Question about Kenwood KAC-8101D Car Audio Amplifier
Amp on but no bass
I have a kenwood KAC-8101D amp and about 2 weeks ago the bass started to cut out but i though it was because i was using a conver box for the rca's so i found the deck i wanted and i installed it and it started doing the same thing excep now i dont have any bass at all before it would cut out for few seconds and come back but now nothing the power light is on and i rewired the subs from the box out and i wanted to know if my amp is toast because if it is im just going to get a new one because its under warantee. thanks in advance
  • Adam Daniele
    Adam Daniele Dec 19, 2006
    thanks for the tip but what has me puzzled is that when the amp did cut back in the subs sounded fine no distortion thats y i dont think its a sub problem and the oter reason is because the power light is on for the amp thats why i dont think its a ground issue... any other suggestions would be greatly but im going to check the ground wire but i dont have a multimeter.. but when i get one i am suppost to set it to ohms correct .. if im wrong please let me know thanks alot
  • Adam Daniele
    Adam Daniele Dec 20, 2006
    Thanks for the tip but i checked the ground yesterday and it was good and its in a spot where it cant rust. and no the head lights dont dim when the bass hits.. but now the bass isent working at all its completely dead but the power light is still on that why im thinking i blew the channel but i wanna know how i can test it for sure because if it is the problem then i will just return the amp so thanks again
    Scholar:
  • 119 Answers
1st make sure the speakers are not bad, check th eimpedance with a multimeter, the voice ciols should read 3.9 to 4.3 ohm's. if any of your subs are below this most likly the subs are bad. if they are ok make sure the ground for the amp is good. now the last thing is the amp. try another pair of speakers, even if it's smaller ones, just make sure they are 4 ohm speakers, keep the vol. very low during your test. if the other speakers do not work then have your amp serviced or replaced. good luck
Posted on Dec 19, 2006
  • kevin letteney Dec 20, 2006
    if it's an intermittent ground problem, using an ohm meter will not help, just make sure the location you hooked up your ground wire has no rust around it. ( rust, even a little can cause intermittent problems). Does your headlight dim very low. when you get a lot of base. if so you could have an power supply problem in the car/truck. that little light on the amp may not go out, but if the B+/ positive voltage drops to low the amp will trun off & on again without the led on the amp going out.
  • kevin letteney Dec 26, 2006
    remove the screws from the bottom of the amp, you should find a bank of transistors on each side. there will be small ones & bigger ones. the bigger ones are your audio o/p. using a digital multimeter, test to see if the pins of the bigger transistors are shorted. the transistors work in pairs & would have to be replaced as such.
Kenwood KAC-8103D on and off problem
it sounds like the power wire might be grounding out somewhere that you dont know of it could be by the fuse link so I would say put electrical tape on any exposed wire on the fuse link first if that don't work try change the power wire.
Jul 19, 2010 | Kenwood KAC-8101D Car Audio Amplifier
KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Sep 27, 2009 | Kenwood KAC-8101D Car Audio Amplifier
Just woundering if i could bridge one sub to front and one to rear the subs are kenwood w3514 dvc subs the amp is kenwood kac-x501f
Hello bigmac208,
Yes, that would be the best connection for both the subs and the amp.
I'd wire the sub voice coils in series since the amp will not be stable at 2 ohms when the channels are bridged. The power will be somewhere between 100-200 watts RMS to each sub. While it's not pavement pounding, it should provide pretty good bass, especially if you tweak the crossover and boost settings for best bass response.
Hope this helps.
Aug 28, 2009 | Kenwood KAC-X501F Car Audio Amplifier
Kac-8101 no power
no its not dead u prob blew a couple of heat sensors or a capacitor. most defenetly a capacitor. ceck ur capacitor and see if its blowned
Jun 28, 2009 | Kenwood KAC-8101D Car Audio Amplifier
Why does my KAC-8404 cut off at high volume bass?
amp 101
1/0 wire to the amp or the amps will loose power
check the connections mainly the negative
wiggle the wires see if you get a cut out or not
a cap will help you give constant power to the amp and not allow them to drain on long bass notes
hope this helps
Dec 26, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Kenwood KAC-9152D Car Audio amp
There could be several problems. The following page should help you determine if you have a problem with the amp or something connected to the amp.
Amplifier in Protection Mode - Troubleshooting
Let me know if you have any other questions.
Sep 17, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Amp light is on but no power to my subs!
Hi There.
When you say the 40 Amp fuse blew. Was it your mains battery fuse or was it the fuse on the amplifier? If it was the fuse on the amplifier then you may have hurt the amplifier. The Kenwood KAC-8101D is a 1000 Watt monoblock amplifier. Therefore if you say that 1 of your woofers is not playing, then it is almost certainly blown if you are sure it is connected correctly. Try disconnecting it and only running the woofer that tries to play. If this woofer is still working correctly, you will notice a drastic drop if the sound of your bass. The reason for this is because you have changed the impedance load on your amplifier due to the fact that the other woofer is not working. Have your working woofer checked and replace the faulty woofer then you should be banging again.
Hope this helps!!
Jan 30, 2008 | Kenwood KAC-8101D Car Audio Amplifier
Need help
It should be better to use the Pioneer GM-7200M Amp with your subs.
For 8 ohm setup hook up this way:
Amp out+ to Sub1 +
Sub1 - to Sub 2 +
Amp out - to Sub2 -
For 2 ohm setup hook up this way:
Amp + to Sub1 +
Sub1 + to Sub2 +
Amp - to Sub1 -
Sub1 - to Sub2 -
Nov 09, 2007 | Kenwood KAC 6201 Car Audio Amplifier
Amp not powering up??
the sub amp may be damage, shorted. you may have a wrong speaker hook-up the first time you use it. too low impedance may have damage the sub.
May 15, 2007 | Kenwood KAC-8101D Car Audio Amplifier
Kenwood KAC-8101D Car Audio Amplifier Logo
376 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
