Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
Freezer is fine. Fridgerator portion does not cool .
Freezer (bottom) is fine (-5 deg) Refrigterator does not cool (72 deg)
Compressor noise level is normal. No abnormal sounds
Kenmore: Model: 596 76509500
Serial: 10309306GL
  • Anonymous Dec 09, 2008
    I have the same problem with my frig/freezer, cold in the freezer and notgetting warmer in the frig.what does a evaporator fan motor cost? How long does it take to install?
    Scholar:
  • 62 Answers
The most likely cause is a bad evaperator fan motor. It is mounted in the freezer section. It blows the air up to the ref section. Open the freezer door and listen to see if you hear any fan noise.
Posted on Dec 06, 2008
Whirpool gx2fhdxvy04 coils entirely forze over. thawed removed ice cleaned all drains and lines. pluged back in is cooling fine, but compressor has been running now continually all after noon. Freezer 5...
It is normal for the fridge to take a while to recover the cold temps after a manual defrost but if you did not test or replace the 12729128 Defrost Heater and the W10165425 Defrost Thermostat you will need to do the manual defrost again until you do replace, Thanks John Tripp Appliance 911
Feb 17, 2014 | Whirlpool GX2FHDXVY Energy Star 22 Cu. Ft....
KENMORE TRIO 2004 59675523400 REEFER/FREEZER NOT COOLING
it should not be the compressor as the bottom is only not cooling.
Jun 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
The fridgerator won't get cool. Freezer works just fine. But the fridgerator stopped working. The model number is LSC27931ST
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 05, 2011 | LG Refrigerators
I have a Kenmore 596.72219200, refridge/bottom freezer that heats up to 50 deg then goes back to normal cooling. This is for both refrig/freezer. The blower fans run but not cooling . Any ideas before I...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 12, 2011 | Refrigerators
Why does the freezer portion temp indicator bounces between 0 and -12 degrees periodically.
Temps should fluctuate, as the refrigerator will go into a defrost mode every so often. Some models will go into defrost mode after you open the freezer door X amount of times, say 6. So every 6th time you open the door it will go into defrost. Then some models go every 4 to 6 hours depending on settings. Then also, it is normal due to temp control. Temp setting is -10 The fridge will run to that temp setting, -10 and shut off the compressor at -10 but due to pressures it will still cool a bit to your -12. it will stay in this off mode until the temp rises 8 to 10 degs. then kicks back on the compressor. Again due to pressures it may take the system 2 - 3 degs to catch back up and start cooling again. But you maintain average temp of -5 to -6 which is great for frozen food and saves a bit of electricity. As long as the door seals are in good shape and you clean the coils underneath once twice a year it should work fine for many years. Then lastly It may have a lag in the thermostat meaning it has gotten week or going bad. Hope this helps.
Jan 10, 2011 | Frigidaire FRS3R5EMB Side by Side...
Refrig/bottom freezer not cooling, fan running, lights running, controls working fine, every 5 minutes a humming, then a clicking....cleaned condensor fans and cleaned condensor coils by vacuuming My...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Aug 30, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Top Freezer won't freeze--blows 50 Degrees constantly!!!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check the fans especially the condenser fan. the noise you hear is probably the klixon cycling because the compressor is hot. You can put a fan blowing on the condenser coil and see if this helps.
Good Luck,
Gilsh
Nov 28, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
My ge profile fridge won't stay cold. the fridge is at 45 deg.
First things first - pull the fridge/freezer out from the wall, and look at the bottom.  You should see a metal coil somewhere - it probably needs to be cleaned.  Next, somewhere around the compressor (the big bulky thing in the bottom of the freezer) should be a fan blowing on the coil - make sure it is running.  That MIGHT have been the buzzing noise you describe - dirt on the fan blades or the fan hitting something.  Additionally, you can check the fan on the inside of the freezer - if it is stuck and/or not working, the air won't circulate properly, and you'll get pockets of different temperatures in your freezer.
Best of luck!
May 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
May 17, 2009 | Samsung Refrigerators
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
594 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
