Question about Whirlpool Duet GHW9150P Front Load Washer
Stops about half way thru cycle anf error code HF appears
Hello I have a Whirlpool Duet GHW9150P washer and about half way thru the wash cycle it stops and flashes HF on the LED , Any suggestions????
Thanks
  • Anonymous Mar 19, 2014
    My amana washer stop half way on the wash cycle how do I fix it
  • 3,230 Answers
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation.
Posted on Mar 28, 2009
    President:
  • Whirlpool Master
  • 2,651 Answers
Assuming you mean FH, code for no water entering machine, first check incoming water supply especially cold water, halfway through cycle the rinse is activated and the "cold" water is energized, if none comes in you will ge the FH code
Posted on Nov 23, 2008
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Whirlpool duet not feeding softener and getting hf error code
The common issue is the pressure switch or the hose connecting the pressure switch to the trap. This is a thin tube from the trap to the upper pressure switch. See that this tube is not blocked, can be disconnected and blown through; when blown thru you shd hear a click - this means it is good.
Apr 10, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer fills with water washes for about 12 min then code hf
The FH error code means that the washer has not detected any water entering it. This tip i wrote relating to the FH code covers what to checkto fix it.
http://www1.fixya.com/support/r10423905-fh_code_means_duet_epic_front_load
GENE
Oct 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
When in final cycle of spin the code HF appears
Hello & Welcome to FixYa
FH error is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
Mar 02, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer model GHW9200LW, THE CODE HF comes up ,tried the recommended fixes from the troubleshooting guide, but no luck
HF = High Fill
This can be caused by using non HE detergent in your front load. Put the washer in a cold rinse for a couple of cycles to clean the excess soap and try the cycle again using HE detergent. If the problem returns you may have a pressure switch or hose that will have to be replaced.
Aug 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer duet
Either one of your supply lines, hot or cold or you have one of two issues. If the unit has a flowmeter that would be suspect but the more common issue is the pressure switch or the hose connecting the pressure switch to the trap.
Sep 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F-21
replace the contol board
Apr 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hf code
You need to be more specific. When does the code appear? Does the machine start?
Nov 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
950 people viewed this question
Dan Webster
Dan Webster
Sal De
