Question about Onkyo TX-SV444 Receiver
Very weak sound like a transister radio
I have a Onkyo TX-SV444 receiver. 4 years ago I bagged and boxed it, it was workinig fine. Fast forward 4 years and I unpack it, wired up the speakers and hit the power button. Unit powered up but there is no volume. Yes, it does respond to the volume knob but it sounds like a headphone speaker from 10 feet away. I am more than confident that the wires and knob selections are OK. Do you have any recommendations...Thanks
5 Suggested Answers
  • 8 Answers
SOURCE: Onkyo TX-SV444 problem
the shorted spkr wires probably fried the putput transistors in that channel.  Do you know how to use a Fluke  test meter on diode test
Posted on Jan 15, 2009
lynchms
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
dunnbiker
  • 8546 Answers
SOURCE: tx-sv444 says protect then powers
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Jul 20, 2011
Hello. If the wires have touched, your amplifier probably has what's known a DC Offset, meaning a damaged amplifier. You will need a qualified audio tech to repair this, as this type of forum is not designed for detailed step by step repair.
Sorry.
Dave
Posted on Oct 09, 2012
I have an onkyo tx-sr308 and I am receiving only static or very low music on my right speaker channel. Please help
Switch to the other set of speaker outputs (move from A to B). If it continues, you have a repair issue...assuming it happens with all inputs. If it only happens with DVD, or CD, or Tuner, or whatever, but works fine with other components, it's a connection issue - unplugging and replugging, or replacing cables may correct.
If I recall correctly, that unit doesn't have a standard twist knob style balance control. If it does, turn the unit off and rotate it through it's full range several times, then recenter it and try listening to it again.
Jun 25, 2011 | Onkyo TX-SV444 Receiver
I have an audio problem with my TX-SR502.
If your remote also controls the Cable Box you might want to look at its audio settings. Maybe you muted it.
BTW: it would be a good idea to also run video and analog audio from the cable box directly to the TV if it has speakers so you can watch and listen independent of the Onkyo.
Mar 11, 2010 | Onkyo TX-SR502 Receiver
Onkyo TX-SR705 - No Audio - Flashing HDMI
The posabilities is power amplifier on your reciever is bad,
replays reciever or repair it.More likely this is IC amplifier located on the main board of the reciever
Apr 15, 2009 | Onkyo TX-SR705 Receiver
Dec 31, 2008 | Onkyo TX-SV454 Receiver
How powerful loudspeakers can my Onkyo TX-SV444 tackle, maintaining good sound?
buy 6ohms or 8 ohms speakers. 4ohms consume too much power and sometimes causes short circuit. (safety first!)
Oct 16, 2008 | Onkyo TX-SV444 Receiver
Onkyo TX-DS797 - No sound
There is a technical bulletin from onkyo where in the problem is in the relay ckt
Sep 02, 2008 | Onkyo TX-DS797 Receiver
Tuner Omits No Sound - Onkyo TX-SR605 7.1 Channels Receiver
Make sure your receiver is hooked up to proper AM and FM antennae. Try switching to AM, scan stations. If you hear AM static and/or weak signals the problem could be antennas are not hooked up. FM has AFT which blocks out weak or noisey stations and you wont hear anything without ant.
May 06, 2008 | Onkyo TX-SR605 Receiver
Audio problems
Hi, I just started having the same problems with my Onkyo TX-DS575. I have to play with the DSP buttons...the A/B speaker button...and now it has gotten to the point where my family and I lift the receiver up in the front, and slam it back down on the shelf and then hit the DSP buttons again and eventually we get some sound. This unit was already fixed once by Onkyo right after the 2 year warranty ran out for a similar problem. They returned it working...but scratched. This is the second Onkyo receiver that has died an early death within 15 years. I love Onkyo's styling, ease of use and sound, but I found the best way to solve this was by purchasing the Yamaha RX-V861 this week. I am done with Onkyo. Scotty D, Middletown, NJ
Aug 20, 2007 | Onkyo TX-DS575 Receiver
DVD/TV Problem with TX-LR552
Did you change your TV input to DVD as well?
Jul 26, 2017 | Onkyo TX-LR552 6.1 Channels Receiver
47 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
