Question about RCA PROV712 Camcorder
RCA prov712 battery will only last 5 minutes
I charged 2 different batteries, even bought a new one. I can only use the camera for about 5 minutes until the battery light comes on and then the camera turns off. Please give me any info before christmas. Thanks
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 216 Answers
Be sure to charge for AT LEAST 14 hours on the new battery, even if the charger light goes out - it's still trickle charging. It's normal for most camcorders to auto-shut off after 5 minutes, if it's not recording. But if your batt light comes on, the problem is probably with the battery.
Posted on Dec 20, 2006
SOURCE:
Camera only takes 5 photos before dying
This new battery, if it is the exact type of battery recommended by the manufacturer then it is most likely not the battery. if you bought a similar battery it might be for even the minimum difference makes all the difference with digital cameras. for camera repair this company does a good job and you can even select your problem on their online quote. www.teleplancamerarepair.com
Jul 08, 2010 | Canon PowerShot S500 IXUS 500 Digital...
Tip
I have the same problem with a Canon Powershot s20. Bought approx 5 years ago...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Jan 28, 2008 | Samsung Digimax D53 Digital Camera
Will not hold charge. put in new battery and fully charged it. Lasts about 5 minutes. Use dock. Is this the problem?
How long have you had your dock and batt.?
They might be in a need of a change.
Here are the steps:
1. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
2. Turn on your camera without the memory card.
Mar 13, 2010 | Kodak EasyShare C875 Digital Camera
Acer aspire 3050 new battey will not charge
Sometimes batteries need a full 24 hr initial charge before they will work. You would be advised not to use the M/C during this period. Also it will take several charges before the battery reaches it's optimal performance.
This could be the problem so it's worth a try.
Aug 21, 2009 | Acer Computers & Internet
I have a Olympus C8080 digital camera that won't start up? It has a brand new battery, which I purchased because the old battery was over 4 years old, and because it took a charge in about 5 minutes, but...
Are you using a genuine Olympus BLM-1 or a cheap "compatible" battery. It's possible that the original fault was caused by a worn out battery, but if you've bought a cheap compatible from places like eBay or Amazon then they're often very poor quality and frequently not of the stated charge capacity. Sometimes they're not even lithium batteries so your charger and camera won't work properly with them They're often so cheap that there is no effective quality control so your new battery may well be a faulty one. There is no way that the new battery would have been fully charged after just eight minutes: although they're usually supplied with a partial charge it's nowhere near a full charge.
Another possibility is that your Olympus BCM-2 charger is faulty.
Worst of all, you may simply have been sold a pup. If the eBay seller described the camera as being in good working order then I suggest you ask for a refund and return the camera. Although private sales are "as seen" they also have to meet the sellers description. If the seller won't play ball then you may be able to claim PayPal buyer protection if you used it to pay the seller.
Your camera is a five year old model now and way outside the warranty, in the UK perfectly good used examples sell for around £125 and this is likely to be less than the likely cost of any repairs if you send it to Olympus. You'll need to carefully weigh up what you've paid so far, what you're likely to have to additionally buy just to diagnose the fault correctly and what you can get if you just cut your losses and sell the camera as is.
Apr 14, 2009 | Opteka (OP-T2XUHD-C8080) for Olympus...
Easyshare 721 battery problems
You need high-power re-chargeables - 2300 mAH or 2500 mAh
May 13, 2017 | Kodak EasyShare CX7430 Digital Camera
Ixus 75 battery discharges overnight even if the camera is turned off.
That's it, the battery's defective, it's not the camera...unless you've tried another (new) battery...
Sep 27, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Nikon coolpix 2100 camera won't stay on
I've been having problems with the batteries and the camera refusing to start even with fresh batteries. I bought loads of new rechargable batteries and have finally found some that work. Duracell rechargables. Theyr'e brilliant and keep their charge for ages despite continuous use of the camera! Last summer I managed to take 975 photos before the batteries finally decided to give up!
Jan 27, 2008 | Nikon Coolpix 2100 Digital Camera
FinePix E500. 4.1 : model # BL00402-200(1) E
Indeed you can!
I would recommend against using any of the older NiCAD batteries, however.
The newer (and - BY FAR - more efficient) standards is NiMH batteries. (Nickel Metal Hydride.)
I used to be an Energizer fan myself... But as I worked in electronics retail, I tried many different brands of batteries with our products. I actually hated Duracell because of the crap quality of their older product lines.
But eventually, I had to grudgingly admit that Duracell batteries were far superior to any other brand currently on the market. (No less expensive, however. Pretty much the same price.)
I use the 15-minute charger currently available from Duracell. It cost about $30, but it comes with 4 AA batteries with a rating of 2400 mAh.
This rating is basically what determines how much of a charge the battery can hold. The higher the rating, the longer the battery will last.
I also bought an extra pack of 4 AA's while I was at it. I bought all of this for my digital camera. (Canon S3 IS.) The batteries in the extra pack had a higher rating of 2650 mAh.
Even using the 2400 mAh AA's, my camera lasts for a few DAYS of continual use! I will admit that I rarely use the flash on my camera. But even with the flash, the batteries last several hours with continual use. The 2650 mAh batteries last even longer. (Yes. I have monitored and recorded usage vs endurance. I know. What a nerd I am, eh? :P )
Perhaps you've had bad luck with Duracell before, but so did I. I'm still not too fond of their alkaline batteries, either. Perhaps you should consider giving the Duracell rechargeables a try?
Click HERE to see the product I bought on Best Buy's site. (I bought mine at Walmart, however.) It is the 15-minute charger system. It works with both AA's and AAA's. (I had to really inspect the device after I bought it to see how it recharges AAA's though. But it works great.) It actually does charge in 15 minutes, too. Every time. It's so powerful in fact that it uses a fan to cool the batteries while it's charging. Now that's awesome. :)
Remember to make sure that you give the batteries a full charge before you use them. Also make sure that you don't charge the batteries again until they're completely drained. Otherwise you will significantly decrease the charge capacity of the battery. Duracell has an excellent guide on their site on how to lengthen the life of your batteries. (I just found it trying to look on their site for their own product...which I did not find. Good batteries, crappy web site. Bleh...)
Click HERE to see this spiffy guide. It actually contains excellent information.
Otherwise, you can try any other brand that you prefer. Energizer is still second best, followed by Rayovac. (This is from my own experiences, of course.)
Let me know what you think. :)
Cyryl
Nov 10, 2007 | Fuji FinePix E500 Digital Camera
Video Cameras Logo
156 people viewed this question
Top RCA Video Cameras Experts
Marvin
Marvin
Lawrence Oravetz
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
