Question about Sharp R-1480 Microwave Oven
Micro/convection stops every minute
I have a convec/micro model r1870 and ity stops every minute on the dot why?
  • Sharp Master
  • 9,098 Answers
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you. You will need the free Adobe Reader to view or print it.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Posted on Nov 21, 2008
I have a Sharp R1870 micro/convection unit. unit kicks off after 60 seconds. have to restart then kicks off again in 60 seconds.
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
See the attached sample drawing for a typical damper assembly.
I have the applicable service manuals for these models and have uploaded it to my site here and here to help you.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 04, 2017 | Sharp Microwave Ovens
Sharp microwave r1870 only runs for 59 seconds
If it consistently runs for exactly 59 seconds, and shuts off, it's probably the control panel.
If it runs approximately that length of time, you might have a defective thermal protector on the magnetron, or the magnetron is running too warm for some reason.
Mar 24, 2016 | Sharp R-1870 Convection/Microwave Oven
My Sharp Micro Convection Model R1870 fan behind the touch panel keeps running for 50 seconds after the microwave turns off,. this is not the vent fan. it also runs for 50 seconds when you turn the...
If the fan seems to run even after the microwave had completed the cycle, then it is possible that the drive to the fan is having a time delay. Also it has to be made sure that the magnetron has been cut OFF power or else it is not a good situation. You will have to remove the control panel and check on the board, check the drive to the fan, since the processor cuts off the fan and magnetron at the same time the fan circuit must be traced. Look to the circuit after identifying the fan wiring and back check using a multimter if you are able to trace. If not take help as this can be harmful in case the microwave works till the fan cuts off. A faulty capacitor on the board can create this time delay.
Oct 11, 2011 | Sharp R-1870 Convection/Microwave Oven
My sharp microwave/convection oven come on, clock counts down but it does not heat nor does the turntable turn. About a week ago the breaker was tripped by it I think but it was fine until now. It doesn't...
It sounds like one of the door micro switches is bad. There are three micro switches typically. A primary interlock, a secondary interlock and a monitor switch. It is most likely the primary or secondary interlock switch. You may need to take your switches to a professional appliance shop to determine which one is bad.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 22, 2011 | Sharp R-930AK Convection/Microwave Oven
My sharp R1870 microwave/convestion oven turns
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Apr 26, 2010 | Sharp R-1870 Convection/Microwave Oven
Our microwave/convecton turns itself off after about a minute
Feb 05, 2009 | Sharp R-1870 Convection/Microwave Oven
The oven/microwave turn off after about a minute
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door could be jammed.
Many models stop after 59 seconds if there's a problem with the damper saystem.
We have the applicable service manuals for your Sharp model and have uploaded them to our site here and here to help you.
You will need the
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
For the Amana, There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts for the Amana by entering your full model number here.
The Amana's damper switch is called "interlock switch" and is located at ref# 15 in drawing #5. The damper motor is ref # 22.
Nov 29, 2008 | Microwave Ovens
Sharp R-1480 Microwave Oven Logo
131 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
