Question about HP PAVILION SLIMLINE S7520N AMD Turion 64, 1.86 GHz, 1024MB, 200GB, DVD-RW/CDRW Combo Drive, Slimlin... (EX259AA#ABA) PC Desktop
OK, here's the problem..
The lightscribe enabled DVD/CD drive seems to have a mind if it's own.
The door opens and closes at random..This happens whether there is a disk in it or not.. It will even suddenly open when it is playing either a commercial DVD movie or C/D music disk thereby interrupting the program that is running....
What to do??
david
    Genius:
  • 1,550 Answers
Unplug your unit from power chord for 30 minutes and plug back the power chord to the unit . This will reset your unit .
This problem can be due to bad motor which causes the door to open at random times .
Posted on Nov 21, 2008
  • SAM ANDERSON Nov 21, 2008
    Sorry for First post dont consider that solution I misunderstood the problem .
    You go to control panel and check whether the DVD drive status is working or it is hardware fault .
    If the status is ok .
    Then you try to open the dvd drive and check for any loose connection .
  • HP Master
  • 4,338 Answers
Go to Control Panel>System>hardware>device manager.
Click on + sign next to cd/dvd drives.
Right clik on the DVD drive and select uninstall.
then restart the unit and see if it is corrected.
Let me know,
Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Lightscribe dvd drive won't work. the eject command does not make it open either. seems to be jammed. if i break it down can it be "unjammed" without ruining it?
Actually it's probaly just got some dust or something in it. What you do to manually open it is take a needle, thumb tack, or safety pin and simply insert it into the tiny hole above the eject button on the dvd drive itself. You'll feel the tip of the button when you push the pin into the hole then it will pop the door and the drive will open properly. This has gone on for cd/dvd drives for years. Usually just the cause of dust or what have you being stuck in the mechanism.
Jul 01, 2013 | Computers & Internet
DVD Drive opens automatically when I start up the pc and won't recognize disc
I had the same problem and it was the sata cable, I would check this and change it for one you know is good. hope it solves your problem.
Jan 09, 2013 | HP DVD 740VI 16X16 Dual Layer LightScribe...
Installed a new dvd burner with lightscribe and my comp runs really slow
Please enable DMA by right clicking on the CD drive icon and go to the DMA tab.
Jun 22, 2012 | Memorex 24x Dvdrw Drive With Lightscribe -...
Can i add lightscribe to a new laptop? just ordered it and realized it does not come with lightscribe.
The LightScribe-enabled CD/DVD disc drive contains a special laser that pumps light into this label to create whatever designs you have created. The light from the laser causes a chemical change in the dye coating that shows up as a visible point on the disc.
The best way to add this to your new computer is to buy a Lightscribe external drive that connects via a USB port.
Oct 03, 2009 | Computers & Internet
Not able to print directly on CD/DVD
Printing Directly onto a CD or DVD in Roxio Express Labeler
  1. Make sure that the product is turned on and that the USB cable is connected to the product and the computer.
  2. Click Start , click All Programs , click Roxio , and then click Roxio Express Labeler v3 .
  3. Click Disk Label , then click Options . Figure 1: Options c01452912.gif 1 - Options button
  4. The Options screen appears. Figure 2: Options screen c01452913.gif
  5. Make sure that LightScribe 12cm Disc is selected from the Disc Label menu, then click OK to return to the Roxio Express Labeler window.
  6. Click Disc Titles , type the title and subtitle for the CD or DVD, and then click OK . Figure 3: Disc Title option c01452914.jpg 1 - Disc Titles button Figure 4: Edit Disc Title screen c01452915.gif
  7. Click Background , then click Import Background to use an image on the computer as the background on the CD or DVD. Click OK to return to the Roxio Express Labeler window. Figure 5: Background option c01452916.jpg 1 - Background button
  8. Insert a LightScribe CD or DVD into the LightScribe drive of the product. Make sure that the label side of the disc is facing down.
  9. In the Roxio Express Labeler window, click Print . The LightScribe label is printed on the CD or DVD. Figure 6: Print c01452917.jpg 1 - Print button
Jun 18, 2009 | HP Office Equipment & Supplies
Lightscribe dvd/cd super multi drive electing all by itself.
It may be a hardware problem. If it starts ejecting as soon as you switch on the system i.e. before booting into the operating system then it is definitely a hardware problem. Take the drive to the service centre and get it fixed. Or if it happens when you are using windows then it might be a prank program or a virus. Check your running processes and make sure all are right. (You can google the process name and check the results)
May 18, 2009 | HP Computers & Internet
CD/ROM Door automatically pops open, and then repeats after it is closed. Sometimes seem to be triggered by opening a random program.
sir
it is due to a virus called odiya or odissey in ur computer..i will advise you to install a good antivirus on ur computer and perform a full system scan
thankyou for using fixya
hv a nice day
dont forget to rate the solution
Mar 25, 2009 | LG GWA-4082N DVD RW Dual Layer Burner
LG GCA-4080N internal drive
It seems that what you have is a combo drive only :(
it only recognize DVD reading. no matter what driver you used. need to buy a dvd writer/ that said can write dvd.
Types of Optical Drives and CD/DVDs
Optical drive type Read from CD/DVD-ROM media Write to CDRW media Write to DVD ±RW/R media Write to DVD +R DL media Write label to LightScribe CD-RW Write to DVD-RAM media DVD-ROM Drive Yes No No No No No DVD and CD-RW Combo Drive Yes Yes No No No No DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes No Yes LightScribe DVD±RW/R and CD-RW Combo Drive with Double- Layer support Yes Yes Yes Yes Yes Yes Blu-Ray Disc DVD±RW SuperMulti Drive with Double-Layer support Yes Yes* Yes Yes No Yes *Low speed (4X) and high speed (4-12X) are supported. UHS-RW (24X and 32X CD-RW) is not supported.
NOTE: Some of the optical drives listed may not be supported by your computer. The listed drives are not necessarily all of the supported optical drives.
Dec 26, 2008 | LG (GCC4521BBULK) CD-RW/DVD-ROM (Combo)...
Lightscribe enabled drive opens
Sounds like there might be debris that is keeping the door from closing all the way properly so when that happens it can make the door open up from time to time.
IF you don't have debris, could also be that the mainboard inside of the drive is going bad and causing the door to open and close on its own.
Change out the drive with a new one cause not only will that take care of the door problem but you'll have a new laser in the new drive and will last much longer.
Nov 20, 2008 | HP PAVILION SLIMLINE S7520N AMD Turion 64,...
HP PAVILION SLIMLINE S7520N AMD Turion 64, 1.86 GHz, 1024MB, 200GB, DVD-RW/CDRW Combo Drive, Slimlin... (EX259AA#ABA) PC Desktop Logo
21 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
