No power I have not power, no power light,just a ticking sound comming from the monitor
  • 2,992 Answers
That ticking is from the power supply section of the monitor. It means there is a short circuit somewhere in the unit. Usually this is a part called the horizontal output transistor, which is mounted on a metal heat sink somewhere on the circuit board. It is possible to repair by replacing the transistor with the same part number (the number is on the transistor). Sometimes other parts are bad too, though, so the repair could be more difficult than that.
Posted on Nov 21, 2008
the power transistor on the SMPS of the monitor is blown,
you will need a skilled person to diagnose and replace the component
Aug 29, 2016 | HP Compaq Fp5315 15 Lcd Monitor With...
793MB flyback went off.
bad power supply, a blown out transistor,diode, but check horizontal output first..
take it out, then test again,,if its stops ,and power light comes on,, then change h-output transistor.
Mar 05, 2014 | Samsung SyncMaster Computers & Internet
My monitors light is blinking with a tick tick sound
Possible fault is A) blown LopT driver transistor, B) some of the rectifying Diodes in Power supply is short or open, thus not suplying needed voltage to circuitry. Also check all electrolytic capacitors in PSU circiuit & around Lop T. If any of them is geting hot or olstic cover is cracking or shrinking , or capacitor is bulginh\g on top.... Replace.
Oct 04, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
Tick tick sound appear from acer 15" crt monitor power supply circuit
the sound you heard come from power regulator. its just fine, just indicate that part are over heat.
maybe you ill consider replace your monitor with LCD. more friendly for your eye and less power consumption
Mar 08, 2011 | Acer AC 711 17" CRT Monitor
Hello.Ihave a princeton vl1919 monitor.The problem is when you press the power button the light comes on for about a few seconds then goes out then you hear a tic tic ticing noise can i try and replace the...
Try looking for bad caps first, see example of failed PRINCETON monitors because of bad caps here:
Post back what you see so we can guide you further.
The ticking sound is from power supply turning on and off.
Feb 23, 2010 | Princeton Digital VL1919 19" Monitor
My monitor just went completely blank. There is a
The ticking sound you hear is from the power supply trying to power up. If you can solder you should be able to repair the monitor yourself. The problem is caused by blown capacitors on the power board. Go to our web site at : We have pictures of what to look for. Open your monitor and look at the power supply board for any blown capacitors, replace all that you find. The replacement parts can be ordered from several places on the internet or we can supply them for you. The replacement parts will need to be high temp and will be marked 105c. The values you need to get will be marked on the sides of the ones you take out but will be something like 220uf, 470uf, or 1000uf etc. and then a voltage rating. When you install the new ones be sure to insert them with the polarity stripe going the same direction as the old ones come out. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping. If you have any questions just let us know
I hope this helps if so please rate our solution.
Corporate Computer
Oct 20, 2009 | Computers & Internet
X2 MW19R is ticking and no display?
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you can't do the repair we offer a repair service, contact us for more details or if you have any questions.
I hope this helps, if so please rate my solution.
Corporate Computer
Over 21 years of computer and printer support/repair
Aug 13, 2009 | X2Gen MG19MY 19" LCD Monitor
No display
The ticking sound is from the DC source voltage being fed into the flyback transformer. Because the transformer coil has one or many shorted components attached to it, it won't start. This monitor needs to see a pro to fix it.
Apr 27, 2009 | NetTV DTV 34X 34 in.CRT Conventional...
No power to monitors, but blinking led on ac adapters.
Try replaced with a new AC Adapter. If it still the same...then you got a busted backlight inverter. To order a new AC Adapter go to this site @ click on lcd parts. have a nice day!
Feb 23, 2009 | ViewEra Computers & Internet
Computers & Internet Logo
650 people viewed this question
David Payne
David Payne
