Question about Sony Playstation 3 (PS3) Console
PS3 wont work
I was playing a video game and all of a sudden it shut off, i tried 2 turn it back on and the green light went to yellow then flashing red. what does this mean? please help me!
  • 2 more comments
  • leenanralphy Nov 21, 2008
    my ps3 was in the middle of a game then switched itself off now when i try to switch it back on it goes green then flashes yellow then back to red??????
  • Anonymous Nov 23, 2008
    same thing, but mine's been doing it for days!
  • lubbeps Nov 23, 2008
    Jip I still have the same problem!! I was playing for about 2 hours and then browsed through my music files when my sistem just shut off. When pressing the power button it goes green, then yellow and the switches off and the red light keeps flashing. I kleened all the air vents and left it over night to cool down, but that was about 4 days ago and I've tried a few times now but still have the same result! Was it maybe the power supply or the motherboard that overheated?
  • Walkerboy Nov 23, 2008
    I have the exact same problem myself, at first i could play for a while before it shut off, now when i turn it on the light goes green for about 2 seconds then yellow, then red, and when it goes red its flashes until i touch the power button again. When iv'e touched the power button it goes solid red, then i touch it again and it goes green, and repeats the process i just explained. Help pleasee!
  • 36 Answers
How long were you playing it? if you were playing for a couple of hours, then it could of just overheated, in which case the ps3 will shut itself off suddenly to keep from damaging something. It should work after about half an hour, adequate time for it to cool down, if not, then you might of damaged something.
Posted on Nov 21, 2008
Fully backwards compatible ps3 shuts down with 3 beeps and flashing red light when trying to play ps1 games
Hmmmnnn, consider the reason they pulled the rev compatible system off the market. It is possible to be getting the symptoms of YLOD without it actually happening with some games. The older games spun faster(sometimes) and made the system work harder. It could be heating up and shutting down right at the point of failure. I've seen 2 different revers compatible systems YLOD the same way. Good luck.
Apr 06, 2013 | Sony Playstation 3 (PS3) Console
I was trying to play a game and all of a sudden it just shut off and when i tried to turn it back on it went green to yellow to red flashing
Hi Kyle,
Are you seeing any flashing red/yellow lights?
If so this is the red light error and you will find that is why the system will not turn on.
Why Does It Happen?
The GPU and the CPU are the 2 main chips in the system and they deal with all of the number crunching however they can get very hot and if they lose connection the system will either freeze up or turn off and give you the red flashing light.
How To Fix?
The key is stopping the heat build up and you can either send it in and they will fix it for you.
Bear in mind that for the PS3 red flashing light error you will be waiting for about 4 weeks and it will also cost you $150 for the repair bill!
Other Ways To Fix?
You can also use a good PS3 Repair Guide to fix it and this will show you how to stop the heat build up with a few household items.
Just make sure that you get a good guide there are some good ones out there!
Click Here For A Complete Review Of All Available PS3 Repair Guides.
Hope this helps and any questions let me know?
Apr 02, 2011 | Sony Playstation 3 (PS3) Console
Ps3 power wont stay on
search yellow light of death on google
1)Turn off your playstation. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work send to sony to get fixed
May 09, 2010 | Sony Playstation 3 (PS3) Console
Playstation light flashing red and playstation not working
Most of the times, you're going to find that this is due to over heating. If you've been playing for a while, shut down your Playstation, and let it sit for about 1 hour. It's best if the room is cooled off as well.If the room is hot, you may want to put a fan blowing toward it, or turn up your Air Conditioning.Check the back of your unit, and make sure that all of the cables are plugged in. What you're going to want to do is take out each one, and blow the inside of the ports with compressed air.
To play it safe, take out the Playstation's hard drive, and place it back in.Once the 1 hour is up, and the Playstation hasn't been running, turn it back on, and see if everything is working. If it is, you're good to go! If it isn't, you may want to consult with Sony.
May 04, 2010 | Sony Playstation 3 (PS3) Console
60gb ps3 wont start up.
Possibly the very common mother board failure. Slight possibility that the power supply is failed, but the capacitors in either component can be tested with capacitor tester and service manual to test for the faulty component.
Aug 27, 2009 | Sony Playstation 3 (PS3) Console
My ps3 suddenely turned itself off mid-game. turned it back onto standby mode, then when i turned it on the light went green as normal then suddenely red light came on with the green, three rapid beeps...
try this:
it works for slimline PS2. might work for PS3.
1) turn off PS3
2) unplug PS3 and wait a minute or two before plugging back in.
3) turn on PS3
hope this helps.
it could also be overheating.
Aug 19, 2009 | Sony Playstation 3 (PS3) Console
Playing my ps3 and suddenly it turned off and wont turn back on.
Hi. this is a basic power supply issue. it has failed. you will need to replace the internal power board(supply). this will fix your issues.
Jun 04, 2009 | Sony Playstation 3 (PS3) Console
PS3 light turns GREEN, w/ blinkin BLUE, to YELLOW, to flashin RED
it is fried and needs repairs if you break the seal by trying it yourself you void the warrany
Mar 15, 2009 | Sony Playstation 3 40GB System Console
Sony Playstation 3 (PS3) Console Logo
170 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
