etc if anyone cares to try it. I figured - NOTHING to loose!! so what the heck and just went for it. Taking it apart was fun! The surface mounted IC was easy to obtain and the total cost was about £10 plus 4 hours panic labour. If anyone wants the info just let me know and I will send the photos - but no promises - it worked for me.
Posted on Aug 14, 2008
My Tomtom One version 1 (purchased in Jluy 2007) has had the problem of going blank on three occasions now. Recharging in car or via the mains charger for several hours does not solve the problem. Holding down the switch firmly for brief or long periods ahcieves nothing. I recalled hearing that freezing (literally) some electronic equipment can sove such problems and had already successfully brought a digital alarm clock back to life by putting it in the freezer. So with my Tomtom out of guarantee I wrapped it in a couple of plastic bags and put it in the deep freeze compartment of a rifrigerator over night. Next day tokk it out, allowed a couple of hours to thaw out and then recharged for an hour before switching on. Instant revival! I have now repeated this treatment on three occasions when the unit packed in and each time it has worked perfectly. Of course the Tomtom handbook warns that the untit must not be exposed to extremes of high or low temperature; but I assure you my treatment worked.
Posted on Jun 16, 2008
I figured out this ongoing problem. I purchased my TomTom One second edition 1/20/07 for $395. I was 30 days past my warranty and had the problem of unit not turning on. Green light came on when charged.
I opened my unit up and found the sw2 micro switch broken. If you press too hard on the on/off button, this will eventually happen.
I couldn't find a replacement switch so I wired my own switch and it works now.
Posted on Mar 10, 2009
Ok...I have had this problem with my GO 510.  My solution has been to take the smart card out. Hit the reset button, plug it back in, hold down the "on" button, and it usually turns back on. Then I put the smart card back in.
Hope it works for you.
Posted on Mar 07, 2009
I dont have a solution but I have the same exact problem as solution number 3...whats up with this upgrade???
Posted on Nov 29, 2007
  • ewingqb12 Nov 29, 2007
    i had the exact same problem as solution number 3...whats up with this update???
  • Ian Firth
    Ian Firth Oct 25, 2010
    spent ages messing about and here is the solution but you have to follow this to the letter
    1) remove sd card
    2) with no power connected press reset for 15 seconds
    3) connect power source so green light comes on
    4) now hold power button and wait for it to fire (do not press power button before connecting power or it wont jolt in)
    5) put sd card back in
    good luck
I start my gps,and stop it again,and after that the gps never start again.I have a gps Tomtom ONE GPS Receiver........Johnny.
Posted on May 06, 2008
  • mgyarbrough Feb 03, 2011
    I have the same problem.. Green light is on but will not turn on... Pc of Junk !!!!
Hey everyone, I'm having the same problem. Here's my story though, I have a TomTom One 3rd edition, so no SD card. I bought it and received it. Plugged it into the wall using my BlackBerry charger, charged it up worked fine. Was driving in the car with it worked great, battery started to get low, so I plugged the TomTom car charger into the car and then into the TomTom while it was on. The unit immediately shut off and wouldn't come back on. The green light would come on, but plugging it into the wall or computer did nothing. Called TomTom sent it back got a replacement. Drove a few hours with it plugged into the car using my BlackBerry charger incase the TomTom one was faulty. Worked for one day. Next day battery was low so I plugged it into the car while it was on, and boom died again. Was so mad I threw it in my desk at work and left it there for a few weeks. Finally called TomTom to get it replaced, and for fun while I was on the phone I plugged it into my Blackberry charger, hit power and it immediately turned on! Felt so stupid so figured it wasn't dead. Went to my car, plugged it into the car charger while it was OFF incase having it on caused the problem even though TomTom said it wouldn't. Surprise surprise, unit wouldn't turn on and it's now dead again. I don't understand how it could just come on after 3 weeks being dead in my drawer at work, so can't be a blown component. Going to try someones freezer trick tonight since I'm at a loss, but getting really sick of this thing. Happened both times in the same car, but different chargers. I charge my BlackBerry all the time though works fine, so I don't think my car is doing it, really have no idea...
