Question about Legacy LA498 Car Audio Amplifier
Amp not working
Hi my legacy 798 is on protect and will not come off when i turn it off it went on when the out put cable hit a live wire plz can some one help me in fixing it as it was a gift of a old freand wich has not long past away thanks
  • ian mcdonnell Jan 22, 2008
    ta 4 thats mate i have a meater and no clue how to use it and its the lil chips that seen to be getting hot i have replaced all 4 of the lil chips and ther still geting hot so wats my next move regards ian
    Scholar:
  • 119 Answers
Well it sound like you most likely damaged the audio output transistors. take a multimeter & test the outputs. remember they work in pairs so if you find 1 replace the one next to it also. in the amp you will find many transistors, the o/p transistors are the bigger ones.the transistors will be stamped with a part number, typically add "2S" in front if you try to find the parts yourself. good luck.
Posted on Dec 19, 2006
I have a Legacy Predator 2000 watt amp with 2 12'' Kicker speakers. It has been in my car for about a year now, and it recently just stopped working. I have the green light to the amp, im not sure about...
If you have checked your ground, live, remote and RCA's, The problem may lie with your kicker speakers.
There may be a loose wire connection on the speaker terminals (hense no sound).
Check the terminals at the speaker (+) and (-) then check the speaker wires to your amp inputs.
Usually if there is a fault with any wires linked to your amp, the amp goes into protect mode.
If your amp is not going into protect mode, try linking a different speaker to each terminal on your amp (left) then (right). If you get sound through a different speaker, more than likey your speaker wire to your kickers has came loose (due to vibrations) or there is a break in your speaker wire.
Hope this helps. If any more info is needed I'd be happy to help more. Please rate if helpful
Mar 18, 2011 | Car Audio & Video
I have 2 kicker cvr12s and a legacy predator 2400 watt amp and when I turn the radio up the amp goes into protection once they hit a decent time. I just down graded from 15s so I know its not a power...
you prolly have the subs wired to a too low of an ohm load...thats what happend to me. i had the same subs, and a 500.1 watt amp...and they still blew up..whire EACH sub to a 4 ohm...that should work.
Nov 18, 2009 | Car Audio & Video
2000 watt legacy predator amp
Disconnect all speaker wires from the amplifier's speaker terminals and disconnect the RCA cables from the amp. If the amp still goes into protect, it probably has shorted output transistors.
Feb 17, 2008 | Car Audio & Video
Falty Amplifier?
It sounds like the output transistors have shorted. This is VERY common. If you want to try to troubleshoot the problem, I'd need to see photos of the inside of the amp. You'll need a multimeter to check the transistors.
Before opening the amp, remove it from the power source.
Since the resolution is severely limited here, send the photos to me directly (babin_perry@yahoo.com). If you're going to send multiple photos, please zip them and send one file.
Dec 21, 2007 | Legacy BLUE 4 X 250W CAR AMP Car Audio...
Legacy amp in protect mode
What was the part number on the transistor you replaced?
Dec 14, 2007 | Legacy Audio Blue Diamond LA1880 Car Audio...
Amp in protection mode
Disconnect all speaker wires and signal cables from the amp. If it powers up normally (doesn't go into protection), the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Nov 11, 2007 | AudioBahn A4401Q Car Audio Amplifier
Amp not working correctly goes into protection
Disconnect the speaker wires from the amplifier and see if it still goes into protection mode. If it still goes into protect with the speakers disconnected, there's a problem with the amp; if not, you may have a blown speaker or a shorted speaker wire.
Feb 22, 2007 | Legacy LA2098 Car Audio Amplifier
Amp shutting off going into protection mode
Check this out: http://www.techlore.com/article/14696/
Aug 14, 2006 | Legacy Audio American Legacy II LA690 Car...
Legacy LA498 Car Audio Amplifier Logo
Top Legacy Car Audio & Video Experts
Putter71
Level 1 Expert
Robert Little
Level 1 Expert
xxxxxx xxx
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
