Question about Samsung HCN653W 65" Rear Projection Television
The TV turns on and off after a few seconds and repeats itself.
When i turn my tv on i can here it trying to work but i get no picture a little bit of sound. after 5 seconds it shuts off and immediatly tries to turn on again with the same result. it will do this until i turn it off myself. My TV is a Samsung model number HCN653W Manufactured in 2004.
  • 1 more comment
  • scottjo Jan 13, 2009
    were you able to solve with this fix? Service man was here today and told me that parts were not avail.
  • ifrejan Jan 18, 2009
    I replaced the 2 stk convergence modules part numbers STK392-040 and also replaced the vertical deflection output IC part number LA7845 and it did not fix the problem. It is doing the same thing. I do hear the sound amplifier clicking while trying to turn on.
  • Anonymous Feb 21, 2009
    I lost picture, the power button continues to power on, the sound comes and goes for a second only when it tries to power itself on.
  • 70 Answers
Hi.
Either the stk convergence modules or the vertical ic have failed.
replace the 3 parts and it should fire up again.
Posted on Dec 28, 2008
PICTURE GOES OFF AFTER A FEW SECONDS. SOUND OF TV
have youtryehave you tried going to menu options and turning off the power save you might try changing the scart cable any interferance will cause the tv to turn of. my little boy often knocks the scart lead on my set an the tv turns itself off when he does this ,. hope this helps good luck
Dec 11, 2010 | LG 42LG30 42 in. LCD HDTV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
There could be quite a few things that would cause the set not to power up. I dont have the service manual, however you can get a copy of the service manual at the following link for your model. As thats the only proper way to be able to check for the proper voltages to determine whats wrong with the set.
Heres the link.
http://servicemanuals.vstore.ca/
Nov 26, 2008 | Samsung HCL652W 65" Rear Projection...
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
TV turns itself off after a few seconds, no picture at all
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mar 28, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
MY TOSHIBA 46HM95 TURNS OFF BY ITSELF...
Sounds like earth problem with your Electricity. Your tv think there is some kind of a short then go in to protection. If i am wright, when you touch the ground and some applience, does it shock a little bit, if yes im wright.
Dec 15, 2007 | Toshiba 46HM95 46" HDTV
As far as fixing goes, you might as well get a new TV... Unless its a LARGE EXPENSIVE HOLY $%^# TV, It will cost more to fix, than to just buy a new one, unless its under warranty, which being an older model as that (or so im reading) It may not be covered.
Try unplugging the TV, and while unplugged, hold down the power button for a full minute (yes, with the plug NOT in the wall) after a minute, plug it back in, and try. Its a hard reset. If it still does not work, and you've tried different outlets, It's probably a repair issue, and you'll need to get someone to fix it, or just junk it :-/
Nov 11, 2007 | Sylvania SST4322 32" TV
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sounds like the typical Flyback and shorted horizontal output transistor. Problem is the transformer is NO Longer Available
Sep 13, 2006 | GE 32GT740 32" TV
Samsung HCN653W 65" Rear Projection Television Logo
167 people viewed this question
Jerry Greenberg
Jerry Greenberg