Posted on Aug 25, 2008
Had this problem after upgradeing software and maps, it would only turn on if i removed sd card, then powered on, then put back in sd card. Resolution was to put card in pc, delete trashes folder, then whilst the card it out of the tom tom, hard reset it by putting pin in hole by card slot, whilst holding power button - then i put card back in when it came on - no problems now - Hope this helps
Posted on Apr 15, 2008
  • Ian Firth
    i was a wagon driver for years and used my tomtom but i allways took my truckers map with me as well because they are totally unpredictable and work when they want and will let you down at the worst time........................should of been recalled and fixed............but they aint bothered cos they got ya money
    Problem Solver:
  • 7 Answers
Take out the SD card and pop it into a card reader. Do not run the Tomtom home software, just open the card to browse files.
Remove (or backup) the folder ".Trashes" then stop the card, remove, replace into the tomtom and after it re-boots, turn off and on, and hey presto, it should all be back to normal!
Worked for me anyway!
Posted on Dec 29, 2007
    Problem Solver:
I bought a Tomtom ONE XL not working for ten dollars and I found the problem I opened this one up and found the power switch is broken the thing is now the soldering it bck in place can be done with a magnifing glass and plenty of light. So next time you power it up just lightly press the power button the switch itself is very fragile.
Posted on Apr 26, 2012
The green light of death tomtom one v4.
this problem is a hardware..i have be searching around for the solution for ages.i came across a chap in birmingham who fixed the fault in 2 hours and only charged me 25 pounds..amazing guy!..he has a mobilephone repair shop.his contact details are 01217727521.i hope this will be of help
Posted on Oct 11, 2010
I don't have a solution but I do have the same problem my switch is broken inside zachgabai solution # 14 how did you wire your own switch? what swicth did you use to do this with? can you explain how you did this?
would greatly appreciate if any one could advise how to do this. Thanks.
Posted on Dec 04, 2009
Number 10 solution worked for me.
Are you guys by any chance using a Mac? I ask because mine had the exact same problem after I ran the first update from my macBook. I couldn't turn it on, unless I popped the sd card out and back again. But when I connected to an Windows machine, I saw some special mac folders like .Trash and things like that, if you use a mac, you know what I mean. I removed those and it started working properly again. Let me know if it helps.
Posted on Dec 06, 2007
Gigatech:
Had the same problem after update online. Try holding the reset button for 15 seconds the try to power up unit. Make sure your battery is fully charged. I connected the unit to my computer for two hours to make sure the unit was charged first. Hope this helps.
  • Carolyn Ryan Sep 28, 2011
    Thank you. This worked...I had to hold the on/off button down for way more than 15 seconds, but it did finally start up. I also made sure it was fully charged before trying. what had happened was that the fuse for lighter socket blew in car and battery in TOMTOM was completely used up. There must be some kind of circuit breaker in the device to protect it from being drained completely....just a thought....
I had the same problem after I upgraded to the latest software version from the website. I find that popping the SD card out and then back in gets the power to come on, but you have to do it every time. Working for now.
Posted on Nov 25, 2007
Usually in such case the problem is in voltage converter chips inside tomtom, TPS62000 and LTC3411, they needs replacing.
Posted on Feb 04, 2007
I had the SD card problem as well with ver 7.162 as solution #4.
difference is mine was connected to a linux comp....
I think that's the problem! Well spotted, these folders keep the tomtom from booting.
Ironically, Ithink the TT OS is some kind of linux !!
Posted on Dec 13, 2007
3 Suggested Answers
SOURCE:
RAC_ICS
  • 143 Answers
SOURCE: GPS Won't Turn On
I suggest any unit under warranty to be returned to its supplier or if they will not help, contact tomtom directly!
http://www.tomtom.com/support/index.php?Lid=1
Download the latest updates from tomtom.
