My card reader on my gateway laptop used to work but it no longer does. Nothing shows up in my computer. I have not installed anything recently other than microsoft updates. I am running windows vista home
  • coldform Nov 22, 2008
    What would it be called?
  • coldform Nov 23, 2008
    The model Number is ML 6720. My quick acsess buttons(the ones for muting and vol. up and down, and playing cd's) on the top stopped working as well(much earlier) do you think they are related?
    Master:
  • 505 Answers
Go to the device manager, Uninstalled the device and then restart the computer. The driver will get installed automatically and then it will work again.
You can also uninstall the updates and then check. If its a problem with Windows update then dont install the updates for the time being. Wait for more patches to be introduced from Microsoft.
Thanks
Posted on Nov 21, 2008
  • Indrajit Roy
    Indrajit Roy Nov 23, 2008
    Try inserting a Memory card and then check if it appears under My computer. You can also clean the Card reader with a Air spray to make sure the contacts are clean.
    If you can send me the Model no. of your Laptop I can check for the same. Since its a laptop and I guess the card reader is an internal one.
    Thanks
  • Indrajit Roy
    Ok. In that case you need to reinstall driver for Intel Chipset.
    Please click on this link http://support.gateway.com/support/drive...
    You have to enter the serial no. for your computer and download the necessary drivers and reinstall it. Also send me the serial no. so that I can look for it.
    Thanks
My gateway desktop does not recognize any sd/xd cards
Either the Card Reader isn't plugged in, or isn't any good.
Repair would be to purchase another Card Reader, but after checking the USB header/s on the motherboard, that the Card Reader is plugged into.
(FOLLOW Anti-Static Precautions)
Or you can use an external Card Reader, and plug it into a USB port,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1951865&csid=_61
Your keyboard has a problem too. It's stuck in capital letters.
joecoolvette
Dec 02, 2012 | Gateway DX483101e PC Desktop
Sd card wont show up on my gateway gt5228
You are missing the drivers for the card reader. They usually come with the chipset driver installation. I looked up your driver downloads on gateway support and it says there is also a driver in the "others" section caller "motherboard driver"
So, what you want to do is go to there site at the link below and download the "chipset" driver and the "motherboard" driver and install them. that should fix your problem.
Drivers link:
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2895
Jun 26, 2012 | Gateway GT5228 PC Desktop
Why doesnt my sd card reader work? I put in my gateway laptop and it doesnt work nothing pops up??
You might just have a bad SD card. Also, if you bought a card that is 4gb or more then you need a SDHC card reader. The HC stands for High Capacity. Look at the card to see if it shows HC under the SD. If it does then you need to find out if your card reader can read SDHC. If it can't then you need to go buy a new card reader that can do SDHC.
Jan 28, 2011 | Computers & Internet
Dell laptop DVD issue
If you have Vista OS, it could be a problem after installing ATI's Catalyst Software Suite. If you recently installed it, try uninstalling it or rolling it back to an older version.
Mar 20, 2010 | Dell Studio 1737 Laptop
Gateway GT5228 - USB Ports & All-In-One Card Reader don't work...
what service pack froom MS have you downloaded and installed? Sounds like the SM BUS DRIVER ARE MISSING. Install SP3 AND LET ME KNOW.
Feb 16, 2010 | Gateway GT5228 PC Desktop
Sandisk card reader wont detect my sandisk card.
This problem arises because your USB is not recognized by your computer. This issue can be solved by following the steps given below.
SOLUTIONS:
  1. Use the Device Manager to scan for new and recently installed hardware. From the start menu, select the 'Run' option. In the pop up box, type in Devmgmt.msc and then click 'Ok'. From the 'Action' Mmnu, click 'scan for hardware changes'. This will make Windows recognize any new devices that are installed. Now, close all device managers and control panels. Now see if your computer will read the USB device.
If the above method doesnt work, then try the following,
Disable power management of the USB hub. To disable the power management,
1.Click Start, and then click Run
2.Type devmgmt.msc in the Open box, and then click OK.
3.Expand the Universal Serial Bus controllers' node, and then follow these steps for each USB Root Hub that is listed:
4.Right-click the USB Root Hub and then click Properties.
5. Click the Power Management tab.
6. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK.
PS: If you perform the following procedure on a laptop computer, you may reduce the battery life.
Jun 02, 2009 | Gateway Computers & Internet
Aspire 3690 built in card reader
the card reader shouldnt show up under my computer. but the cards should show up there when plugged in. you need to update your driver on the card reader. check in device manager to make sure everything is working properly.
Apr 16, 2009 | Acer Aspire 3690 Notebook
Post recovery problems
http://www.drivershq.com/Drivers/Gateway/Notebook-Computer/Gateway-MX3228/9771/23769/23957/Drivers.aspx
Mar 31, 2009 | Gateway MX3228 Notebook
Acer Aspire 6920 6-in-1 card reader
put ur SD card in and restart will install all drivers and will make the card reader work
Mar 19, 2009 | Acer Aspire 6920 Notebook PC
Sd card reader
You can find the driver download at the following website that i have provided... look for the following in this list... If you have XP do the XP download and install... and the same if you have Vista. Hope this helps!!! this is a list specifiaclly made for your laptop. If anything else stops working refer to it and you might find the resolution. CIAO!
http://www.acerpanam.com/synapse/forms/AcerDrivers/Aspire%203680.pdf?CFID=1266040&CFTOKEN=21904604
Look for:
IF YOU HAVE WINDOWS VISTA--------->
Card Reader TI Driver 2.0.0.6q for Windows Vista
Windows Vista
Card Reader TI Driver 2.0.0.6q.zip
IF YOU HAVE WINDOWS XP----------->
Cardreader - Driver V2.0.0.2
Windows XP
TM4220_CardRdr.zip <--- click on this within the website i provided.
good luck.
Oct 20, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
David Payne
David Payne
