IBM ThinkPad T30 2366 PC Notebook
Problem for IBM ThinkPad T30 2366 PC Notebook
NO VIDEO
By mattman on Dec 19, 2006
Having a problem with my T30. recently my girlfriend dropped it. Since then I get no video at all. i've dismantled the laptop, checked all the connections, and even ordered a used replacement from ebay. still i can't get any video on the thinkpad's screen. The laptop starts up, and shuts off again within 5 seconds. However, with an external monitor attached, the laptop will boot and run perfect. even trying to switch to the internal LCD shuts the computer down immediatly. PLEASE HELP!!!!!!!!!!!
Comments:
Dec 21, 2006
- you can change the resolution, the drivers are fine, the computer just won't boot without the external monitor. AHHHHH! any idea's from anyone would be much appreciated. also is there any way to test my LCD's to see if they work for sure?
Same Problem
Jan 10, 2008
-   Sorry guys, don't know if it was clear what I said about my Dell Latitude, but the LCD screen started to work at the same time the external monitor started. When I pulled the external monitor, the LCD kept working. Until it was shut down and thereafter same problem.-   Texneth
Jan 10, 2008
-   I also dropped my Dell Latitude and experienced the same problem. Boots up to the Dell logo and then shuts down. After reading your problem, tried the external monitor and unbelievable, but it works.
After it booting up, I removed the external monitor and kept working until I shut it down, but again did not want to reboot w/o the external monitor.
-   Texneth
Best Solution
posted on Dec 30, 2006
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
sounds like a bad or broken lcd inverter
board. it takes the signal from the mobo
and sends it to the screen.
Should be located in the display hinge
or next to the mobo.
Replacements easy to find
Solution #2
posted on Dec 22, 2006
Helpful)
tomj23
Rank: Guru
Rating: 87%, 1813 votes
I've been pondering this for awhile but I think sandrew is on the right track:
-Probably not the LCD unless you were sold a lemon.
-Onboard video circuitry is working with external monitor so that?s not it.
Assuming a hard fall I'm more inclined to think that there is damage to or around the connector that the LCD plugs into. Could be a busted solder joint, cracked connector or a damaged printed circuit run near it but I think that?s where you should start looking.
Was this helpful?
Yes
No
Solution #3
posted on Dec 21, 2006
Somewhat Helpful)
sandrew
Rank: Wiz  IBM Expert
Rating: 83%, 5928 votes
It must be an integrated graphics problem, probably due to a damaged board.
if you have the correct drivers for the graphics, cant see it being anything else, although most people posting seem to have the same problem, it maybe something that has to be set up in the bios, but as we well know manufacturers only allow changes the simplest bios options, others are hidden.
Does the external monitor have the ability to change the resolution or is it just VGA mode, if it does then the drivers are fine, it's an lcd setup problem.
Was this helpful?
Yes
No
Solution #4
posted on Mar 02, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I am having exactly the same problem with my fujitsu siemens lifebook. There was a hard fall going through spanish customs. Will try the solution.
Popular Solutions for IBM ThinkPad T30 2366 PC
Questions and Unsolved Problems for IBM ThinkPad T30 2366 PC
Do you recommend IBM ThinkPad T30 2366 PC Notebook?
Answer
Answer
Hi, I need to know if a 333mhz ram will run on the 2366-1G motherboard of IBM ThinkPad T30 ... (More)
Answer
I can not restore my think pad back to any restore point. Why?
Answer
my account won't let me go to my emails for my confirmation code
Answer
when i turn it on only the battery light works what should i do and what is the problem
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For IBM ThinkPad T30 2366 PC...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
