Question about Xerox XG-91D 19" LCD Monitor
Screen goes blank also.
Hello, recently my Xerox 19-inch LCD Monitor screen just went black. When I power it up the blue power light will be solid for approx. 5 secs and the screen will light up greyish-black, then the screen loses all light and the power LED flashes.
  • lunatm Mar 15, 2009
    Hey I've got the exactly the same problem as you, guys, but i have XA7-19i monitor, and the DOWN button doesn't work as reset button, i have tried all the buttons.. it takes effect only on MENU button, but no picture just few red,green,blue lines. Earlier i had the same problem but it fixed itself (it was working 3months perfectly) but now its black again and nothing seems to be helpful..
The thing with removing the power from the back of the monitor and holding the Down Button down whilst plugging back in the power does work. My 19inch Monitor was having the same sort of problem. White lines would appear as I turned on the monitor. I did the hard reset on the monitor and it works! I was awed and amazed.
Posted on Nov 26, 2007
I am in the UK.  I had the same problem.  Bought it from PC World with one years cover. 2 years later broke.  PC World didn't want to know, but could do me a good deal on a new one.  After trawling the internet and looking for reviews of the monitor I found out that there is a Manufacturers 3 year warantee on it.  Contacted Goodies Enterprises of Bedford and they could fix it for 56GBP, including shipping.
Very good communication with them - thank you Velma - and it took less than 2 weeks to get it back (next day delivery once it's fixed).  Fingers crossed it's sorted.
Posted on Oct 31, 2007
I have an XG92-D with this same problem. I took the suggestion of unplugging the monitor, holding the down button while plugging the monitor back in. Then I turned the power back on, and my monitor now works again! Thank you.
Posted on Sep 22, 2007
I have seen this on two 17i's now - I tried a 'DIY factory reset' (i.e. I guessed and tried several buttons until it worked !). All I did was pull out the power cable, hold down the 'down' button on the screen whilst plugging the power back in. This has cured this on both screens (including the one I'm using now !). I have no idea if this is a proper Xerox function, but it worked for me twice. The problem I was having (in case yours is different) was the screen would power up and display normally for about five seconds, then go black. Hope this helps !
Posted on Jun 20, 2007
  • 3 Answers
I too have an LCD Xerox - it worked fine for a while, then kept going blank and going onto standby. Unplugging and reconnecting from both pc and power seems to reset it. It hadn't happened for months but started again the other night when it occurred to me that I had just downloaded MS security updates - I've removed the ones that I downloaded just before it started happening again and the problem seems to be solved. Hope this helps someone.
Posted on May 27, 2007
Blue light on with blank screen dell SE198WFP monitor
It depends on what type of connection you are using. If you are using a VGA (analog) cable then you need to select that mode on your monitor menu. If you are using a DVI (digital) cable then you need to choose that mode on you monitor menu.
Nov 24, 2013 | Dell SE198WFP LCD Monitor
Screen goes black,power light stays green. display only stays on a couple of seconds
This happened to me and I was able to fix it. I cracked it opened and found a bad capacitor, bought a replacement at Radio Shack and I'm back in business. Actually using it right now to post this.
-Jon
May 27, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Xerox XA7
ccfl tube is destroyed or fuse on inverter board
Sep 01, 2008 | Xerox XA7-192i 19" LCD Monitor
ProView 19'' Widescreeen LCD Monitor problems
It guess it is upon the logic board is having problem.
Feb 10, 2008 | Proview PL926WBi 19" LCD Monitor
Screen goes blank
Screen going black would indicate a data flow problem- but then you would see a warning saying words to this affect or a back light/inverter problem. If by looking slightly sideways at the sreen you can see 'shadow images'[try a moving image to be syre] then you have a backlight /inverter problem If you see nothing at all ckecj the data cable pins- one or more may be bent
May 23, 2007 | LG L1910S (Silver) 19" LCD Monitor
Xerox XG-91D 19 in. Flat Panel LCD Monitor
Just tore mine apart so here is some help. You need to remove the two screws on the back of the case on the bottom. Then you remove the front cover it slides toward the top of the screen then lifts off. You can pry it off if that doesn't work. If you want to seperate the screen from the back cover you then need to remove the swivel mount and the other two screws from the back cover.
Oct 06, 2006 | Xerox XG-91D 19" LCD Monitor
Screen lit up, but nothing displayed (black)
Hello Frank, I have the same problem with my monitor. I don?t have the answer yet to resolve the problem. if you want the first of us who find the resolution will advise the other. I sent an email to Xerox to get the info to remove the cover without breaking it. regards Sylvain
Sep 01, 2006 | Xerox XG-91D 19" LCD Monitor
Xerox XG-91D 19" LCD Monitor Logo
620 people viewed this question
Top Xerox Computers & Internet Experts
Aditya Agarwal
saurav777
Level 1 Expert
Jim LeVerso - IT...
Jim LeVerso - IT...
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
