Question about KitchenAid KERC507 Electric Kitchen Range
Code f2e5 what does it mean and how can i fix it
    President:
  • KitchenAid Master
  • 2,651 Answers
F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC)
Posted on Nov 21, 2008
  • Ron Coons
    Ron Coons Nov 21, 2008
    although teh e0 is different its still showin a short in the keypad assy and recomend replacingt the electronic control
What does code F2E5 mean. Keeps on appearing on the display window
F2 E5 - Cancel key drive line open.
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
let me know if this works.
Nov 03, 2017 | Kitchen Ranges
I have a maytag frontload washer 2000 series that will not start spin cycle won't even try unless the washer is empty. no error codes showing, even after I do diagnostics. help...wife is miffed..
After determining that the washer is plugged in, the drain hose is free from kinks, the "No spin" option is not selected and the washer door is securely closed, the cycle should be reselected to see if the washer will spin. If this does not solve the problem, it is advised to contact a trusted repair service. Problems with the lid switch assembly, drive belt, drive pulley, drive motor, tub bearing or transmission can also cause a Maytag washer not to spin. These repairs should be carried out by a professional.
If the washer is spinning but clothes are still wet at the end of the cycle, one should ensure that the washer is not overloaded or unbalanced and that the correct wash cycle is selected. Delicate or handwash cycles spin at a lower speed, resulting in wetter clothes
Oct 12, 2016 | Maytag Washing Machines
I have an Samsung airconditioning unit that flashes an error code NS0714DXEA is the model and the code is E 153. Is this something easy that I can fix myself or....
It mean Indoor Float Switch 2nd Detection,Self Diagnosys Error .check my shutdown the power and start after 10 min if it was not fix then its best option to call ur local technician to fix this.
Aug 18, 2016 | Samsung Heating & Cooling
What does the E3 code mean on the 540 model and is there a fix?
Troubleshooting the "E3" error code in Maytag MAH6700 ...
fixitnow.com/.../troubleshooting-the-e3-error-code-in-maytag-mah6700-...
Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
I have a samsung frontload washing machine. A code E3 is ...
www.shopyourway.com > Denise LaGrasse > Questions
Mar 15, 2014 - My samsung front loader is not working. do not no what E3 means. ...code F26 mean on a Kenmore Elite model 110.4708 washing machine?
How To Fix 3E Error Code On A Samsung Washing Machine
www.appliancerepairlesson.com/.../how-to-fix-3e-error-code-on-a-samsu...
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
Jan 06, 2016 | Washing Machines
What do p1000&p1151 codes mean & how do i fix them?
If your vehicle is a Ford the P1000 means emission system diagnostic is not ready, & P1151 means you have an emission system problem. You will need to determine and fix the problem causing the P1151 before the P1000 code will clear. The P1000 code requires several driving/operating conditions be met before it will clear.
Dec 29, 2015 | Cars & Trucks
F2E5 showed on the display and the oven turned off
The F2 E5 error indicates that there is a fault between the key pad and the control unit. (The wiring is giving an "open" fault.)
Press Cancel and wait 60 seconds. If the error recurs, you need to get behind the keypad and check that the wiring is securely connected to the keypad and the central control unit. Inspect the wires for any breaks. Check each conductor for continuity on each side of the wiring harness, if possible. Reconnect the wiring and press Cancel again. If the error recurs after 60 seconds, you'll need to replace the keypad or the keypad and control unit. (KitchenAid provides the keypad and control unit as a single assembly for some models.)
If your oven is still under warranty, contact KitchenAid for service.
I hope this helps. Please add a comment with the model number of your oven for details on the appropriate replacement parts.
Feb 17, 2015 | KitchenAid Ovens
What does the f1 code on whirlpool duet sport mean
think its a thermal fuse code not a hard fix and not expensive
Aug 22, 2014 | Whirlpool Dryers
Wondering what code F-- means on cabrio whirlpool topload mod. wtw66005w2 Thank You
Is there a number after the F code?
Thats ok heres what the code means: Whirlpool Cabrio Washer Fault Codes.
Means primary control failure and to resolve this you'll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part.
Hope helps.
Aug 03, 2011 | Washing Machines
Error F2E5 on Kichenaid oven
F2 - E1 Keypad cable unplugged1. Check keypad connector for firm connection (keypad connects to control board).
Apr 01, 2010 | KitchenAid KERC507 Electric Kitchen Range
Oven press start no.flashing f2e5
Bad connection between the touch pad and ERC (electronic range control). Check for loose connection between the membrane and the erc. Turn power off for 10 minutes and test. If problem recurrs it is usually the touch pad. It can be both the touch pad and erc so we allways hope that you model has both parts in one assembly, otherwise the costs can be too high especially when there is no accurate test to determine which part it is if you have seperate componets. Appliance Specialists
Dec 10, 2009 | KitchenAid KESC307 Electric Kitchen Range
KitchenAid KERC507 Electric Kitchen Range Logo
307 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
