Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Sp2 on dual core cpu
I have a problem using sp2 on dual core cpu. sp2 never runs after i install it to my pc so i use sp1 instead of sp2 but when i use it on single core cpu, sp2 can run. i have to install first the sp1 to my dual core cpu then upgrade it to sp2 in order to change my os to sp2. is there a way i can directly use sp2 without having to install sp1 first? thank you..
    Scholar:
  • 162 Answers
Please read and follow the article for your issue trouble shooting.
http://forum.notebookreview.com/showthread.php?t=60416
Thanks
Cyber_kaka
Posted on Nov 25, 2008
How to re-enable dual-core working on a lenovo a55(pentium d) when it is disabled
There are two possibilities: one is the factory installed a single core CPU and thus set the BIOS to correspond to this, and two is that you might be able to update the BIOS using BIOS update from Lenovo; make sure that the update states that it will take care of the single to dual-core cpu discrepancy. Please be aware that updating BIOS can be a very tricky procedure. If correctly done, everything works fine; if not, you can easily have a non-working motherboard.
Jul 25, 2014 | Lenovo Computers & Internet
What is the best upgrade cpu for a compaq presario sr5110nx 32 bit vista O.S... ATHLON 64 (single core) without having to go to 64 bit, and/or new drivers ?
The 400W PSU is going to limit your CPU selection to dual-core at best, although you might be able to get away with a higher-end dual-core CPU if your RAM is not ECC and not dual-channel, and you're not running anything serious in terms of a graphics or sound card or a SCSI array.
Given your current setup I'd really look for a 1.6Ghz dual-core Athlon which has a decent amount of KB in its Level 1 and Level 2 cache, but 3MB for its Level 3 cache.
Anything beyond that ballpark of a CPU upgrade is certainly well within the bounds of diminishing returns, and you should look at getting a new PSU, motherboard, and probably RAM (I'm guessing you're using DDR2 RAM currently).
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/andrew_7b5641a71b84cd85
May 24, 2014 | Compaq Presario SR1050NX (DW257A) PC...
System requirement to run crystal report v9 professional
System Requirements
  • PC with AMD or Intel based processors, Dual Core CPU, 2 GB RAM.
  • 3.5GB available hard drive space (for English only, 7.5 GB for all languages)
  • DVD drive (for DVD install only)
  • Microsoft Windows 7 SP1, Windows 8, Windows Server 2008 SP2, Windows Server 2008 R2 SP1, Windows Server 2012
  • Languages: Chinese simplified, Chinese traditional, Czech, Danish, Dutch, English, Finnish, French, German, Hungarian, Italian, Japanese, Korean, Norwegian, Polish, Portuguese, Romanian, Russian, Slovakian, Slovenian, Spanish, Swedish, Thai, Turkish
Technical Specs
  • Hardware Requirements: Intel Pentium III or equivalent processor, 256 MB RAM, 512 MB Recommended
  • Disk Space: 2 GB for default installation with English language, 4 GB for default installation with all languages installed
Dec 23, 2013 | Crystal Decisions Crystal Reports V9...
Swap single core to dual core. and system shuts down for hardware problems. emachine el1300g-01w using windows 7 mother boards with am2 socktet. i installed the dual core processor and the pc ran good for...
I installed a dual core in my 1300g no problems. I we t against advice and tried a 65w tdp chip for a couple days and it ran a bit hot. A dual core am2 CPU for this machine must be 45w tdp or under. Research the dual core you tried. I'm betting it was too hot or needed to much power. Also the heatsink is crappy too. If you need a better one find a lga 775 heatsink with back plate. They it right in but check for height to fit in your case.
Feb 15, 2011 | AMD 4800+ Athlon 64 X2 Dual-Core Processor...
CONFUSION WITH INTEL CORE DUO AND INTEL PENTIUM DUAL CORE!
You are worrying about nothing.
Intel Pentium Dual Core and Intel Celeron Dual Core are both Intel Core Dual processors.
The performance rate is mesured compared to a single core processor so your 2.2GHz dual core will do the same amount of work as a 4.95GHz single core.
Sep 06, 2009 | Intel Computers & Internet
Gtaiv running problems
your pc cant run it .you dont have enought ram and to run gta IV is beter to have 2 core atleast 2,2 ghz
Jun 18, 2009 | Rockstar Games Grand Theft Auto™ IV for...
Intel cpu comparable to "Dual Core AMD Opteron 1212HE"
This is an AMD 2nd generation Opteron CPU, running at 2GHz. It is a single core device. So a comparison would be against Intel business CPU - the Xeon, again compare against a single core.
Apr 02, 2009 | AMD Opteron Dual-Core 1212 HE 2.0GHz...
Hilw,, what is the difference between atom and intel core duo processor??
The Atom is a low power single core processor, it is roughly same speed and similar microinstruction set as a pentium 4 single core, and uses far less power and produces less heath than a regular pentium 4.
The intel core duo is a dual core processor that uses 64-bit core duo (dual cpu inside) processor.
Mar 08, 2009 | ASUS Eee PC 900 Notebook
Want to up grade my cpu and ram to improve speed and program use.
Question#1 is my current processor duel core or single core , how can I know?
Intel Celerons are Single Core. You can also download and run CPUID (free) from http://www.cpuid.com/ No installation needed either , just run it!
Question#2 What kind of duel core processor in combination with new ram should I install?
I dont think your computer supports dual core. I cannot be sure without you giving me the make and model of the motherboard. Besides , a 3.33ghz Celeron D is a great processor!!!!
Memory - See http://www.crucial.com/store/listparts.aspx?model=Presario%20SR2150NX you can have a max of 2gb. You have 2 slots on the motherboard so its 1 gb per slot and the board takes DDR2 PC2-5300.
Here , you can expand to your max of DDR2 PC2-5300 2gb (2x1gb) for $24 and theres free shipping too!!!
http://www.crucial.com/store/mpartspecs.aspx?mtbpoid=03AC4AE5A5CA7304
Jan 07, 2009 | HP Compaq Presario SR2150NX PC Desktop
Dual boot problem
first install win98(dont re boot for xp installtion),  while running 98, insert cd of xp and install xp from there.
Nov 18, 2008 | Biostar P4M80-M4 Motherboard
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
89 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