Posted on Dec 15, 2007
  • 6 Answers
dude check it the car charger really isnt a chargers. what! i kno i kno. the '' proper" way of chargin ur battery is thru the computer or u can purchase a a/c to usb adapter and charge it on the wall but the car charger is a trickle charge as long as the green light is coming on that means that there is power going to it and support is going to just tell ur charge the batter the right way over and over again try charging on the computer for about four hrs then see whats up if its still not working then call tech support and make sure u tell them that u tried charging it on the computer for four hrs
Posted on Jan 21, 2009
Does not find GPS signal in Spain
It may help if you regularly get the latest satellite positions (for the next 7 days) - QuickGPSfix data (via TomTom HOME).
Jun 19, 2013 | Tomtom GO 700 GPS Receiver
My newly bought tomtom one 140s has given me inaccurate directions.the location was on the leftside of the street but the gps pointing the opposite ,and one time i arrived already to my destination but the...
This is a very common problem with ANY brand of GPS. Even if you have the most current and updated map, there are some mistakes in the GPS addresses. It should only happen occasionally, maybe once every couple of weeks. As I said before, it's not unheard of for TomTom, Garmin, Magellan or any bradn of GPS
Mar 20, 2010 | Tomtom ONE GPS Receiver
Tomtom One not doesn't calculate arrival time correctly.
thats normal- estimate is always higher the units go by speed limits and you shave time off trip units adjust accordingly
May 18, 2017 | Tomtom One XL GPS Receiver
GPS Won't Turn On
Jan 19, 2009 | Tomtom ONE GPS Receiver
In the last week I have bought 2 tomtom ones. one was a 125 the other a 130. Both have given me the same problem. On arrival of my destination it is taking me anywhere from 1/8 mile to 1/2 mile away from...
First thing to check is make sure your maps are up to date. Run your device through TomTom Home and make the proper updates. 1/2 a mile away seems too far of a distance to be off by. I've taken trips on my TomTom and even other brands for that matter, and it is not unusual to be slightly off or announce the arrival a few hundred feet too early. If it is navigating you to the wrong street, you need to update your maps. The maps are very reliable on my device so use that as a starting point.
Dec 06, 2008 | Tomtom ONE 130 GPS Receiver
I purchased my TomTom One XL.S4Aug08. I am finding that the unit will not hold a charge. I took a trip some 200 miles away gtom home and plugged the unit into the 12 volt and system. It work OK while...
I am sending the tomtom back to the manufacturer. I have only had it for two (2) months. I didn't feel that I should have to pay to have it fixed. thanks for your reply.
Bob
Sep 17, 2008 | Tomtom ONE GPS Receiver
GPS Won't Turn On
www.batteryship.com
look up tomtom 510 - or whatever model you have
Order the battery..........comes with manual and tools to fix it
only 20.95
it works
cheaper than sending it in!!!!!!
These are genuine replacement parts!!
Laura
Jan 30, 2008 | Tomtom GO 510 GPS Receiver
My garmin
it may be trying to get you back on track or if when turning it on it trys to take you a previously sort location you may have set this as your home. make sure your actual home address is stored as your home address on the gps unit.
Jan 10, 2008 | Tomtom GO 910 GPS Receiver
GPS Won't Turn On
If its a battery problem the unit still works while charging!
If not it sounds like the OS or SD card has become corrupt.
you'll have to wipe both clean & start again...
tomtom will talk you through this either via an email or on the phone.
http://www.tomtom.com/support/support.php?ID=2
Dec 11, 2007 | Tomtom ONE GPS Receiver
GPS Won't Turn On
Dec 03, 2007 | Tomtom GO 300 GPS Receiver
Tomtom ONE GPS Receiver Logo
22,162 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
