Question about GE 24 in. GLD5560LSS Stainless Steel Built-in Dishwasher
Ge dishwasher gld4160looss
Water runs down front of door on outside fron the heat vent while in the drying cycle.
    Problem Solver:
  • 8 Answers
Where's the vent on top/or the end of the door under the cabinet? Some steam is normal.
Posted on Nov 21, 2008
How to reset code to turn up the heat on a dishwasher model #WDT9105AYE
You can't turn the heat up, just on or off. Are you using heated dry?? It sounds like the vent system in the door is either not working or blocked. Some dishwashers have a small trap door flap in the dishwasher door that is closed during wash and opens to vent steam during the dry cycle. Sounds like it is staying closed. If you have a higher end dishwasher, they usually have a fan motor that come on during dry that gets rid of steam and moisture. Just a few things to check.
Feb 16, 2015 | Whirlpool Dishwashers
I have a kenmore ultra 665 1627. The green front panel light blinks. And we can not run a cycle. Thanks
Ah, the famous (or infamous) Clean-light blinking problem. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff, a bad controller; but the most common problem is that 1 of the 2 switches inside the door latch is not getting engaged fully. This may be caused by something getting spilled (like a soda) into the door latch that is making it stick, or the door strike may be weak and not pressing down on the door latch hard enough. If it's the latch, you would need to take the door apart and remove the latch mechanism (unplug the dishwasher first!), remove the switches, and clean the plastic parts with water, dry it, and then re-assemble. The other thing to check is the door strike, which is supposed to push down the latch. The springiness of this metal part may be weak. You can remove that door strike, bend it down more, and then re-install it. Then you need to reset the controller by running a diagnostic cycle. Do that by pressing the following sequence of keys: Heated Dry - Normal - Heated Dry - Normal; or High Temp - Air Dry - High Temp - Air Dry; or Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or High Temp Wash, Heated Dry, High Temp Wash, Heated Dry). You will know that you have entered the diagnostic cycle when all the lights light up for a few seconds. Let the dishwasher run the diagnostic cycle for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jul 27, 2014 | Kenmore Dishwashers
GE GDWT160R dishwasher.
Some type of dirt or dust got in your panel, now the contacts don't touch. Not a diy job.
Jul 27, 2017 | GE GDWT160R Dishwasher
I have a 665.16039401 kenmore dishwasher and the clean light continues to blink. I can not run any cycles
Ah, the famous (or infamous) Clean-light blinking problem. Watch that blinking light.... You say it blinks 7 times, pauses, and repeats, right? Well, 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff or thermostat, a bad controller, or a problem with the door latch and/or switches. Usually, the most common problem is that 1 of the 2 switches inside the door latch is not getting engaged fully. This may be caused by something getting spilled (like a soda) into the door latch that is making it stick, or the door strike may be weak and not pressing down on the door latch hard enough. If it's the latch, you would need to take the door apart and remove the latch mechanism (unplug the dishwasher first!), remove the switches, and clean the plastic parts with water, dry it, and then re-assemble. The other thing to check is the door strike, which is supposed to push down the latch. The springiness of this metal part may be weak. You can remove that door strike, bend it down more, and then re-install it. Then you need to reset the controller by running a diagnostic cycle. Do that by pressing the following sequence of keys: Heated Dry - Normal - Heated Dry - Normal; or High Temp - Air Dry - High Temp - Air Dry; or Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or High Temp Wash, Heated Dry, High Temp Wash, Heated Dry). You will know that you have entered the diagnostic cycle when all the lights light up for a few seconds. Let the dishwasher run the diagnostic cycle for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error. If the problem re-occurs, then the cause may be a bad heating element or a bad controller.
Mar 24, 2012 | Kenmore 15129 Built-in Dishwasher
Dryer is running, but rotating very slowly. it generates heat, but makes a very loud noise. it's a GE Adora Dryer
Instructions
1. Wait approximately 90 seconds for the light to turn off if the "Start/Reset" indicator light flashes. Press the "Start/Reset" button to restart the wash cycle.
2. Close the dishwasher door and move the latch to the locked position if you hear a beep once every 30 seconds when the dishwasher should be operating. The dishwasher will not operate if the door is open.
