Question about Parkinson Cowan SG556 Gas Kitchen Range
Ignition sparking repeatedly
The oven ignition keeps sparking when the oven is lit, especially on low sttings
0 characters
1 Points
I need to know how to light the oven? Does it have a pilot light like the stove top
most stoves do not have pilot lights but work from a pizo ignition system
when you turn on the gas knob ,the first action is to energize the pizo and that continually sparks to ignite the gas at the hob
the same is with the oven
ovens should be lit with the oven door open and once lit then the door can be closed
Jun 07, 2015 | Sears 61301 Gas Kitchen Range
Oven igniter will not quit sparking when pilot and burner is lit.
Hello & Welcome to FixYa
The problem seems to be with the spark module as it won't quit sparking, another thing to check before spark module replacement is the ignition switches. Please get back to me if you have any other questions.
Jan 12, 2011 | Hotpoint RGA524 Gas Kitchen Range
My stove lights very slow with a low flame. Should the igniter stay on after it lights oven
Yes the ignitor stays on even after the burner is lit. The ignitor is wired in series with the oven valve. It sounds like the oven valve isn't opening all the way. A new ignitor should solve this problem. The old igniter builds up resistance and doesn't let the correct voltage through to the oven valve for it to open properly.
Aug 16, 2010 | Magic Chef CGR3725 Gas Kitchen Range
Oven won't ignite
Your range is a Direct spark model.ce00970.jpg8278a1e.pngIf you want a Direct spark manual, let me know. The module gets confirmation from relay on the oven control and sends dc power to the gas valve. I suspect that gas valve be cause the top burners work which is usually and indicator that the module is fine. The terminals ohms should be 216 ohms between each of the 3. If any are open the valve won't work.
Jun 01, 2010 | Whirlpool GS460 Gas Kitchen Range
Igniter in oven will try to ignite. Hear gas flow. Can see spark on upper burner assembly but it does not ignite. Use custom broil and it will ignite the upper burner but will not stay lit after ignition...
the ignitor may be faulty and not pulling enough power to keep the as valve open in order to light them oven, even though it is getting red or glowing the power is not enough.try and replace the ignitor
Jan 24, 2010 | Whirlpool GS460 Gas Kitchen Range
Oven won't stay lit
Welcome to Fixya
My name is Huum,
The igniter is bad even if you see the spark.
the igniter must first get red hot with enough amps to ignite the gas or the valve will not open or if ope it will shut off!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Jan 01, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
My oven - St George UGM-4 model - won't light. I don't know how old the oven is. There have been problems for a while, with the flame going out after about 5 minutes when it's first lit (it makes a...
this one is hands on fix,many times the spark ignition the one that makes the clicking noise is clicking on a different position,so you most look inside the oven to see the spark, you can see it better at night or when is dark to see the spark, that spark is right at the tip of the oven pilot, make sure you see the spark lighting the long as the pilot does not ignite.the clicking sounds continues making the noise. if the pilot lights the noise will stop, if the oven burner does not light after pilot is being for about 1 minute and a half the safety valve needs replacing
Dec 06, 2008 | Kitchen Ranges
Often times you will have problems with the gas thermostat and not necessarily with the safety valve. Once you have lit the pilot light, turn the oven knob to any temperature. The pilot light should get bigger in size of flame. If not, the thermostat that controls the oven must be replaced. If the pilot light does get bigger, but the stove does not ignite, it is the safety valve.
Nov 12, 2007 | GE JGBS07PEAWW Gas Kitchen Range
Parkinson Cowan SG556 Gas Kitchen Range Logo
Top Parkinson Cowan Kitchen Ranges Experts
ray gallant
Dan Apthorp
Are you a Parkinson Cowan Kitchen Range Expert? Answer questions, earn points and help others
