Question about Sony STR-DG500 Receiver
PROBLEM with my sony str-dg500 says error 20 and no sound
Just need help and don't now what details to give being i don't now what you need to now!
  • 35 Answers
SOURCE: no sound out of my
Were you playing it at a high volume when it quit playing?
Posted on Nov 21, 2008
BillB-SA
  • 2761 Answers
SOURCE: How can i use Sony 5.1 Receiver STR-DG520 in India (120V to 230V)
Sorry, but according to Sony this set operates only on 120 volts at 60 hertz. As we have no real need for up converters here in the USA, I cannot recommend one for your application. The best course would be for you to visit one of your local electronics stores and provide them with the specific current requirements. I'm certain that an appropriate converter is available in your area.
Bill
Posted on Aug 21, 2009
Testimonial: "Thanks,"
  • 88 Answers
SOURCE: My Sony STR-DG500 wont turn on just clicks once and nothing.
Sounds like faulty psu (pwer suply unit) Amp is going into protection mode. Disconnected all speaker and av wires (only power) turn up volume and see if it stays on. If not psu, sounboard or volume function faulty. If on, connect one speaker L or R. Go to tuner mode to tuned radio station an listen for sounds. If on, connect speakers and av cables one by one and test each one on its own until amp switches off, Investigate from there were problem is. Make sure speakerwires is not shorting out.
Posted on Aug 29, 2009
  • 52 Answers
SOURCE: I HAVE A SONY RECIEVER STR-DH700, I get no sound
make sure the FM antenna is connected and in a good place then check to see if the A-B speaker selector is selected properly.check to see that the sound field is set properly, My 800 allows for several different options and if your speaker wires are reversed or not in the correct position front left at front left etc it will not send the signal to those speakers. try using the TEST TONE feature if you have one it will send a signal to each speaker in sequence (LF< C< RF<in order) it will go all the way around to see if they are connected properly, that way you can tell if they are connected at all or in the wrong spot on the back interface. I dont know if that is what you meant by AUTO CAL, but that is a seperate feature when you use the connected mic to determine range, height and distance to the position in the room you are most likely to be seated for optimal sound.
Posted on Nov 29, 2009
SOURCE: no sound from Sony STR-DH500 when playing dvds with HDMI
no sound via hdmi cables, you must use optical or coaxial
Posted on Dec 18, 2009
PROTECT MODE
usually means a short in the amp section. Needs to be repaired before it will turn on properly
Nov 17, 2013 | Sony STR-DG500 Receiver
"protection", no sound. What happened?
Usually means there is a short in the amp. Would have to go in for repair.
Jan 17, 2013 | Sony Str Dg500 Stereo Receiver Digital...
On my sony STR-DG500 Receiver only the video 2 output works for video. I can hear all aother modes but no picture. Any guesses?
Double check all of your connections and settings on the receiver. You might also try resetting the receiver.
Aug 02, 2012 | Sony STR-DG500 Receiver
Need remote code to program for universal remote
Code 31518 should work on your Comcast universal remote here is a link good luck! http://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Oct 13, 2010 | Sony STR-DG500 System
Aug 29, 2009 | Sony STR-DG500 Receiver
Lock up
It probably is but may require a service person to physically open the unit up and do some testing/repair work which can be expensive if you dont know somebody or have the skills yourself.
Nov 08, 2007 | Sony STR-DG500 System
Sony STR-DG500 Receiver Logo
147 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