3. Turn on the hot water faucet and feel the water to check if it is hot. Wait for the water to warm up before running the dishwasher if the water is not hot. Check that you have proper water pressure and wait for the pressure to return to normal if it is low. Your dishes may not come out clean if the water is not the correct temperature or if you have low water pressure.
4. Move the dishes on the racks so that they do not block the detergent dispenser or washer arms on the bottom of the machine. The dishes will not come out clean if they block the detergent dispenser or the washer arms.
5. Load the proper amount of detergent in the dishwasher if you find spots or film form on your glasses. If you have hard water, use a rinsing product such as Jet-Dry in the dishwasher to clean the spots or film. If the problem persists, wash smaller loads of dishes.
6. Add only automatic dishwasher detergent to the dishwasher if you find excessive suds in the tub after running a cycle. Measure out the proper amount of detergent.
7. Press the "Heated Dry," "Hot Start," "Hot Wash" and "Added Heat" buttons, if you find that your dishes are not fully dry after a wash cycle completes.
8. Press and hold the "Heated Dry" button on the dishwasher for approximately three seconds if the control pad does not respond to button presses. This is the child lock that prevents unwanted use of the dishwasher.
Feb 24, 2011 | GE Dryers
Low detergent light does not come on indicating the GE profile dishwasher is out of detergent.
It is probably because your Smart Dispenser is full of water and there may be a clog of some type in the pump. Try purging your Smart Dispenser and see if it fixes the problem!! It fixed ours!!
How to Purge Smart Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Jul 09, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Purging ge profile smart dispense dishwasher
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
Jul 05, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Dishes not dry enough & leak of water at sink vent device
HEATED DRY.Turns the drying heater on for fast drying.
ENERGY SAVER (no heat boost). Turns the drying heater off to save energy. Dishes will dry naturally over a longer period such as overnight. lf you need your dishes sooner, open the dishwasher door after the cycle is complete to reduce the natural drying time. Use of this option reduces the electrical energy used by this model approximately 7%. A rinse agent makes water flow off dishes quicker than usual. This lessens water spotting and makes drying faster, too.
Make sure inlet water temperature is correct.(SeePage6.)
Unload the bottom rack first.Water from dishes in the top rack may be spilling in to the
bottom rack.
Check for improper loading.Dishes shouldn’t nest together. Avoid overloading. Check the rinse agent dispenser to see that it’s not empty.
Inlet temperature....Good Dish washing starts with hot water, To get dishes clean and dry,you will need hot water.To help you get
water of the proper temperature, your dish washer automatically heats the water in the wash cycle. For good washing and drying , the entering water must be at least 120°E To prevent dish damage,
inlet water should not exceed 150”F. How to test water temperature: Check the water temperature inside your dishwasher with a candy or meat thermometer. Let the dishwasher run through
one fill and pump out cycle, then let the dishwasher fill with water
the second time. When you hear the water stop filling, unlatch the door and slowly open it. Measure the temperature of the water in the bottom of the tub this way: Remove the silverware basket and
place a candy or meat thermometer in the water towards the middle of the tub. If the temperature is less than 120”F,you will not get good washing results. Higher water temperature is needed to dissolve grease and activate powder detergents. If the unit is a long way from the DW you may need to let the water run in the sink until hot before starting the DW....or if is a cold day and water has not been used in a while the pipes could be cold....also if you have just used the hot water ( washer, shower...etc) give it time to recover first before using DW....All of the above mentioned material is straight out of the Users guide...but you may have an element that is going out also...so check the temp of your water and open it during the drying cycle to see if it is hot or at least warm inside...if not your element may need to be replaced...
I hope this helps...have a great day & good luck...please rate my effort.... the Fang.
Jan 06, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher maytag 945 awq
Door gasket or sealOver time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Nov 08, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Water Leak at vent area in door...
On this model the vent is open and shut by a wax motor. The vent should be closed tight during the entire wash cycle and the first 6 minutes of the drying cycle. Check the operation, make sure there is not a bunch of gunk restricting it. If you are handy with a meter check the resistance of the motor. It should read approx. 2100ohms. Another reason for leaking at the base is oversudzing. Also check the upper spray arm for cracks or splits shooting water into the vent area. Catriver...post back.
Oct 23, 2006 | Maytag 24 in. MDB4000 Built-in Dishwasher
GE 24 in. GLD5560LSS Stainless Steel Built-in Dishwasher Logo
250 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
