Question about Microwave Ovens
Light went out in Amana Radarange Microwave.
Can not find where to change a bulb! Model # is RRL-9TC. Model code 26C49. Serial # is C00052314907. Came with the house we bought last Dec.'07. It is a counter-top model, and a note says it was bought in 1984. Still runs great. Just miss the interior light that went out today.
  • margbrown1 Nov 22, 2008
    Discovered book w/ description that bulb is located in a panel on the back of the microwave. Since the microwave is in a lower cabinet and is very heavy, I have not taken it out to see where the cover is, but was told what size bulb to order, and have ordered the bulb. So hopefully when it comes, it will be easy to install!? Thanks for your help. Sorry to take up your time but may check your website if another problem develops.
  • Microwave Ovens Master
  • 9,098 Answers
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Posted on Nov 21, 2008
Microwave light socket shorted out
every thing all right accept working heater both heater tube doesn't light or no power on it
Nov 14, 2013 | Amana Radarange Microwave Oven
Ragarange light bulb
If Amana call customer service Or look with Google for a possible You Tube video online for replacement of the bulb etc.
Dec 10, 2012 | Amana Radarange Microwave Oven
I replaced the cooktop lightbulb in my Radarange Amana Mircowave. When I turned the light on there was a loud pop and the breaker flipped. I took the bulb back out(which was now blown) and flipped the...
Yes there are fuses inside.
There are lethal voltages within Microwave ovens that can stay charged up for many days. If you do not understand the hazards, get it repaired by a qualified electrician.
Dec 02, 2017 | Amana Radarange Microwave Oven
We have an older Radarange over-stove microwave oven with touch pad controls. Whenever I boil something without a lid for a longer period, some of the buttons stop working. Usually, they begin working...
Call Amana customer service. Microwave ovens should be able to handle the high humidity you are talking about.
Here's the contact information:
Have your complete model number ready. You can find your model number and serial number on the label located on the upper or lower
front facing of the microwave oven opening, behind the door.
For assistance or service, call 1-800-843-0304.
If you need further assistance, you can write to Amana with any questions or concerns at:
Amana Brand Home Appliances
Customer eXperience Center
553 Benson Road
Benton Harbor, MI 49022-2692
Aug 05, 2009 | Amana Radarange Microwave Oven
Moved oven. Keypad can not set time. Amana RRL 9TC
After so many years, the electrolytic filter capacitors dry out and these become more susceptible to disruptions and glitches.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, I would say your control unit (called the "net module") needs to be repaired or replaced.
If this item is available anywhere, it may take several weeks to get and will likely run well over $150.00.
If you decide to look for parts, the proper model number format is RRL-9TC and it also has one of four manufacturer numbers on its tag: P7553302M, P7553303M, P7553304M, or P7553306M.
Be sure to have both numbers handy.
The original part numbers for the net module seem to have been R0163049 and then R163079A.
Good luck.
Feb 02, 2009 | Amana AMV5164 Microwave Oven
Need to change bulb inside Amana radarange RR1220
There is an access / cover panel on the back of the oven.
It's shown in the exploded view here.
Please unplug the oven from the wall first.
Then use a 1/4" nut driver or socket to remove the screw in the end of the lamp cover.
The bulb is behind the cover, and should be readily available at grocery stores, home improvement centers, hardware stores and big box stores like Wal-Mart.
Dec 01, 2008 | Amana Radarange Microwave Oven
Instruction manual for 1986 Amana Radarange microwave
I think it will use a standard generic probe for the Accu-Temp. Sorry I couldn't help. Take care.
Jan 14, 2008 | Microwave Ovens
Amana Radarange Microwave/Convection over the stove
what is the model number of your radarange? it should be found inside the microwave on the rim.
Nov 21, 2007 | Microwave Ovens
Microwave Ovens Logo
155 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
