Question about Vacuums
MY VACCUM WILL NOT PICK UP THE DIRT SO HOW CAN I FIX IT
    Scholar:
  • 55 Answers
There are two things that can cause an upright vacuum to stop working
A: Air Flow or Suction-Make sure that the air flow is not impeded by a clog, full bag, or dirty filter.
B: Agitation- Make sure that you have a good belt, the roller is engaged, and that the height adjustment is set appropriately. Most vacuums need a belt change about every six months whether it is broken or not.
You may want to ask a more specific question with your make and model number included.
Hope I could help
Good Luck
Posted on Nov 21, 2008
Eureka Maxima 12 amp vaccum cleaner is not picking what can be done to make it pick up?
remove and clean the filter ( tap and brush filter or use a air compressor to blow out filter ) --- also check the vacume hose near the floor attachment for any dirt and debris that may be clogging the line. this should bring your vacume to full operation.
c...
Jan 22, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
The vaccum won't pick anything up
You have a clog in the dirt path ... Inspect and clean it from end to end. You will probably need a broom handle and a screwdriver.
May 01, 2010 | Dirt Devil CE6000 Featherlite Wet/Dry...
Hello, I have a Hoover 3200 Turbo Power vaccum. while the motor appears to be working fine the vaccum no longer picks up the dirt. I turned the vaccum upside down and the belt appears to be broken. would a...
take the vacuum head off the end of the tube , turn the machine and place your hand over the end of the tube
if it sucks your hand onto the tube , the machine is working as a vacuum machine
then check fro a blockage in the elbow section near the head
if there is no vacuum , junk it and get a new one
Jun 30, 2017 | Hoover Vacuums
How do you replace the belt on the dirt devil feather lite vaccum.
not a expert just trying to help,,turn vaccum over take plate of and pull brush out and install new belt,,hope this help you
Oct 20, 2009 | Dirt Devil CE6100 Featherlite Upright...
Poor suction in electrolux theboss power 1300W and LG HEPA filter 1500W vaccum cleaner. have checked bags no problem. It doesn't pick up any dirt.
if the motor is truning perfectly without any strange noise,please their be an obstruction suction side
Oct 01, 2009 | Vacuums
The vaccum doesn't pick up dirt, it sprays out
There is probably a second or third filter (besides the canister) that needs to be cleaned.
I doubt that it's rotating the wrong direction.
Apr 25, 2009 | Dirt Devil M084600 Dynamite Bagless...
Dirt devil vaccum #088915 won't pick up.
well the first thing i would look for is if the brushes turn turn it over bump the on off switch if it turns the belt is fine but u might have a clog in the bottom if that the case have to pull cover from thhe bottom take the belt and roller brush off and look up insde where the junk sucks up use a wire hanger if u need and after that clean out where the dirt goes in bag or canister........hope this helps
Dec 16, 2008 | Vacuums
Dirt devil swivel glide - no suction
check the filter gauze on the unsud of vack where bag is if this is blocke you will not have vacuum as there will not be ventilation thro this filter should be able to feel blow of air from this vent when vacuuming up hope this helps good luck from uk !
Nov 02, 2008 | Vacuums
Dirt devil 12amp,Patent No.6571425
Either it needs a new belt, they stretch and break, then won't turn the brush roll. The dirt inlet by the brush roll is clogged, the hose may have a clog in it, filters are bad. If the hose comes off on one end, is there suction there, is so then the clog is farther down. If no suction, then the clog is in the hose or filter.
Mar 02, 2008 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Bissell vaccum problem
Could be plugged, check the hose and at the bottom by the brush roll, the inlet maybe clogged. Also check the filter under neath the dirt tank. There are filters above the dirt container, clean those out. If after that it is still loud, then maybe the motor fan or bearins are bad and will have to be replaced, part #2031214 sells for around $55.
Jan 16, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Vacuums Logo
37 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
