Question about Minolta EP4000/5000 CS/PRO Copier
Copier making black backgroung after 3-4 prints.
WHEN I MAKE CONTINUE 3-4 COPIES, PAPER`S BACK GROUNG BECOMES BLACK. TELL ME PLEASE WHY IT IS HAPPENING.
    Problem Solver:
  • 11 Answers
Check cleaning blade
Posted on May 07, 2008
Check ur voultage meter and connection of your scanner. MAS
Posted on May 05, 2007
    Problem Solver:
  • 8 Answers
Possibly your drom is no longer discharging properly. This could be caused by bad drum, bad or dirty erase lamps.
Posted on Apr 02, 2007
System fault 9-363 i tried everything i know, please help
You can try this, try to clean the dev rotary sensor. open the upper right hand cover then there are two assy's to be removed also for you to access the rotary sensor located inboard side. this sensor senses the home position of rotary developer. to removed this sensor, you have to open the rear cover, then rotary pwb. some 9-363 code is due to busted fuse in the rotary pwb. Or could also be a fault with the fuses.
May 13, 2008 | Xerox DocuColor 12 Printer
Print Black Page
Is the scanning lamp coming on ? No, replace lamp
is there a print in the background? Yes, check Seperation unit ( inside under the drum, usually three thin wires)
Nov 19, 2008 | Sharp AR-M450N Copier
Dark edges
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty.
Does this happen when,
Using the Doc Feeder
When making copies from the Glass
Or when you print from a computer (assuming you print from a PC)
If you print something and this happens then it is inside the machine
Probably toner or developer dumping...
Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment...
One more test
If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Oct 25, 2008 | Sharp AL 1215 Black and White Copier
Printer does not make black copies, it will print colored copies but not black kodak 5300 aio printer will not print in black. ink cartridge new.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
Aug 26, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have a xerox dc12 with error message please turn machine off and on again 9-363 have tried several times but no good! what else can I do?
That's a process problem with that machine.
May require a service call .ON and OFF is pretty much all a customer can do and wait for it to setup.
NOTE: The problem occurs because of the trickle development system in the machine, making extended lengths of black and white copies / prints does not allow the black developer housing to purge itself of excess waste Toner (Dry Ink) and Developer. There are two solutions for the problem:
  • Make 1,000 copies / prints of a black and white job, then make 150 copies / prints of full color. Continue making 1,000 copies / prints of the black and white job, then 150 full color, and so on, until the entire black and white job is complete.
  • Make extended jobs in groups of 100 by making 100 copies / prints of the black and white job, then allowing the machine to cycle down (return to 'Ready') and making the next 100 copies / prints. Continue in this pattern until the entire black and white job is complete.
Apr 28, 2008 | Xerox DocuColor 12 Printer
Error 9-363
NOTE: The above solutions are based on jobs using 8.5 x 11 inch paper, single sided, with no more than 28% coverage.
Feb 18, 2008 | Xerox DocuColor 12 Printer
or
  1. Power OFF the machine.
  2. Wait 30 seconds.
  3. Power ON the machine.
Dec 04, 2007 | Xerox DocuColor 12 Printer
Docucolor 12 error code HELP
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Sep 13, 2007 | Xerox DocuColor 12 Color Copier
Copies print all black
Make 1 copy with the lid open & verify that the scan lamp is lighting & that the scanner moves. A blown lamp is the most common cause for all black copies.
Jun 11, 2007 | Gestetner 5499 Black and White Copier
89 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
