Question about Whirlpool Duet GHW9150P Front Load Washer
Washer won't start
The little black button in the inside of the door broke off and now the washer will not start, how do you fix this problem?
    President:
  • Whirlpool Master
  • 2,651 Answers
Youll need to repalce the latch assy, part number 8192634. simple repair, remove outer door spring( holding the rubber boot on, then unscrew 3 torx 15 scres holding latch to unit . the latch will pull out throughte front after pulling boot back. 3 wire harness to reconnect.
Posted on Nov 21, 2008
MHWC7500YW0 maytag washer will not start
I have had the same problem but in my case the button above the door latch was not getting fully depressed when the door was closed so the machine did not think it was closed. Temp fix, I used a paper towel folded in 4ths and put just enough inside the door to press in on the button a little further and that worked.
Aug 12, 2013 | Washing Machines
How much would it cost to get front driver door fixed that won't open on inside on 2009 Ford Fusion
need to take panel off and check the little plastic clip that hold the rod in place probably broke or fell off
Feb 26, 2013 | Ford Fusion Cars & Trucks
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
see this causes and fix it. God bless you
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
Machine turns on but won't start
this means that the door is not shut check to make sure the door button is still there its behind the door on the frame you should see a little black button sticking out if its not there you need a new door switch if its there try pushing the door button a couple times really fast sometimes this button gets stuck if that doesnt work its probably your door lock
Aug 27, 2012 | Kenmore 44102 Front Load Washer
My kenmore front load washer doesn't want to start all lights are working but nothing happens even the door won't lock
your door switch is the problem,where the door latch goes into the machine a little switch sites behind this a safety feature and if this is broke the machine will still switch on but will not work it will need replaced they are cheap.adrianxxx
Jun 02, 2012 | Kenmore 44072 Front Load Washer
My son put a load of laundry in and forgot the hot water heater was broke when he turned the machine on. It wouldn't run and the door is still locked. We tried unplugging it, holding the cancel butt
Remove the lower panel by taking out the screws at the bottom. Unplug washer. Then reach up inside to the bottom of the door switch and pull down on lever to unlatch the door. Try running machine again after plugging back in.
Nov 10, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a 1998 ford explorer and sometime at the same time the windows won't go up or down and the dome light won't work and the windshield wipers won't work what can it be?
  • You need to open up the drivers side door and look at that harness that stretches between the door and the door frame. Inside that harness are the wires for the electronics in the cabin and then some.
  • Over time those wires get pinched and crack and break. So you need to splice the casing (or just simply slide the harness to one side and then the other) open the long ways and inspect the wiring. Your looking for broke, split, rusted, bulging or otherwise negated wiring. The boots on either side may need to come off to look up inside for broke wires as well. Usually it's pretty evident which wires are messed up but sometimes you have to do a little digging.
  • When you find the broke wire[s] splice some new wire[s] in and use electric tape to re-insulate.
  • This is a common problem across the board with many car manufacturers and repairing the harness almost always is the fix in a situation such as yours.
  • Hope this helps.
Oct 28, 2011 | 1998 Ford Explorer
The contact button (part where you put the door down to make the washer start to agitate) something came apart....washer is filled with water and now won't go. The part came out.
you broke the lid switch,send the full model number located under the lid,lift the lid up,follow the lid to the bottom and look right under it and you'll see the model number,it will start with like 110.
Aug 30, 2011 | Kenmore 22422 Top Load Washer
He3 washer will not start. The lights on the
you probably broke the door switch and the machine thinks the door is open. little piece on top of the lock catch. need to change the door switch
Feb 05, 2010 | Kenmore Elite 45986 Front Load Washer
HE3t wont start
open the top access panel, 3 screws in top rear.
start washer
push up gently on one of the center black wired connectors that connect to the control unit (in back top of washer)
if it starts to work then the relays on the control circuit board need to be re-soldered . a normal reoccurring issue
its rarely the latch
Mar 21, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
91 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
