Question about Kitchen Ranges
Kenmore Elite electric range
I have a kenmore elite electric range. Model number 790.96593601. The cook top does not work, it gives a F- 20 error code.The service data sheet says to test harness connections P4 (EOC) and P7 (surface element control board). If harness checks ok failure can be caused by faulty UIB, Surface Element Control Board or EOC. How can i tell which one is the problem? What voltage should i have at the P-4 and the P-7 connections?
5 Suggested Answers
SOURCE: Kenmore Elite 790 Range
I can't believe I found this today. Today, my Elite 790 inner coil also stopped working! A little too coincidental.
When I turn on the burner, I can hear like a relay click on, but it does not heat. The middle and outer burners are fine.
Posted on Dec 21, 2007
  • 728 Answers
SOURCE: The hot surface indicator light remains ON all the time.
Your hot surface indicator light might have a short that causes it to stay on all of the time. If you can, try unplugging it for a little while and plugging it back up. If the light is still on, you have a short. You can still use the stove, but the light staying on will not be any help to you.
Posted on Oct 22, 2008
  • 1136 Answers
SOURCE: 0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
Posted on May 17, 2009
  • 1772 Answers
SOURCE: Kenmore Elite Electric Range 790.9912.3402 Had
yes, that could very well be the problem. cable or keypad
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 01, 2011
Testimonial: "Do you know of any way to test the keypad to determine if the problem is there, in the cable or in the controller?"
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
My Cook top will not turn on. All it does is beep when I try to turn on a burner. The oven does work.
is it in child safe mode? look for a picture of a lock near one of the buttons and hold it. if that does not work please provide a model number from the oven.
Jun 25, 2015 | Kenmore Elite 4.6 cu. ft. Slide-In...
My induction cook top was on high to boil (P6) when it let out an odd pop sound, the element shut down then an error code flashed across the dash: E035 - constantly beeping. I have unplugged the oven
Is there a chance that you transposed the first two digits?
KENMORE ELITE Electric Range Parts Model 79095073310
Manuals , diagrams and help.
Note you do not have to download manuals to read them. Click on the name to the left.
Oct 30, 2014 | Kenmore Kitchen Ranges
I have a sears kenmore elite slide in range model number 790.46613500 that has a f13 err can anyone help with this
Unfortunately, the F13 error indicates that the oven control has failed. First unplug your range and wait 30 seconds or more to reset the code.
If the error recurs, this part will need to be replaced. See for the parts list.
I'm not exactly sure if your unit needs part 97 or 97A.
I hope this helps.
Dec 08, 2012 | Kenmore Elite Sears & Other Brands...
F10 error on kenmore elite electric built in model 790.4907
Try unplugging the unit from the wall, wait 5 minutes and replug back in. I had same thing happen to me a few months ago. I had to leave my stove/oven unplugged for 24 hours to finally get it to reset itself. It is working fine now.
Aug 12, 2009 | Kitchen Ranges
What does error code 35 mean on a kenmore elite induction cooktop model 790.4290. I believe the unit is made for Kenmore by Electrolux
it has a fatal or error condition. try turning the power off and than back so it the cook top can reset it's self. if that does not work you will need to contact sears for service.
Aug 23, 2008 | Electrolux Kitchen Ranges
My kenmore elite electric slide in range displayed error and F13 and the oven won't turn on
i phoned Sears about error code f13 on a gas range, and was told to unplug the range for 30 minutes. i think she meant 30 seconds - to reprogram the microchip. i unplugged it for 15 minutes or so, then reconnected, and it worked.
Jul 09, 2008 | Kitchen Ranges
My kenmore elite electric slide in range suddenly had the word error appear and the code f13. The oven won't go on, but the range top works
Need the model number (specifically the 1st 3 digits ) too determine who manufactured it for Sears then can tell what the fault code means for that brand. You might try shutting the breaker off 20-30 mins see if it resets itself.
Kitchen Ranges Logo
138 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
