Question about RCA P52955 52" Rear Projection Television
Bowed picture on rca p52955
My rca p52955 52" rear projection has a bowed picture. how do i fix this?
  • barbidoll Nov 21, 2008
    have a 52 inch RCA P52955 with same problem..bowtie picture with colors off
  • RCA Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See bebowed picture on rca p52955 - 69189a5.pngix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jun 06, 2010
Bowed in on both sides. colored lines everywhere
Open fuse/bad connections on HV ckt board and one or two bad capacitors.
Mar 22, 2010 | RCA D52W19 52" Rear Projection Television
I have an RCA HD52W67 and it just started to have
I'm having the same problem with my RCA HD52W67 rear projection TV and I've notice this problem is listed with my other owners of this product. I have no experience with fixing electronics. Sould I try this myself or take it to an expert? Has anyone fixed this problem? What is an estimated cost involved, if I take my set to an expert? Any advice with the HD52W67 is great appreciated.
Mar 19, 2010 | RCA HD52W59 HDTV Projection Television
OLD Hitachi 50EX13K rear projection TV now has bow shaped picture
Your convergence ic's have to be replaced along with checking all the bias resistors for exact value. Easy for me! I don't know what your electronics background is?
Oct 30, 2009 | Hitachi Televison & Video
Could use some help with a "bowed" picture on my RCA P52960
Is the convcergence ( Alignment) also off which gives the TV a 3D look around items on the screen? If so replace the STK730-130 on the convergence power supply
Jun 23, 2009 | RCA P52960 52" Rear Projection Television
Colors seperating and Screen bowing
The convergence circuit is not working. There are bad solder connections on the sweep board and a small fuse is open. this is not easily done yourself unless you have a technical background but an RCA tech can fix this easily.
Mar 25, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca projection tv is blurry
Find a large rifle and put it out of its misery. Bowing is either from a problem in the pincushion correction circuit or the convergence circuit. Blurry picture or poor color rendition is most likely bad CRTs ( picture tubes)
michtech
Feb 03, 2009 | RCA D52W19 52" Rear Projection Television
RCA Projection TV not working properly
All I need to know is how to shrink the picture!
Dec 21, 2008 | RCA P61830BL 61" Rear Projection...
BOWED PICTURE AND COLOR CONVERGENCE
You can replace the whole convergance board assy Part #239126 or 239126R and it should take care of problem.
Dec 18, 2008 | RCA P50830BL 50" Rear Projection...
Symmetry
Yes fairly easy to mess up sounds like a pin bow problem have you checked ay circuits
Sep 05, 2008 | RCA D52W19 52" Rear Projection Television
Rca projection
Conversion problem most likely. Do your conversion controls work both colors in all 4 directions.
Jan 04, 2008 | RCA P52926 52" Rear Projection Television
RCA P52955 52" Rear Projection Television Logo
344 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
