Question about Epson Stylus Pro 7600 InkJet Printer
How to change the pump cap assembly and where to buy a new one
I am also getting little ink streaks on my prints. The printer has been idle for at least a year.
  • jhlubek Nov 21, 2008
    How to change the pump cap assembly ..is there a manual available
    The manual tells you to clean cap, check wiper blade, etc but does not tell you how to do it.
    Sergeant:
  • 276 Answers
Follow the instructions 1)remove the right side cover . 2)remove the flushing box. 3)remove the trigger assembly end piece and spring. 4)
Posted on Nov 21, 2008
  • smarttech Nov 21, 2008
    for A to Z instructions .just click this link .
    and go to page number 91,92,93,94,95
    the instructions of removing the pump assembly cap and refitting the new cap and pump assembly is explained in detail just read the instructions and follow the easy steps with diagrams and proper picture.
    http://www.inkjetcolorsystems.com/downlo...
    this is the link just click the above link.
    thanks.
  • Epson Master
  • 19,396 Answers
To remove the Cap and Pump do the following
Remove the right side cover.
After removing the Right Side Cover you will find four more screws to be removed. The four screw are loacted at the back side of the Printer.
Undo the 4 screws to remove the Cap and Pump assembly.
  • Ginko
    Ginko Nov 21, 2008
    After
    About cleaning heads and cap, you clean them by removing the parts and soaking them on isopropyl alcohol, or cleaning solution.
    To clean heads you can also use cleaner cartridges.
  • 849 Answers
The ink of cartridges may gone dried in a year time, better to replace cartridges or refill them.
  • 758 Answers
I was able to locate a manual for you..I hope that works..
http://www.jesseheap.com/EPSON%207600_9600%20Field%20Repair%20Guide.pdf
Please rate accordingly
Thank you
Computerrep
  • Epson Master
  • 4,338 Answers
Here is a free field repair manual on your unit. Pages 12-15 deal with the Cap assembly, Pump and printhead:
http://www.eserviceinfo.com/downloadsm/17523/epson_stylus%20pro%207600.html
Let me know if you need further assistance,
Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
    Master:
  • 505 Answers
Open the cover and then take out the ink cartrdiges. Using a nozzle sparay and a soft cloth clean the head where the ink cartrdiges sprays ink. Also clean the colour cartridge head to make sure there is no dried ink. You get such spray in the market.
This will resolve the issue. Also make sure the roller is also clean.
Thanks
Streaking on photo plots on a 1050c
Streaks can come from several sources. Since you said they appear near the end of a plot, the print heads may be running out of ink before the end of the job. This would happen if you had air in the ink tube system and consequently in the heads. When the printer is idle for a while, ink will migrate to the bottom of the print head so when you print again it is ok for the first part of the plot and then gets to the air bubble.
Open the back door of the plotter and look for air bubbles in the ink supply lines. If air is present, it needs to come out. There is a purging tool at Designjet Ink Tube Priming Tool . The print heads may need to be replaced, but not before the tube system is clean.
May 25, 2012 | HP DesignJet 1050c plus InkJet Printer
I have an Epson stylus photo 925 printer. It is only printing out the top half of pages. Any solutions?
This is usually caused by the purge unit or capping assembly. Epsons have a bat habit of the purge tube falling off of the bottom of the capping assembly.
The purge unit is used the **** a little ink out of the printhead. Inkjets do this to keep the nozzles full of fresh ink. Sometimes the hose will come off of the bottom of the head capping assembly on the top of the purge unit preventing the purge pump from having any effect. This assembly should be on the right side inside the printer where the head sits when the machine is off. If you can get the head to move to the center of travel you can unplug the machine, shine a light into the right side and inspect the assembly. Depending on use it could be quite dirty with old ink making it difficult to inspect. If the rubber cap is missing or misaligned, or if there looks like there is too much old ink you should be able to tell with the visual inspection. If the tube has come off the bottom of the assembly you may be able to see that as well. If you just cannot tell, you'll have to decide if you want to try new ink cartridges or not. This can be an expensive test, but often just old cartridges can cause similar problems. If not, the machine would have to be disassembled and have the purge unit removed for a closer inspection and cleaning or repair.
Oct 07, 2010 | Epson Stylus Photo 925 InkJet Printer
My pictures are getting yellow streaks as they print out
If you are getting "yellow streaks", run the Kodak "print-head-cleaning" software, to see if that helps.
Be sure to compare the cost of "repairing" the printer to that of buying a new printer (that would use the same ink-cartridges).
Jul 03, 2010 | Kodak EasyShare Thermal Photo Printer
Lexmark z2300m....black printing suddenly started streaking. Prints first 6 lines then streaks on rest of page. Nozzle cleaning and manual cleaning didn't help.
Your best bet is to buy new ink cartridges.
Ensure that the entire assembly is cleaned thoroughly though, just to be sure. Nozzle cleaning is rarely useful.
Apr 07, 2010 | Lexmark Z2300 InkJet Printer
Red is printing very light and streaking. The other colors print
1.clean the printer head using printer service utility
2.Buy a new catridge and fix it
note: if you are not use the printer the ink will be dry.so it cant able to print
Feb 12, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Faded-out streak
check your ink levels. if its the ink that came with the printer it is probable running out of ink. they do not give a full cartridge with printers, only about 3rd full. also try cleaning the heads. and try changing your printer settings/prefrences to less ink, more drytime see if that helps.
Apr 26, 2009 | HP LaserJet 1018 Printer
Epson 9600 magenta won't print - have new cap assembly installed
The ink should come out of the cart. if not the cart is the problem at this point try anothere magenta if that does not shore it up then you need to then start looking at the print head where it goes it itself now the store you bought the ink from will give you a replacement no questions asked sometimes even if you dont got the reciept. Try those steps you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 23, 2009 | Epson Stylus Pro 9600 InkJet Printer
Canon Pixma IP4000 - will not print. Did maintenance cleaning and the 3E was not showing solid lines. Cleaned many times and finally took out ink & print head and cleaned off a bit and now won't show...
I'm not sure what you did. We have 3 MP780 and IP6000 and 9000 printers. The frequent problem have is streaking usually w/ refilled cartridges and even new cartridges. This is what we usually do:
1. Take the printhead out and dip it in 1-2mm depth hot water. Hopefully the water changes color and clears up the clog. Keep the Circuits dry. Wipe off excess water when you are done.
2. For really difficult clogs, if the hot water doesn't work I find a small rubber hose and syringe that encloses(meaning air tight) the mesh in the printhead where the ink goes in. I then pump air in to clear out the clog.
3. Since you have to do it for the Black 3e, you might as well do it also for all the others to make sure they are not clogged.
Make sure when you pump in the air the syringe is not touching the mesh in the printhead. If these don't work then you can try borrow the printhead of another printer and testing it out. If it works then you need to buy the printhead. If Canon has stock, you should get it fast. If not, and you really need to print either go to a printing service or buy a new printer. Good luck.
Nov 13, 2008 | Canon Office Equipment & Supplies
Canon Pixma 600 printer showoing a green streak
You may running out of the colored ink.. just make sure you change it before it runs out.. make sure you buy a colored ink for Canon Pixma iP1600.. the cartridge of the colored ink of your printer has a number infront of it.. eg: Canon CI-41
Sep 21, 2008 | Canon PIXMA iP1600 Printer
DeskJet 9800 Streaks in Color Print
That is the problem, you need to expost the track wheels and clean them with a paper towel soaked in rubbing alcohol.
Jun 27, 2008 | HP DeskJet 9800 InkJet Printer
Epson Stylus Pro 7600 InkJet Printer Logo
791 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
