Question about Philips 50P8341 50" Rear Projection Television
No voltage feeding the convergence ic's. - Philips 50P8341 50" Rear Projection Television
    Scholar:
  • 119 Answers
The B= feeding the convergance ic's will have a fuseable resistor or a "pico" fuse, ( looks like a small resistor but no color bands). try looking for one of those, I would suspect it will be near the ic's themselves, but some put them in the power supply circuit. good luck.
Posted on Dec 19, 2006
Can't correct my red blue convergence manually or by using factory preset...the unit is 7 years old, is my picture tube bad?
You have bad convergence ICs. There are 2 ICs in the convergence circuit, one is for the Blue the other is for the Red. You can buy 2 ICs for under $40.00. Replacing these ICs require soldering and desoldering skills. Sometime, the resistors in the convergence circuit go bad also. Be very careful, there is a very high voltage in a CRT projection TV the voltage is over 30,000 volts.
Best of Luck
Sabre
Feb 23, 2010 | Philips 60PP9202 60" Rear Projection...
Do you have to buy a new convergence board to fix the blue and red convergence for a samsung tv
mo you can replace the two Convergence ICs and check the 3.9 ohm feed resistors. You can get new replacement ICs and resistors at the following link.
http://servicemanuals.vstore.ca/
Apr 20, 2009 | Samsung HCM5525W 55" Rear Projection...
Picture looks like 3D
replace the convergence Ics and feed resistors. You can get the DPTV305 -DPTV345 Convergence repair kit at the following link which contains both ICs and all 12 feed resistors plus step by step directions with pictures. Here's the link.
Feb 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
Manual Convergence
your convergence ICs have failed. You can get the convergence repair kit for your model at the following link which contains both convergence ICs and all of the feed resistors, plus the kit contains step by step instructions with pictures on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/phillips-dptv-305-dptv345-convergence-repair-kit/cName/convergence-repair-kits
Feb 01, 2009 | Philips 60PP9202 60" Rear Projection...
Failed resistor
those are the convergence feed resistors. # blinks on a panasonic means convergence IC failure. You will need to replace the two stk392-110 convergence ICs and the six resistors. You can get replacement ICs and resistors at the following link.
Sep 06, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Signal board jumper wires?
Hard wire jumpers feeding voltage to convergence circuitry located between board edge and current limiting resistors & near STK IC's.................HTH........................T.
Most H-line Toshiba's have them......
Aug 21, 2008 | Toshiba 43H71 43" Rear Projection...
KP46V15 Convergence problem
You must have checked fusible resistor?
check convergance control panel and check voltage supply to this board.If voltage are o.k than you have to change convergance control ic which is smd ic and its on the control board.
Gopal
Dec 10, 2007 | Sony KP-46V35 TV
Convergence IC,s overheat
the ic is getting too much voltage check a diode that feed into the ic it has a short.if you dont locate that defected component it will cost you much more than the set lol.good luck
Apr 23, 2007 | JVC AV-56WP74 56" Rear Projection...
Horrible Convergence Problem on Start
I doubt it. In a problem like this it could be a power supply that feeds the convergence ic(s). The longer you wait to have this problem taken care of the more of a risk your taking of blowing out the ICs, if there already not bad. Its highly unlikly all three ics went bad at once, unless of a power supply problem. Now this set is not serviceable by the end user as its solid state and all parts are soldered in. Also theres alot of HI Voltage inside this set!! Have the set checked out by a technician ASAP for a bad filter capacitor in the b+ line that feeds the convergence ics Good Luck
Jul 03, 2006 | Sony KP-65WS500 65" Rear Projection...
Philips 50P8341 50" Rear Projection Television Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
