Question about Panasonic CT-27D12D 27" TV
I can not get the expanded cable with this TV
I have been trying to work on my nephews Panasonic CT-2??? tv it doesn't have a manual but it does have a remote when it isn't hooked to the cable it gets channel 3 and 4 but when I connect it to the cable box I can't get any channels but if I bypass the cable box I can get the regular cable channels but in order to get the expanded cable I have to have the tv on channel 3 but it will not allow me to add the channel. I've done many scans auto and manual but 3 and 4 will not come in. Do you have any secrets to get channel 3 on so I can use box to get the expanded cable? And there are not reset buttons on the back of the tv or box that will let me set it to channel 3. Thanks
  • 10 Answers
SOURCE: dvd recorder panasonic dmr-es20
run cable box through dvd recorder
Posted on Aug 25, 2007
  • 93 Answers
SOURCE: cannot program cable to tv
if your are using a cable box,all of your channels will be control only on the cable box.so, what you are going to do is use the remote control of the cable box.
Posted on Nov 07, 2007
  • 47 Answers
SOURCE: Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Posted on Apr 05, 2008
SOURCE: panasonic CT-32SL14 flat screen tv stopped working
I dont know if this will help anyone....but I opened the TV up and found a blown fuse right wherer the power cable connects. I replaced the fuse and while doing so noticed alot of dust and what seemed like part of a spider web. I got a can of compressed air and cleaned it up. Once I put in the new fuse the TV worked perfectly.
Posted on Aug 12, 2008
ShadeTek
  • 81 Answers
SOURCE: Can't change our Panasonic TV channel to watch DVD input
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
Posted on Nov 10, 2008
Panasonic tv model CT-20G10T doesn't work with my cable
1) test the cable with VOM for continuite, you must see is closed in VOM see the diagram. contrary case is open and replace, and proof.
God bless you
Jul 10, 2012 | Panasonic Televison & Video
My Panasonic CT 2521 HDB needs to be reprogramed
Reset it to its factory default, and then reune it. Refer its user manual for details.
May 07, 2012 | Panasonic CT-34WX54 34" TV
The tv doesn't turn on. checked power and both dvd and cable box work.
Obviously you must make sure the power is plugged in.
You should also try to get up and manually operate the power
switch on the thing, to be sure some of the 'StUpId' things aren't the actual problems.
I could be the remote!
When all of this is for sure, call a tech. Its big and dangerous for you to get into the back of.
If you were in VB you could ask me.
PLEASE RATE THIS ANSWER
Aug 29, 2011 | Panasonic CT-32E13 32" TV
The sound doesn't work on T.V. It does work on video or c.d.
This is problem due to the cable being loose on the back of the T.V. that connets your T.V. to the Cable Box providing your television service. If this does not correct the problem then try calling your service provider; it is often a problem with the connection between the BOX and the T.V. rather than a problem with the T.V. itself. If DVDs and CDs are working as well as the sound for these than it is definitely a problem with the BOX-T.V. connection.
Try removing the white cable from the T.V. and Cable Box and then re-connecting them slowly until the metal twisting connecter is on tight. Hope this helps.
If not, write back and I can walk you through another option.
May 13, 2011 | Panasonic CT-27D10 27" TV
My Panasonic CT-27SC14 tv won't turn on. worked fine last night. The cable box does but nothing happens with the tv..whether I use the remote or the power button. Unplugged it from the power source and...
hi,disconated from AC main. if you know bit of repairing tv and soldering? this what to look for main power board. 1 x dry joints 2 x leaky capacitors just remember when changing cap's make sure to use the 105' and same value.
Feb 04, 2010 | Panasonic CT-27SC14 27" TV
How to dismount ENG36604G tuner from CT-27D11 27" Panasonic TV
With difficulty.
Soldered to board.
Only qualified techie can do it.
Oct 05, 2017 | Panasonic CT-27D11 27" TV
Not receiving commands from the remote. (Panasonic Panasonic CT-34WX54 HDTV)
Your using a universal remote from what U am understanding, Two solutions for ya
1)diffrent remote all togeather from radioshack
or
2) the Tv's IR is not working
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Panasonic CT-27SL14 27" TV
Panasonic CT-32SF36 isn't getting video from A/V receiver
Hello, I hope this message can help you, After reviewing the Panasonic TV info, and the Yamaha reciever info., I have found on page 19 of your owners manual for the Yamaha reciecver that you can connect the the cable box HDMI cable to the reciever, but the reciever needs to connect to the T.V. HDMI.
I see your T.V. has S-video in and your reciever has S-video out, what about your cable box if it has S-video than I would connect all your device together through the S-video jacks.
A further note is you can't down grade the signal from the cable box through the reciever to the T.V., so even though the technology is there on your cable box, it's not there on the T.V.. On that note there is 2 options 1) buy a new T.V. with HDMI inputs. 2) connect the system together using S-video or component cables (RCA). It will give you almost the same quailty if you use good cables. I hope this will help you and I look forward to helping you in the future.
Jan 14, 2009 | Panasonic CT-32SF36 32" TV
Sometimes remotes have a switch to select tv,vcr,or cable,amke sure the remote is in the tv mode,other than that rare but remote receiver go bad and they have to be replaced,but before you call for assistance make sure the remote is communicating with the TV.It could be still good with other devices and not with the set.
Sep 27, 2006 | Panasonic CT-34WX54 34" TV
Panasonic CT-27D12D 27" TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
