Question about HP Compaq Evo n610c Notebook
Battery or ac adapter problems?
I have a used compaq evo n610c got from ebay. it came on for a little while then went dead. i cant plug in ac adapter because the tape on ac adaptert said bad so apparently it does not work either but i have tried different adapters i had here at the house and the battery charger light does not come on. should i buy a new ac adapter or battery or could the ac adapter connection on the laptop be bad. i dont know what to did work for 20 minutes when i got it it said i had 1hour 36 minutes on battery life left and to plug in the adapter but it dont work either supposingly. after i pluged in adapter thats when it completly went dead and wont come on.
  • HP Master
  • 4,338 Answers
The power jack on the system board may be loose or disconnect. The only way to check it is to plug in the AC adapter and wiggle the connector , if it feels loose then that is the problem. The other way to find out, is taking out the motherboard and checking it.
The fact that the battery was charged when you receive it tells me that the seller knew about the problem. He probably held the adapter plug in such a way that the battery got charged.
Posted on Nov 21, 2008
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
Sounds like you were cheated out of your money. Hopefully you just need to replace you Power Supply Cord and it will work fine because my guess it has broken wires and that caused the shutdown. If this does nit work, Your motherboard has been short circuited and this will never be fixed, it needs to be replaced and this is costly so it may be better to get whole new laptop. Buy a new Power cord and maybe a new battery if you feel you need to, but if they don't work, your laptop is dead
My compaq Evo n610c my battery wont charge when on ac power.The light for when the battery wont go on.
sounds like your DC coonector came loose from the system is a common problem with laptops,
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
here is how to repair:
Nov 26, 2010 | HP Compaq Evo n610c Notebook
don't waste money on buying second or used.
buy original from near HP store or order online. check HP center near
Oct 12, 2010 | HP Compaq Evo n610c Notebook
If i plug an ac adapter 19 volts 4.7amperes to my compaq evo n610c, will it broke
YES - the N610c uses hp power pack 402018-001 18.5vlts 3.5amp 65W 50/60hz -
Jun 16, 2010 | HP Compaq Evo n610c Notebook
Compaq N610c does not power on on AC adapter or on Battery :(
it might be that the AC adapter is no more working. To confim this, remove the laptop battery and test the AC adapter with the laptop.
You can also borrow a friend's AC adapter and test it with your laptop.
I wish you good luck.
Mar 03, 2010 | Compaq Evo N610C Notebook
Hi forum, I have been using Compaq N610c notebook and was working fine but was not power ON . on AC adapter but it was working on Battery. From last day, the battery become zero showing battery indicator...
It's possible that the AC adapter "died", and then your computer ran on battery-power until the battery went to 0%.
Or, the socket on the laptop where the AC adapter connects could have broken, or become disconnected from the motherboard, such that the power from the AC adapter was not being accepted, meaning that your computer was running on battery-power.
Take the AC adapter and the computer to a qualified technician, who can test that the AC adapter is working fine, and can disassemble the laptop, to inspect that socket where it connects.
Bios password n610c
Try this: -
Remove your Laptop Li-ion battery module.
Then remove the RTC battery for at least 15min.
Replace RTC, and boot the computer ONLY with the AC-Adapter.
Enter the BIOS and set to boot from USB
Feb 13, 2009 | Compaq Evo N610C Notebook
Battery installer
My compaq evo n610c have the following problem: "103 circuit charge failure" and use power AC only.
best regards
Sep 19, 2008 | Compaq Evo N610C Notebook
Docking station fror compaq Evo n610c
docking station for my old compaq armada did not "charge seperately" but did supply power to the pc through docking connector and not through the normal ac input, cant say if they have their own power transformers or not, till i go home and take my old docking station apart. Will the computer not power up when plugged in, it normally will run off ac power even when battery is dead or removed.
May 06, 2008 | Compaq Evo N610C Notebook
No power
You sound like you have either a dead power supply inside or a dead motherboard. Best thing is to open it up and test each. replace the culprit.
Feb 18, 2008 | Compaq Evo N610C Notebook
Laptop not charging
Unfortunately on most Compaq/HP mobile devices the AC pin is soldered directly onto the motherboard. If the pin is severely bent of broken off then a service is required, usually to replace the motherboard. Having the broken off like then can actually create a minor crack in the PCB. Sorry for the bad news.
Nov 17, 2007 | Compaq Evo N610C Notebook
HP Compaq Evo n610c Notebook Logo
112 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
