Question about Frigidaire SUPER SPECIAL 22.6 cu ft Counter Depth Stainless Steel Side By Side Refrigerator, FSC23R5...
Frozen water tube that goes into the icemaker
Frigidaire 22.6 cu. ft. Counter Depth Side-by-Side Refrigerator White FSC23R5DW
I have an RO unit that feeds water into the fridge. It was turned off for 2 days. Now the water works but it looks like the tube that feeds water into the icemaker is frozen inside.
  • Frigidaire Master
  • 19,396 Answers
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
Frigidaire Professional 22.6 Cu. Ft. Counter-Depth Refrigerator - Model: FPHC2399KF I have ice that is collecting in the bottom of my freezer. My understanding is that this ice is caused by a buildup...
There is a chance that the drain hole is pluged or clogged with frozen ice.This can usually be cleared with hot water to melt the ice then dry off any remaining water with a towel.
the drain is located in the bottom rear of the freezer cabinet just behind the panel with the vent holes
Jul 06, 2010 | Frigidaire FPHC2399KF (226 cu ft) Side by...
Installed new ice maker, produces ice slow, is there a way to adjust for faster or slower?
The water tube to the icemaker inside the refrig is frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Jun 06, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Ice maker is not working
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 05, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool icemaker not working properly
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Likely that the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Jul 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker not working
Jun 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Icemaker not making ice
The same thing happened to my Whirlpool gold. Defrost it for 24 hours and the ice maker now works.
Apr 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Frigidaire SUPER SPECIAL 22.6 cu ft Counter Depth Stainless Steel Side By Side Refrigerator, FSC23R5... Logo
246 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
