Question about Maytag PYE2300AY Electric Dryer
Dryer leaves marks on clothes
The marks are eye shaped and black about 1 " long someone said that I could use viniger to clean the machine yes no
  • cyndihoath Nov 21, 2008
    my dryer is only 2 1/2 years old and is doing the same, only noticed on light coloured clothing. I noticed black "goo" around the felt seal at the front of the drum. After reading some stuff on the internet I wonder if it's a treansmission seal leak. Going to check into this and find out cost of repair or can I do it myself?
  • 706 Answers
Folks,
Yes, you can use white vinegar to clean the dryer surfaces inside.. and the goo you see may be some of the gasket cement that secures the felt seal to the drum and s breaking free. I suggest you do a thorough examination around the entiore drum circumference for any traces of this material and clean it off with a single edge razor and solvent such as alcohol or mineral spirits. Be sure to allow ample time for the residue from those solvents to dissipate Before cycling clothes in that dryer. I hpe this helps you. Please post yopur replies if these suggestions did not solve your problems and we can take a closer look.
Regards,
Rick
Posted on Nov 23, 2008
Dryer eating clothes
It may be running way too hot. If the filter is clean there may be a thermostat issue.
Mar 19, 2014 | Dryers
Frigidaire FDE336RES2 Dryer marking Clothes
Excessive lint on or near the heater coils will send smoldering lint onto the clothes. Use a flash light and go inside the drum to see the heating coils or lifting the top up who should be able to see the lint build-up on the coils. These need to be cleaned.
Nov 10, 2009 | Dryers
Dryer is leaving black marks on cloths.
was a pen or crayon placed in the machine by mistake ? You will need to
remove the residue, use rubbing alcohol on a rag for marker or pen ink , crayon use a razor scraper and then clenser and scrunge pad.
Oct 26, 2009 | Fisher and Paykel DE06 Electric Dryer
Electric dryer leaving brown marks on clothes
i would asssume that the marks are "crescent moon" in shape??? if so either the front or rear felt has/is going bad and casuing clothes to slip betweent the tub and the seal causing the streaks
Mar 14, 2009 | Whirlpool Dryers
Front load washer frigidaire leaving small marks on clothes
I have twice taken apart this front loader Frigidaire washer (also sold as Kenmore) to replace the rotted out aluminum spider arm supporting the spin-basket (which seems to universally fall apart within 5 years), and now I started observing the described black stain pattern on the clothes. As with the spider arm breakdown, this problem has nothing to do with water hardness, softeners, detergents, or dryers (I line-dry all my clothes), and everything to do with the poor quality design of this machine. I have not yet positively identified the cause of the black stains, but I suspect that the bearing seal is breaking down and in the process is releasing greasy particles that mix with the clothes and create the described black stain patterns. Unfortunately the repair would cost more than a new machine for most people, as the spider arm is probably just about gone by this stage. I am lucky to own another junk washer for spare parts and am able to fix it myself. For skilled do-it-yourself mechanics, it is possible to find a replacement seal and bearings on the internet, assuming the spider arm is new (over $200 part), or still in good shape.
May 16, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Dryer Model FLGB43RG
those "burn" marks if they have an arking shape to them are smudges from the felt that goes on the drum support above and bellow the door inside the drier. the felts wear out every five to seven years or so. easy repair. send me a model number and i could go into more detail. part numbers ect.
Sep 23, 2007 | Zanussi TC7114W Electric Dryer
Black marks on clothing at completion of drying cycle
Is the residue coming from the back or front of the drum? Most dryers are equipped with 2 drum roller supports in the rear under the drum. You may have a drum roller that is going bad and some of the rubber residue is getting past the drum seal. Some dryers are quipped with an additional pair of drum rollers under the front of the drum as well. I would check all the drum rollers to see if they are all in good shape. A definite symptom of a bad drum roller is finding black residue along the outside of the drum where the rollers ride. You will have to open the dryer cabinet to see the outside of the drum. Also, check the rear drum seal to make sure it is not crimped or folded inwards in the drum. The felt seal in the back should should ride evenly all the way around the drum and should not be that visible inside the drum itself. That is, you may see some of the seal, but you shouldn't see part of it folded inside the drum or bits of it tattered or torn. I hope this makes sense to you. Let me know if this helps.
Jul 06, 2007 | LG DLE2514 Electric Dryer
Black marks
throw a clean pair of old sneakers in the dryer with the clothes. this should not allow the clothes to stay in one place during the entire dry cycle
May 25, 2007 | Equator EZ 3612 CEE Front Load...
Maytag PYE2300AY Electric Dryer Logo
104 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
