Question about LG 32LX1D 32 in. LCD Television
I can't turn off my TV
I opened my LG 32LX1D tv with the remote control and tried to turn it to the dvd input. It did nothing. At first I tought the remote was not responding anymore, I changed the batteries, etc. Nothing worked. So I said, maybe you could turn it off from the pannel and back on again, it might work, but I can't turn the TV off at all. I did not tried to unplug it yet, since I' affraid it would damaged it?
Any idea of what is hapenning?
Hi,i have 32 in classic lcd tv,when i plug in is on but cannot turn off either way?
Posted on Dec 25, 2008
    Champion:
  • 211 Answers
Maybe your logic-board is a little stressed.
If your TV doesn't response on your remote control, the only way to switch off is to unplug it.
After one minut you can plug it in and give it a try, no problem.
If it still doesn't work, you have to visit your dealer.
Kind regards,
Gerard
Posted on Nov 21, 2008
I have 37LC50CB LG tv. When I turn on with new DTA remote control come up channel # 56-1 and cloud(nothing) on screen Then I...
Your DTA remote cannot turn on your LG TV. Find the red/white/yellow cable that was in the box with your DTA and connect it between the appropriate RCA outputs on the rear of the DTA and the corresponding RCA inputs on the rear panel of your TV. Disconnect the cable connected between your DTA and the antenna input of your TV. Be sure your DTA is on. Turn on your TV and select your DTA as the input source. You may have to press SET UP on your DTA remote to display the set up screen on your TV. Do a channel search and you should be all set.
Nov 24, 2016 | LG Televison & Video
Use and codes
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too
http://remotesearch.blogspot.com/
Apr 21, 2014 | LG AKB35840202 Remote Control
Directv remote and LG remote will not control tv, just receiver
Let's start simple first. Your TV is not responding to either remote control, but specifically if your factory original LG remote does not operate the LG TV, then the problem could be with the IR receiver in the TV itself.
Ensure nothing is blocking the IR receiver on the TV. Move anything out of the way.
Test both remotes to ensure that they are sending an infrared IR signal to the TV. Use a digital camera (such as the one on your phone) and point the remote into the camera lense and press the power/volume/channel buttons. You should see a faint flashing light in your camera viewfinder. This indicates that the remote is sending IR signal. If you don't see anything, then there is no signal. Try FRESH batteries.
If your remotes are working, and since this is an LG, look at the back of the TV by the video inputs. Look for a port called "REMOTE CONTROL IN" or similar. It looks like a 3.5mm headphone jack. This port is used for external remote control and may be dirty.
UNPLUG the TV, then use a regular 3.5mm male headphone jack to plug in and out several times. You basically want to push all the way in and all the way out several times to dislodge any dust and remove any oxidation that has built up in the port. 10-15 times should do fine.
Then plug in the TV and try your remote.
Best of luck.
Nov 05, 2017 | LG 32LG30 32 in. LCD HDTV
I have recently had dish network installed and now I cant get my DVD player to play I have tried contacting dish network for assistance and no one can figure out the problem. I have a LG TV
Hello! This is Dan with DISH Network customer support. have you tried cycling the inputs? If you have an HD tv the DISH receiver and your DVD are probably connected using different cables. I would power them both on and hit the input or source button on your LG remote until you get a picture from the dvd player. Remember what input comes up as you will need to change this to go from satellite to DVDand back.
Jan 12, 2011 | Directed 434MHZ Remote Control
When i plug my lg lcd tv in, it does not turn on, instead the standby light on the front of the tv flashes as if its coming on and then goes. i have tried plugging it back in many times but cannot find a...
Have you tried switching it on using the remote control for your TV? It appears your TV is on standby mode and only the remote might do the trick to get it to fully power on.
Post a feedback or update if this tip does not help you out.
Oct 12, 2017 | LG 32LX1D 32 in. LCD Television
I have a 32LX1D that is four days out of warrenty.
try talking to LG--do not take no for an answer--also someone has bought the circuit city name---people who take no for an answer do not get it fixed---most of these companies if you go high enough up will grant a Concession( it means they will take care of it)
Aug 07, 2009 | Televison & Video
LG TV renote not worknf on 4 new sets
If you have a cable box (otherwise known as a set-top-box) that you have to turn on when you turn the tv on, and you use to change your cable channels, the LG remote will not control it. The LG remote is strictly for the tuner built into the television, and is not capable of controlling the cable box.
You probably see "function not available" because you are viewing the picture on an external input of the tv (component, composite, etc). Your tv cannot tune stations in when it is set to an external input that you use to watch DVD's, cable boxes, games, and other devices. The tv is telling you that you can't change channels if it is on an input.
I hope this helps you...
Jan 20, 2009 | LG Televison & Video
LG 32LX1D 32 not turning on
Hi, I think you have to get it checked out by a profesional, unpluging your appliances is a good idea but damage can also ocuur the moment you plug them back on. If you want to try it could be that a fuse is open there not normal fuses inside (small chip fuses surface mount)
Aug 24, 2007 | LG 32LX1D 32 in. LCD Television
Remote control has lost communication with LG 32LX1D 32 in
I have the same problem. If you unplug the tv for a while then plug it back in it will work again for a time.
Nov 04, 2006 | LG 32LX1D 32 in. LCD Television
LG 32LX1D 32 in. LCD Television Logo
221 people viewed this question
