Question about Microwave Ovens
Loud noise coming from turn table
When we use the microwave it makes a loud rubbing noise from the rotating plate.  Is there something that we can use to lubricate that area so it will be more smooth?
  • rustycage Nov 22, 2008
    The microwave is an Ewave KOT152UW.  It was here when we moved in to the house 4 years ago.
  • William Miller
    William Miller May 11, 2010
    Lubrication is not recommended or required.
    As long as it's clean, it should not make any noise. It may be worn.
    How old is it?
    Please reply back with your brand and model number so we can help you.
  • Microwave Ovens Master
  • 9,098 Answers
The turntable system consists of the turntable motor, the turntable coupler, the roller guide / turntable support with rollers, and the glass turntable tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
It's important for everything to be clean and dry. Lubrication is not recommended or required. That would only serve as a bandaid.
If it doesn't work right, or it makes noise, then it is broken or worn.
For more help from Magic Chef / Ewave see here or their contact page or you can order replacement parts here.
Posted on Nov 23, 2008
    Problem Solver:
  • 19 Answers
I have the same problem my microwave is a kenmore this is the second one I've had and they both did it I solved the problem by re-seating the turn table however if you are skilled at taking things apart you can put a few drops of small motor lubricant on the spline it worked for me. good luck!
Posted on Nov 21, 2008
Unit makes a lot of noise when cooking.
The exhaust fan may be loose, {check mounts} also, the turnable motor that rotates the plate often gets noisey before seizing, {remove plate to see if noise goes away} and finally the magnetron gets very loud near end of life.
May 16, 2012 | Magic Chef MCD1311ST Microwave Oven
Frigidaire FMV145K 950 Watts Microwave Oven makes LOUD noise when turn table turns?
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 25, 2011 | Frigidaire FMV145K Microwave Oven
I have an Oster 1.2 cu. ft counter top microwave model OM1201E0VG. I purchased this model about a month ago. Every time we run it there is a grinding noise as the turn table rotates. I have checked...
There is still factory warranty on this and most stores wold even take it back if there is a problem. Please don't try and repair something that can be fixed under warranty or they will void the warranty. My advice is to put it all back to gether and then take it to the store you purchased it from and demand an exchange. They most likely will return it no questions asked if it is that new.
Apr 08, 2011 | Microwave Ovens
Intense squeaking noise
When microwave is running, turntable squeaking when rotating. Can problem be fixed? Microwave is about twelve years old.
Mar 07, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
JVM1440 BD - has a loud noise when I turn it on
Sounds like the "hub" for the turntable is worn. either that or the actual turntable motor. also insure the "plate" has a ring under it with wheels. sometimes I find those missing which in turn put far too much loud on the hub & motor, hence wearing them out pre-maturely.
you should be able to pull the hub out from inside the oven, if not. remove the filters below and if you twist just right you should see a small round device mounted with two tiny philips head screws, that's the turntable motor. It's usually the "hub" that wears though, so it's likely an easy fix. The most difficult part may be finding the new replacement part itself.
hope that helps,
good luck
Sep 26, 2009 | GE JVM1410 Microwave Oven
Ge above range microwave, when it is turned on it makes a rattili
is this noise a loud noise or low. and tell me the make and what the model. please
Mar 20, 2009 | Goldstar MV-1501 Microwave Oven
Unit making loud noise
your turning spindle must have warped due to high heat in oven
Dec 06, 2008 | Microwave Ovens
Microwave makes a loud noise while using.
Could you describe the noise?
It may be a noisy fan motor or a failing magnetron or high-voltage transformer.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Oct 13, 2007 | Microwave Ovens
Microwave Ovens Logo
617 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
