Question about Saniflo Sanibest Grinder Pump Only 013
Saniflo not flushing corectly
I have a saniflo and it has been working perfectly,
today it has left some waste in the bowl,
If i throw some tissue in the bowl, the tussue remaons behind along with the waste!!
the pump seems to be working fine as the sink is draining and the shower is draining.
what can be the problem, i look foreard to your advice.
    Scholar:
  • 104 Answers
Does the shower or sink back up into the toilet bowel after running for a few minuits?
If not:
The bowel is clogged. Fill it with water then use a plunger
Posted on Feb 07, 2009
My saniflo pump turns on about every six hours or so on its own.what could be the ploblem?
Water pressure makes the unit kick on and off. Most likely somehow water is draining back into the pump. Check the flapper in the flush valve, inside the toilet tank and see if its leaking water into the bowl and from the bowl into the pump. Also, in the 90 degree discharge elbow there is a check valve with a rubber flapper that opens up to allow waste to pump out and it closes to prevent waste water from draining back into the pump. The check valve may be defective or it may be stuck open allowing waste water to drain back into the pump and is making the unit kick on and off by itself.
Apr 03, 2011 | Saniflo 002/005/007 Saniplus Toilet with...
Sanipro continuously runs,however, not pumping waste away and waste water has filled toilet bowl. Any suggestions
There can be a blockage somewhere in the discharge pipe, the blade or impeller. Also the short discharge pipe or long elbow inside the pump casing may be split open or not attached properly and waste water is just cycling inside the pump casing. Worst case scenario could be a bad capacitor, the capacitor spins the blade and impeller, it that goes bad the unit will just hum and not pump any waste out until is replaced. You can also order parts through Saniflo if needed.
Dec 23, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
System works perfect however the pump now has started turning on every 10 or 12 min and runs for about 2 seconds then shuts off
This means that water is draining back into the pump, creating enough water pressure that is making the pump kick on and off at all times. You need to inspect the check valve inside the discharge elbow where the waste is being pumped out, the check valve may be obstructed or may need to be replaced. Also check the flapper on the flush valve inside the toilet tank (water closet) the flapper may not be sitting properly allowing water to drain into the bowl and from the bowl into the pump.
Dec 08, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
We have a saniflo compact the toilet will flush 3 out of 5 times and the motor sounds fine but the other times when flushed it will sound like it is trying to flush and then just turns off at the end of...
This could be a problem with the capacitor that has gone bad or something stuck on the blade or impeller and is not allowing the waste to be pumped out. Typically when the capacitor has seized up or there is a clog on the drain pipe, blade or impeller; the unit will just hum and not pump the waste out and eventually back up on the toilet and overflow.
Sep 30, 2010 | Saniflo & Saniplus& Macerator Pump
Saniflo Top: Pump
indicates perhaps a faulty pressure switch. otherwise: this happens often in hard water areas due to build up of limescale. Use a descaling agent (acidic) to clean the saniflo - can be introduced via the toilet bowl.
Apr 02, 2010 | Saniflo & Saniplus& Macerator Pump
My daughter flushed he winter hat down the toilet. How do i get it out?
Kids eh?
.. I had my son flush LOTS of wipes down ours ...
*** STEP 1 ... DISCONNECT THE MAINS POWER SUPPLY!!!! ***
You'll need to drain the main toilet bowl of water and remove the toilet bowl away from the sanoflo. This may require that you also empty the cistern and stop the water from entering it (do you have an inline valve to the cistern supply pipe?)
When you have emptied the water and removed the toilet bowl there should be a large Jubilee clip attaching the saniflow to the WC waste outlet. Loosten this and remove it so you can see into the saniflo where the WC waste goes.
You should be able to see the object and reach it with your hands. I would suggest wearing some rubber gloves to protect your hands from getting gunk in cuts etc.
If you cannot get to the object, you'll need to empty out the other pipes to the Saniflo and remove the unit. When you have done this you'll need a star driver to open up the unit and get to the object inside. I would suggest that since most of the saniflo range have an internal grille to stop objects such as this actually hitting the macerator that you should be able to reach it just by disconnecting the WC waste connection
If this helps please leave feedback
Feb 09, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
Saniflo Sanibest Grinder Pump Only 013 Logo
1,172 people viewed this question
Top Saniflo Plumbing Experts
jasbo
jasbo
Gil Shultz
Vernon Taylor
Are you a Saniflo Plumbing Expert? Answer questions, earn points and help others
