Question about Jensen JMC-600 CD Shelf System
Drive belt part #
I need two drive belts that raise the cd and cassette covers and possibly the left (CD) cover that is cracked. Thanks in advance. Happy holidays to all.
2 Suggested Answers
SOURCE: where can i get drive belt for cassette player?
solved it
Posted on Dec 27, 2009
Changer states checking disk, error
Possible broken drive belt, that's what caused the same error on my unit. Very easy to replace, just take off the top cover and the motor and belt are readily accessible.
Feb 03, 2014 | Technics SL-MC700 110-Disc CD Changer
When i turn my technics cd player all i see is error
Technics CD Changer SL-MC400
The ERROR Is Cause By The Belt Drive
Remove The Cover And You Can See if
The Belt is Lose or slip of In Any Case
You Must Change That RUBBER DRIVE BELT.
Dec 31, 2013 | Technics SL-MC400 110-Disc CD Changer
Sony TC-138SD cassette deck starts to play then stops after 3 secs. Same when trying to rewind/fast forward
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
Aug 15, 2011 | Sony CASSETTE DECK Single Dual Cassette...
Cassette player doesnt play or record, ff or rewind. CD player, AM/FM radio works fine.
Hi.
If you hear a faint whirring sound from the cassette player while performing these functions, the motor is fine, but you require a new drive belt/s that need to be fitted at an electronics shop. If you hear not sound at all, the motor has died (possibly belts too), again it will require and electrinics repair shop visit.
For the sake of repairing it, it maybe cheaper to buy a new one.
Jan 14, 2011 | Memorex MP3227 Radio/Cassette/CD Boombox
Disc belt needed
You need only measure the diameter in MM and put that and "CD/Cassette drive belt" into google and you should find a supplier. A few MM either side shouldn't make difference. Drive belts etc are none specific makers by the way.
May 31, 2010 | Sharper Image SA265 Shelf System
Broken drive belt on cassette player lbt g2000 how
just go to a good electronics store i bought a pack of ten assorted belts today for $7.97 at **** Smith Electronics
May 16, 2009 | Sony Audio Players & Recorders
Streched CD drive belt
turntableneedles.com has about 450 belt sizes in stock. your unit is too new to have this listing yet as the belt should not have failed already so when you call be ready with the length of the old belt. Don't worry that it is stretched, a new size will be calculated that is about 3-5% shorter.
Jan 13, 2009 | Philco 841205 Turntable
Drive belt for a HH957 CD player
Found a belt at a local dealer.
Aug 02, 2008 | RCA RS2605 CD Shelf System
CASSETTE DECK
Sounds like another case of a slipping belt. A belt usually runs off the flywheel and actually lifts the head assembly into the play or record mode. Due to the pressure involved it's either that belt or the main drive belt which is slipping or completely snapped. BMW
Dec 12, 2005 | Aiwa XR-MD100 Shelf System
Jensen JMC-600 CD Shelf System Logo
18 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
