Question about JVC AV-32F476 32 in. Television
Delay with channel surfing
December 19, 2006 I got my JVC AV-32F476 32 inch TV four days ago, and hooked it to my Sony VCR yesterday. Today, all of a sudden, while surfing channels I noticed a delay and hesitancy before I got the channel. This did not happen when I entered the channels by using the number pad. At first I thought it might be that the remote control was damaged since it fell a distance of about one foot from the couch to the carpet, but the same thing happened when I used my VCR remote. Can anyone help me with a solution? I will add that this problem started occurring with my 20 year old Sony Trinitron, but only after 20 years, then the tv just collapsed. Sony thought it probably is a relay dysfunction. Should I return the JVC while I still can or is this a simple problem? Thank you very much. Layla
  • Layla Kaf Dec 23, 2006
    Thanks very much henlopen. I tried your solution, re-- programming it on cable, and it did improve it by about 30%. However, the problem still persists. Your diagnosis is absolutely right. I think that is exactly what is happening, however, unfortunately, the solution did not eliminate the problem completely. Question still remains, why is it doing it only on surfing when it does not when using the number pad.
    Oh and by the way, I had already contacted JVC Canada I came upon this site, and they have still not responded. May be Christmas season. Will wait till after Christmas to try again.
    Thanks again.
    Layla
    Sergeant:
  • 308 Answers
Two things I would check before contacting JVC. In the on screen menu does it have a setting under tuner controls to disable AFC? It sounds like the tuner is seeking the proper channel frequency before it locks it in and displays a picture. If there is no such setting, then I would try a channel autoprogram in the cable mode. I'm assuming you have no cable or satellite TV box hooked up to the set. JVC is usually a pretty good brand name.
Posted on Dec 20, 2006
We bought a used AV-32D305. It didn't come with the remote. We hooked it up to cable our cable box and it worked fine for three days. Today we turned it on and there's was just a blue screen with the...
hi
well to bad it looks like you have a bad tuner
I would suggest to use your cable box if you have a remote or it and connect your cable box in video mode or use a vcr in the same maner
Sep 30, 2010 | JVC AV-32D305 32" TV
I HAVE A MAGNAVOX TV MODEL 255102-OODD, A MOTOROLLA (VERIZON) SET TOP BOX MODEL QIP2400/1006 AND A JVC DVD MODEL DR-MV150BJ. I HAVE TRIED ALL THE HOOK-UPS SUGGESTED BY JVC AND STILL CONNOT GET A PICTURE. ...
ok, The issue will be in the sequence you have things connected. The connections sequence is going to be controlled by what connections are available. I assume the Set Top controller is connection to your Antennea connection on the TV. Your TV should be on channel 3 or 4. The next step depends on what type of connectors you are using for the JVC DVD. I have an Antennea output on mine so I connected them in series. If you don't have an Antennea output from teh DVD player you will need to connect the DVD using Audio/Video cables which means you will need to connect to the TV alternate Source connector and to watch DVD's you will need to change to that source. Much like you would switch between regular TV and VCR tape on a VCR player connected to the Antennea connector.
Sep 23, 2009 | Televison & Video
To Connect AV Cable from Panasonic VCR to Sony 29 inches
You can either connect the antenna output of the VCR to TV ant in or hookup the audio/video outputs from VCR to audio/video TV inputs. If using the antenna output you need to sellect channel 3 or 4 to view VCR. If using the adio/video lines you need to select the line input on TV to view VCR.
Feb 18, 2009 | RCA F20640BC 20" TV
JVC television-lost old remote-have universal /can't add channels
I don't have an answer for your question.
However, I do have a suggestion. You can hook up a vcr to your tv, then put the tv on channel 3 or 4 (whichever the vcr is set for) and change the channels through your vcr. You have to have the cable go first to your vcr and then out to the tv.
Dec 19, 2008 | JVC AV-27530 27" TV
Vcr does not run
Try changing the channels on the VCR itself. If you can do that, then it would indicate a problem with the VCR's remote. If you are still unable to change channels on the VCR manually, it could indicate a circuitry problem, for which you will have to get the VCR serviced.
Oct 25, 2008 | Sony SLV-685HF VHS VCR
LOST INSTRUCTIONS HOW TO HOOK UP MY DVD & VCR PLAYER TO MY TV SONY?
Sony maintains most manuals on their website. The general principle is to hook the cables from the video and audio OUT of the DVD/VCR player to the video and audio IN of the TV. Once the cables are hooked up correctly, just press the input, source, av, or video button on the tv or tv remote to change the television to the correct channel so that you can watch videos.
Jun 14, 2008 | Philips Televison & Video
Philips dvdr3575h/37 Initial setup
Do you have two cable inputs going into your player?
May 01, 2008 | Philips DVDR3575H/37
Problems hooking up a VCRplayer
Hello..try to turn on the test signal generator switch it is marked test at rear of vcr...and chose av¨rf channel on your tv i.e the 0 or 9 channel than search for the vcr and memorize on tv...alt you can playback a tape ..pre-recorded without the test signal and make the search...alt 2...use a direct av-cable between vcr and tv..which is best and put tv in av mode...good luck...Ron
Mar 11, 2008 | Televison & Video
MAGNAVOX TV MODEL CCT192AT01 FROM DECEMBER/1995
You need the original remote for that. Try "remote controls.com" and I believe they should have one. If not, let me know.
Feb 26, 2008 | Televison & Video
Hooking up a tv
Hi first of all are you using scart leads to plug into each device here is how it should be set up ok
1. Scart lead from dish network into vcr
2. then other scart from vcr into tv
3. Now ti recieve the signal from the dish network you need to have the telly on the right av channel so that its picking up the signal from the vcr.
you can test this by changing the channel on the vcr controll or direct via buttons on vcr.
If the channels change then your on the right av channel.
Now when your on right channel on telly you need to now make sure dish network is on and on a channel or press the tv guide button just so you know what your looking for when the picture comes through.
You need to press av on the vcr controll this will then pick up the signal from the dish network via the scart lead as av is the channel for scart lead.
say if you was recording from dish net to vcr you would put the vcr on av to pick up the signal so press av on vcr controll this should then allow you to watch the dish network with no problems.
Let me know if you still cant and ill assist you further if it dont work tell me what you have done so i know how much you have done ok
Feb 10, 2008 | Toshiba TheaterWide 46HM94 46" Rear...
JVC AV-32F476 32 in. Television Logo
340 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
