LG WFT1071TP Top Load Washer
Problem for LG WFT1071TP Top Load Washer
LG WFT1081TP Top load washer
By erina on Dec 19, 2006
My washer filled and then shut off. I have tried unplugging and then plugging in again, different plug-ins, flipping circuit breaker, etc and still will not turn back on. Any suggestions??
Same Problem
Feb 06, 2008
-   same problem - filled then shut off- love to know if anyone has had it fixed yet-   stevesellon
Best Solution
posted on Jul 13, 2008
Very Helpful)
SOUDNISAY201
Rank: Apprentice
Rating: 100%, 3 votes
I WANT KATALOGE WASHING MACHIN MODEL ; WF-T1081TP BECOUSE MY KATALOGE MISSE
Comments:
Jul 13, 2008
- IWANT KATALOGE WASHING MACHIN MODEL :WF-T1081TP MY KATALOGE LOSEN
Was this helpful?
Yes
No
Solution #2
posted on Jul 10, 2008
Very Helpful)
jaguar007
Rank: Apprentice
Rating: 95%, 3 votes
my washer is dead, no lights on panel, Fuse looks o.k. solid white porcelyn.
Was this helpful?
Yes
No
Solution #3
posted on Mar 09, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
My washer stopped just before the rinse cycle and won't turn back on, I just opened up the control panel to see if I could find the fuse the previous poster referred to and was unable to locate it.
Where is the fuse, all I saw was plugs and I checked them, they are all tight.
Solution #4
posted on Apr 09, 2007
Helpful)
hienvo
Rank: Apprentice
Rating: 91%, 7 votes
Hi Erina,
I just had the same problem too. The washer never filled though, but it just won't respond or turn on. Have you fixed the problem yet? What was it?
Comments:
Apr 09, 2007
- Hi Erina,
I had the same problem with the same washing machine today. I just won't respond to anything and no lights. Have you resolved the issue on you washer yet?
Was this helpful?
Yes
No
Solution #5
posted on Dec 17, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Under the control panel there is a fuse, try changing that. My washer died too, and that was the problem
Solution #6
posted on Mar 11, 2008
Very Helpful)
rallupae
Rank: Guide
Rating: 92%, 6 votes
The fuse is located in a black cover.  You need to gently pull the front panel out of the way and look to the right of the unit, in the area under where the panel was.  There, you will see a black wire running into a black cylindrical case that has a black wire running out of the other end.  Heed the warning on the label, please, and make sure that the power is unplugged form the wall.  Gently pry open the casing and you will see the fuse within.  The ends of the wires just pull off (gently) and then you have the fuse.
Tomorrow I go on a fuse hunt and try this out.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #7
posted on Aug 12, 2009
Not Rated)
christine001
Rank: Apprentice
Rating: 0%, 0 votes
Where can I get the fuse (125V,12A) replace? Can I find the fuse in home hardware store?
Was this helpful?
Yes
No
Popular Solutions for LG WFT1071TP Top Load Washer
Questions and Unsolved Problems for LG WFT1071TP Top Load Washer
Do you recommend LG WFT1071TP Top Load Washer?
Answer
Answer
my lg washing machine wf-s6607tc soon after start washing it stops then spin and drain lights comes.... (More)
Answer
Machine cycle but over flow as if load sensor is broken , The machine does not complete cycle and... (More)
Answer
My fully automatic Fabricare LG machine just stops before the spinning process has to begin. We need... (More)
Answer
water accumulates inside drum and leakes out in my LG top loading machine
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For LG WFT1071TP Top Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14896
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
