Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
Problem with novar control board
Went to a family dollar cause they said the alarm went off and they could smell burning...so when i went out there, the only thing i could do.. because i didnt have a tall enough ladder to get on the roof, at least not at the time...so i checked above the drop ceiling and could only get to where two piece's of flex came down through the roof along with a piece of sqaure duct going through the roof also..with a novar control board mounted to it..with i think it was 6 or 7 wires total on the board and three wires connected to the alarm.. but the fuse inside the board was NOT blown...thats the only thing i could see at the moment.. any suggestions? i thank you for your help
  • 24 Answers
Call a professional! Novar control systems can be connected to HVAC,lighting, alarms, etc. Guessing or trying to fix something if you are not at least familiar with the control system can cause more damage than you are willing to pay for. sometimes in life it is just as heroic to know when to put your hands in your pockets and slowly back away.
Posted on Dec 18, 2008
LG LDF6810ST won't power up there is power going to dishwasher
the main control board is fried from what you've described, you will need to dismantle it and remove the board (there will likely be visible signs of damage if there was a burning smell) relatively easy and cheap to replace
Jan 01, 2017 | LG LDF6810ST Stainless Steel Built-in...
Why do I get audio, but no video?
blown power board is a possibility
if youre good at tinkering removed the back panel and check the boards. with the power unplugged of course check for smells strange smells like acid burning. if not get a repairman your looking at 200 dollar repair or more by a repairman, or might be an easy fix for under a dollar if you know how to solder a cap or two.
Dec 15, 2015 | Samsung Televison & Video
I was wondering if someone could help me find which board could be bad on a Samsung PN59D8000FFXZA plasma TV.
look on the power supply board for burned parts. The board that controls the back light may have some burned parts as well.
Jul 05, 2015 | Samsung PN59D8000FFXZA - PN59D8000 59 3D...
05 Nissan Murano . I was in a hurry and charged battery and had ( - + ) Mixed up. Smell burning . Disconnect and redo do. Car started but now display screen is completely off. Heater and fan still on but...
HOOKING UP A BATTERY BACKWARDS CAN CAUSE SEVERE DAMAGE. THE SMELL IS MOST LIKELY ONE OF THE CONTROL BOARDS THAT SHORTED. BURNED CIRCUIT BOARDS REQUIRE REPLACEMENT
Dec 09, 2014 | 2005 Nissan Murano
My air conditioner on my 1999 kia sportage smell like smoking and like burning went turn on
do you turn on fan when using a/c ! if so heres a few causes-- burning smell in car, blower motor is going bad, or resistor is burning up.the resistor controls the fan speeds. good-day !
The burning smell could be due to gas leakage in the engine compartment. The gas smell is being sucked into the fresh air intake of the air conditioner. It can be avoided by checking either fuel pressure regulator or fuel injector.
Sep 24, 2011 | Kia Sportage Cars & Trucks
My dishwasher by Frigidaire Gallery Professional Series Model gpd8998jc0 has all lights flashing and could not be started. I smelled burning from dishwasher. Could it be motor burning?
it could be the motor depending on where it's coming. You can remove the lower panel, there are only two screws that hold it on. Look under their and inspect the motor.
Another part that could cause this issue is the mother board. The board is located behind the control panel. Remove the screws around the door frame to loosen and remove the control panel.
On most of these you also have to remove the plastic shielding that cover the control board. To do so remove the three or four screws that mount the board down.
Often these control boards will burn and create a smell like this.
Let me know.
Mar 26, 2011 | Frigidaire Professional Series 24 in....
I have a 50803 projection tv. The picture went out. It started with a green tint and lines going across it. I turned off the tv and then turned it back on. Now there isn't any picture at all. There was...
This is very simple to repair if have burning parts smell,replaced parts that burning smell,the parts that cause by the burning smell part,make it to dies that hard to find.My sugestion replaced the DM power board,first to get power back,than go on from there.
Dec 12, 2009 | Mitsubishi VS-50803 50" Rear Projection...
Went to a family dollar with a roof top unit and at the time could only check right above the drop ceiling, where there was a return and supply flex and a piece of square duct going through the roof and a...
sounds like a smoke detector to me. usually they just break the red or the green through a relay, if it smells smoke. could be dust burning off the heat strips first use, or you could get on the roof and find burned wires or motor. lots of old wires burning up with heat strips kicking in this time of year. i usually have em turn off alarm so fire dept wont come and turn to max heat and burn off the strips , measure amps, check wires, and all relays etc. you may have to bypass smoke detector till done. then return to correct "as found" wiring and reset alarms. hopefully no call backs. good luck.
Nov 21, 2008 | Heating & Cooling
Burning smell and light switch does not work
The controller needs to be repaired. We regularly repair these control board assemblies for only $32.50 nationwide, and that's much cheaper than replacing the board. For safety, disassembly and other info see http://tinyurl.com/yzjozk
Jan 14, 2007 | Whirlpool MH7135XE Microwave Oven
Heating & Cooling Logo
126 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
